USB/Ethernet/Bluetooth/WiFi/ZigBee/RS232 Relais
Esteban
Post by Esteban »
Relais-Nirvana:
http://www.controlanything.com/Merchant ... e_Code=NCD
Bluetooth:
USB:
Wifi:
Zigbee:
Ciao,
Esteban
Francois
Post by Francois »
Erg leuke bordjes maar stevig aan de prijs! Ik zou eigenlijk wel zoeits willen hebben maar dan wireless met 1 of 2 in/uitgangen en 1 of 2 analoge in/uitgangen. Kan ik her en der in de woning sensoren plaatsten zonder afhankelijk te zijn van kabels.
Francois
Esteban
Post by Esteban »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Francois</i>
<br />Erg leuke bordjes maar stevig aan de prijs!
Hi Francois,
The price for some of these boards is pretty steep indeed, even more with the dollar to euro ratio at the moment! The Wifi cards are to expensive for my taste. But this store has an amazing range of boards and options, I was quite surprised.
Those ZigBee 32 relais boards, (although I have no use for them) are quite interesting and not that expensive. (600$/32=+/-19$ = 15eur per relais)
Francois
Post by Francois »
I just finished my own project built on a DigiBee board (euro 60), a velleman 16 relay board (euro 70) and a home made optocoupler interface (euro 25) this adds up to about 150 euros for 16 outputs, 16 inputs and as a bonus 4 analog inputs. That is different from the ZigBee solution.
If you build a similiar solution for 32 relay outputs it would be 60 euro's for the DigiBee, and 2x 70 euros for the velleman relay boards = 200 euro's /32 = 6.25 euro per relay
Francois
Esteban
Post by Esteban »
You're right Francois. If you can use a wired solution the DigiBee/Velleman combo is a much better deal.
Alexander
Post by Alexander »
can these (http://www.samenkopen.net/action_products/419547) be used with RFXCOM instead of the ones over here?
DJF3
Post by DJF3 »
Esteban,
You have turned off the feature that allows people to send you a personal message through this forum. Can you turn that on or send me an email through this website?
Thanks
DJ
Esteban
Post by Esteban »
Hi DJ,
Indeed it was, I hadn't noticed. Sent you a mail
Ciao,
Esteban
