This week I got a GatewayOT inside.
This I now flash the correct firmware. I want it gateway.hex flash but I get this error message: "Please manually reset the Open Therm Gateway"
What can I do to fix this? Like asked for help.
Flashing firmware problem
Re: Flashing firmware problem
Did you try powering off and on the OTGW at that moment? Because it's not really an error but a command (for the user). You need to power cycle the OTGW for the upload to start.Chriskras wrote:This week I got a GatewayOT inside.
Kind Regards,
Greg.
Greg.
Solved my problem was that all of the RS232 connectors were not connected. So here I soldered it again.
