Hi Andre,
My firmware is 15, (language version 15-07-2008).
Do you know if I can upgrade the firmware somehow?
Do you also have the callenta, does the menu "externe toegang" exist?
Rob
Which Thermostat
Re: Which Thermostat
I have a loaner iSense with firmware version 19 (language version 09-4-2010), which does have the "externe toegang" menu entry and works with the gateway. The existence of that entry doesn't depend on the boiler make and model.
I don't think there is any way to upgrade the thermostat firmware short of sending it to Remeha.
Where are you located? Maybe there's someone nearby with a gateway that will allow you to hook up your thermostat to verify if a setpoint override will work or not.
Hi Hvxl,
I think you are absolutely right!
Good Idea to ask someone for some help.
I live in the north of the Netherlands, and would be happy to take my iSense for a drive...
Rob
Rob
Rob,
Maybe I have a solution for U
I am a HVAC Service Technician and last week, on the office they found some Isense thermostats that where not used anymore.
I have got one of them... (just one)
After checking the device I found this: Version 19, Language version 09-04-2010
And it contains the option 'externe ingang'!
I got it for free, so if you would like it, I can send it to you!
There is a small scratch on the front at the display.
But If you replace your own print with this one, you will have a perfect Isense to use?!
Let me know if you want it!
André
André
Hi Andre,
I can just smile after reading your message...
Of course I would like to accept you offer.
I don't know how to sent you a private message, can you contact me at:
Rob at Vledderveen.net
Rob
Rob
