Again a new product with the Intel ATOM 330 and Windows Homeserver:
The entry SQA Home Server. Fitted with 1GB memory and a single 500GB Green Power Hard disk. This is an ideal starting unit. Tranquil can add additional low noise, low power HDDs for you, or you can add your own easily and quickly.
<b>Features :</b>
1GB Memory
500GB Green Power HDD
4x spare HDD slots
Server recovery pack
<b>Specification:</b>
Unit dimensions 213 (W) x 221 (D) x 195 (H) - incl feet
Unit construction Enamelled steel (typically >70% recycled materials)
CPU cooling Internal CPU and chipset aluminium heat sink (fan less)
CPU 64 bit ready Intel Atom 330 (2x1.6GHz) Dual Core
Memory 1x DDR2 533/667MHz (up to 2GB)
HDD 1 - 5x 3.5" Western Digital (Green Power) - or user fitted 3.5" SATA2 HDDs
Colour options Satin Black
Front panel Power, Mode and Backup switches, multi-coloured status LEDs and 2x USB2.0
Rear panel 12V DC power in / 4x USB2.0 / 10/100/1000 LAN / eSATA (with Port Multiplier). Desk Lock
Weight Base unit (nett) 6Kg (1x HDD fitted)
Packing box 310 (W) x 320 (D) x 290 (H) (external)
Power supply Universal (50/60Hz - 110/240V) External AC/DC with country specific power cord
HDD support 1 - 5x 3.5 HDD supported (SATA2)
Working temp Maximum 44C ambient
Acoustics ~23dBA (1x HDD)
HDD Cooling Hot swap 8cm Fan, with optimised speed / acoustic control
Mounting options Desk
<b>Power consumption 29W</b> (base unit, with 1x HDD) <i>a bit high</i> [:(]
Software Windows Home Server PP1 pre-installed
Media Pack, with Connector, Restore CDs and Installation DVD
System / Data recovery system included.
http://www.tranquilpc-shop.co.uk/acatal ... -1000.html
Tranquil NAS with Intel Atom 330 & Homeserver
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
