My configuration,
Nefit trendline hrc35
Ems to opentherm converter
Opentherm gateway
Honeywell round modulation thermostat
Domotiga home automation running on a raspberry pi.
When i look into the logging of domotiga it looks all ok, when i change the temperature variable in domotiga it is overridden and keeps overridden,
but the thermostat is doing just his own thing.
The first time i did it it looks like it was working and the logo from honeywell home automation showed in the thermostat, but now.
nothing happends on the thermostat.
can anyone help me ?
Thanks
Opentherm Override issue, honeywell round modulation
- Starting Member
Re: Opentherm Override issue, honeywell round modulation
I am using the OpenTherm gateway using a Honeywell round modulation and a Daalderop boiler.
For overriding the temperature setpoint I use the TC= command. About 1 minute after issueing the TC command I see the Honeywell symbol and the updated setpoint. I read back to actual setpoint, and that matches the value set by the TC command.
Geert-Jan
Geert-Jan
I can't help with the domotiga part. Do you get the same issue when using otmonitor? If so, can you provide a log that shows your attempts to change the setpoint?ronaldkelleners wrote:The first time i did it it looks like it was working and the logo from honeywell home automation showed in the thermostat, but now. nothing happends on the thermostat.
I`m using a Honeywell Round Modulation on a Vaillant Boiler and the setpoint of the thermostat is send using a HomeSeer script TC=xx,xx and after several minutes the thermostat takes over the setpoint
Note: I`m using an OpenTherm gateway with firmware 3.4
I have almost the same issue:
I'm using Opentherm interface with Honeywell Vision modulation and Remaha Calenta. With otmonitor i can see all data. But for some reason I'm not able to override temperature:
7:33:04.412430 Command: TC=22.00
17:33:04.431802 OK
17:33:40.252426 A40091600 Read-Ack Remote override room setpoint: 22.00
17:33:49.623881 T9018141D Write-Data Room temperature: 20.11
17:33:49.717536 B5018141D Write-Ack Room temperature: 20.11
Still flame is not turned on
Also no luck with TT and TR command
I read on the forum that there where some issues with Honeywell Vision modulation. Is there still a problem overriding tempeture with this Thermostat or am I doing something wrong?
Thanks in advance.
17:33:04.431802 OK
Thanks in advance.
That's a completely different issue. You have to disable the TELE input.
Thanks for your reply it was indeed disabling tele input (settings, press clock 5 secs, set option 7 to 0).
I was not sure in what thread i should place this issue as it was indicated that my issue already had related threads.
- Starting Member
In the weekend i have some time to test the gateway.
I will give some response.
Thanks.
Ronald
Thanks.
Ronald
