Sollae EZL-400S
Sollae EZL-400S
Postby Digit » Sun May 10, 2009 10:33 pm
Somehow it looks i just have to keep on buying RS232 -> Ethernet devices...
This week i bought a Sollae EZL-400S. Cost: EUR 195. I know, it looks like a lot of money but you get 4 serial ports for it.
Features:
- 10/100Base-T Ethernet, auto MDI/MDX
- Supports IEEE802.11b : PCMCIA Wireless LAN card interface
- RS232 x 4 (up to 115,200bps, DB9-M interface)
- Powerful security function : SSL3.0/TLS1.0, Password
- Supports EAP-MD5
- Supports communication with variety of TCP/UDP hosts(TCP Server/Client, UDP)
- Supports DHCP and PPPoE for xDSL and cable network
- Easy configuration utility via network for Windows OS (ezConfigMP)
- Virtual COM Port Redirector 'ezVSP' for Windows
- Firmware is upgradable through network
Just like the 2 Sollae EZL-200F's i have, this device works very good, no problems yet. You can assign a single IP address and a port for each RS232 port or assign a different IP address to each COM port.
Currently I'm using this device in my office for testing purposes with a new RS232 interface. However, eventually this device will be moved to where the fuse box is; i need 3 RS232 ports there in the near future, so this device is worth the money.
Sollae EZL-400S
Postby Bwired » Sun May 10, 2009 10:47 pm
Nice device!
Handy to put all the rs232 devices in the Fusebox closet.
Question: How much power consumes it?
Sollae EZL-400S
Postby Digit » Sun May 10, 2009 11:00 pm
Right, that will be the final place where i'll put it, the fuse box.
Power consumption is very low; my mobile power monitor (Conrad Powermonitor Pro) is displaying 2.1 W with 1 RS232 device attached. Without any serial device attached it jitters between 2.0 and 2.1. Ofcourse this EZL-400S is powered by an energy efficient power supply :-)
Sollae EZL-400S
Postby TANE » Sun May 10, 2009 11:14 pm
Nice device...
what are you going to connect?
more and more device are using USB.
Sollae EZL-400S
Postby Digit » Sun May 10, 2009 11:27 pm
Oh, just a RS232 device... i need some more time before i can tell you more than just that.
Sollae EZL-400S
Postby r_255 » Mon May 11, 2009 12:01 am
Nice piece of exotic hardware :)
r_255
Sollae EZL-400S
Postby Hetwieg » Mon May 11, 2009 8:46 pm
That wood be nice with a voice modem and a One Wire RS-232 in the (Meterkast)
Hetwieg
Sollae EZL-400S
Postby Willem4ever » Wed Jul 22, 2009 3:41 pm
i received this device yesterday and not so impressed by the Virtual Comport director. ezVSP has too run, but it cannot start as a service. Homeseer is running as a service so I guess I'm out of luck. Anyone has a smart solution for this ?
Willem4ever
Sollae EZL-400S
Postby Digit » Wed Jul 22, 2009 4:34 pm
I don't use ezVSP, i try do everything without drivers as much as i can; so direct TCP/IP.
Sollae EZL-400S
Postby Willem4ever » Wed Jul 22, 2009 4:51 pm
yeah, i figured, can't do that with homeseer. Guess this item needs returning. Very strange they didn't create a proper VCP voor this.
Willem4ever
Sollae EZL-400S
Postby Digit » Wed Jul 22, 2009 5:35 pm
I'm happy with it. Only have 1 port left for new stuff...
Sollae EZL-400S
Postby Willem4ever » Fri Jul 24, 2009 8:14 am
After some googling I found some commercial drivers to work with the EZL-400S and any other terminal server which accepts raw data. [url="http://en.wikipedia.org/wiki/COM_port_redirector"]Here[/url] is the starting point. I'm currently testing Eltima & FabulaTech.(Eltima is more attractively priced) Sofar so good.
Willem4ever
Sollae EZL-400S
Postby Digit » Fri Jul 24, 2009 11:08 pm
One other thing to keep in mind is that i had to reset the EZL-400S when i had a power failure in my office where my domotica server is running. The EZL-400S wasn't affected by this power failure, but after everything was up and running again in the office, it couldn't connect to the EZL-400S because the ports seemed to be still occupied. After power off of the EZL-400S everything worked fine again.
Return to Announcements & News Forum
