problem with "light on when motion" scene
Forum all about Z-Wave Fibaro
I-1
Post by I-1 »
I have build the following scene:
"When between 17:00 and 09:00 motion is detected the lights go on and after 30 seconds the light goes off again."
I have build 3 scenes to make this work (see screenshots below).
My Problem:
When motion is detected the lamp goes on, and after 30 seconds the lamp goes off again.
But right after the lamp has gone off I make some movement to trigger the motion again and the lamp is not turning on...
After a while this is working again if I try this 2 min. later...
But this is not how it is supposed to work right?
Does anyone know how I fix this?
raymonvdm
Re: problem with "light on when motion" scene
Post by raymonvdm »
In HomeSeer there is an option to prevent the event from triggering to often (cannot retrigger for x minutes) maybe Fibaro has the same options?
I`m not sure how the event works, but are you sending the on and off at once but with a sleep of 30 seconds? Maybe these are the 30 seconds at which the script is not starting because it is still running (sleeping 29 seconds before finished)
Akatar
Post by Akatar »
does the hc2 see the motion? some pirs only report every x minutes
blokl
Post by blokl »
Return to “Fibaro”
