Kwikset Smart Code
Noel
Kwikset Smart Code
Post by Noel »
Anyone here ever tested the "Kwikset Smart Code" keyless locks?
http://www.kwikset.com/smartcode/
Henk
Kwikset Smart Code
Post by Henk »
Looks nice although the pincode can easily be compromissed by the neighbours with a binoculair ..... from a security standpoint a weak secure system - with a 4 digit code only 625 different possibilities
Also this lock is based on the American market - you need some serious carpenter work to fit it into a Dutch door.
Henk
Lempens
Kwikset Smart Code
Post by Lempens »
It looks nice when you combine the Smartscan http://www.kwikset.com/SmartSeries/SmartScan.aspx
With a normal electric lock.
When you forget your key's or transmitter, you can still use your finger.
Esteban
Kwikset Smart Code
Post by Esteban »
Another thing to consider with these keypads with soft plastic buttons (I think this lock has those as well) is that with heavy use it quickly becomes aparent which buttons are use for the pin. This because the numbers printed on the keys quickly start to fade/scratch/rub off.
Ciao,
Esteban
Henk
Kwikset Smart Code
Post by Henk »
you should change the code regular so all keys will show sign of wear ...but somebody can put powder on the keys and after opening the door by the homeowner check which keys has been used ... it will limit the number of possibilities. To prevent it wipe clean first all the keys ..
Henk
Snelvuur
Kwikset Smart Code
Post by Snelvuur »
i think a hammer and screwdriver will do just fine too..
