The gateway was sitting happy next to the boiler on a shelf and today i finished another project "Starcase Lights" and i think it is just coincidence but all of a sudden the boiler started heating. Hmm strange let check HS2 nope seems fine should not be heating. Next check down stairs on the thermostat, hmmm no display.. Back to the attic i disconnected the OTG en connected the thermostat directly to the boiler. Tada problem solved. Placed the OTG back in business and yet again the problem is back. Disconnected the adapter of "Starcase Light" which is giving me a loud noise sound next to my pc speaker so it is pending replacement but this should not be an issue when it is unplugged
I measured X1 and it gave me 21,5 volts when the thermostat is not connected and around 6 volts when the thermostat is connect (but the display is not working) i`m not sure what to do next. The 5 volt on IC1 and IC2 are fine as stated in the trouble shoot link
Serial communication is working
22:30:07.153668 Command: PR=A
22:30:07.187522 OpenTherm Gateway 3.4
22:30:48.408234 Command: PR=M
22:30:48.424156 BV
22:31:49.118202 Command: PR=V
22:31:49.134696 3
22:32:04.245730 Command: PR=L
22:32:04.261271 RXOF
