TP-Link Ethernet converter firmware image
roblom
Re: TP-Link Ethernet converter firmware image
Post by roblom »
Somebody?
Who developed this actually?
adijk
Post by adijk »
Maybe you should have a look at this post: domoticaforum.eu/viewtopic.php?f=75&amp ... 189#p73174.
I don't have a TP-Link my self but it sure looks like the same problem.
jeroenc
Post by jeroenc »
Hello all,
I would like to receive the firmware and manual as well pls.
And I second the previous poster; the seller has to provide more documentation that pressing the rest button gives more problems than it solves!
PS: TP Link TL-WR710N
Thanks for the help!
Regards, Jeroen
jeroenc
Post by jeroenc »
*bump*
emmeesse68
Post by emmeesse68 »
I bought a OTGW kit with USB option only, since WiFi option wasn't available, and because I already own an TL-WR710N (EU) v.1.2.
I'm interested in the configuration/firmware, I think (better: I hope) I can install OpenWRT on my own but a bit of documentation for the configuration would help...
Could anyone share the needed packages and configuration?
Thanks in advance
M
fgoldie2015
Post by fgoldie2015 »
is it possible that i can get the firmware and manual for the TP-Link TL-wr710N to ?
Thanks.
jimlambe
Post by jimlambe »
Does anybody have links to TL-WR703N and/or TL-710N working openwrt images so I can get my OTGW connected to my Vera Lite.
Jim!
emmeesse68
jimlambe wrote:Does anybody have links to TL-WR703N and/or TL-710N working openwrt images so I can get my OTGW connected to my Vera Lite.
Jim!
Here you can get OpenWRT for a lot of devices based on the same Atheros SOC:
http://downloads.openwrt.org/latest/ar71xx/generic/
Better check your device wiki page to understand differences between hardware releases (e.g. 710n v2 has a smaller flash than v.1.xEU thus can handle only reduced size firmwares).
While I think it's a bit OT on this forum to get deeper in the subject, my advice is to take time and read OpenWRT wiki. If you're good with Linux, it's quite easy...
