Hello all,
I received a newsletter from pixmania.com offering a 32GB Solid State disc for 59. I see many price differences for SSD disc and I don't understand why the price differences. What are point to check when buying SSD?
http://www.pixmania.nl/nl/nl/2041668/ar ... srcid=3678
32Gb SSD at Pixmania
- Jeroen Bartels
Search the forum for SSD, i know there have been posts with some more information about different types of SSD, reliability etc.
If you buy it, use it as a gadget not a hard disk replacement. There's a reason why enterprise drives are three times more expensive.
- Jeroen Bartels
OK, that's clear then. Thanx
I guess this is the serie with the 'hickups' it sometimes let you wait a second before it gets the data......
If you want to use an SSD for your valuable data, either wait a little or get yourself one based on SLC NAND flash technology. See also:
http://www.domoticaforum.eu/topic.asp?TOPIC_ID=1556
I have a 64 Gb SSD in my Asus EEE box
Did not had any problem in the last moths..performance is much better that the original 2,5" 5400 disk
it's the Transcend TS64GSSD25S-M (MLC)
