Dear domotica friends,
On your nice domotica forum I believe an item is missing
and I like to introduce that item to you,
although my opinion is hardly objective.
but I will do my best to prevent it being too promotional
CER is a Dutch manufacturer of a product line so called FieldCommander devices.
A FieldCommander is an embedded and fanless linux computer
packaged with some tools and support for several interfaces and communication technologies.
A FieldCommander application is configured basically with 3 tools
- an embedded SQL database
- logic and event handling is configured with the FieldCommander-script tool
- HMI (user interface) with html/php-pages
is supported with a built-in webserver and PHP-server
A FieldCommander device support many different interfaces.
Because this forum is mainly domotica focused I will adress some domotica protocol.
- KNX/EIB; an important domotica technology
Your partner probably likes KNX because the components are available in many colors and designs
from white plastic, alu-like, square, round; glass.. whatever...
and the real estate project development people likes it
because it is currently the only technology that is compatible with the European
domotica standard (European standard Cenelec EN50090 and international standard ISO/IEC 14543-3.)
- EIBnet/IP (the IP-versions of KNX; so now 1 domotica project; including several separated school buildings
can now be easily implemented).
- EnOcean; a wireless technology that operates battery less.
- ZigBee; a wireless technology that allows a meshing network
- Kadex; another wireless technology
- soon X10 support
- DMX512 (a protocol for controlling light equipment, popular in theaters, popgroups, disco's
and also for the growing application area of LED-based lighting)
- support for the many Adam-, Nudam, Idam-modules or how these low cost I/O modules are being
called in your area that support basic input- or output, analog or digital.
So using a device like FieldCommander an engineer can easily setup a complete solution,
for example for a product like a data logger, an access control system
or for implementing a project.
So using a device like FieldCommander you can create a domotica application.
And this has already being done and that application is called FCDomus.
The FCDomus application is available free and even contains the source code.
And if the members of this forum are interested,
I'm even willing to extend the support for the HPDM (Heino Peters Domotica Modules) protocol.
This will support an simple basic domotica application for those HPDM-units
making control and visualization easy
and it will allow the user to extend it with own web- or PHP-pages to create his own application version.
and this proposal even makes integration with the other domotica technologies, like X10 easy.
Just let me know if you like this suggestion....
FieldCommander is not perfect and it can't do everything
just like cars.... many brands and models are required to satisfy everybodies taste and preferences.
So let's skip the idea that 1 brand/type of domotica technology can be the only solution
and I hope you like the idea that a flexible device like the FieldCommander gives
you freedom, freedom to select the technology you like most
and even supports integration of a mix of domotica technologies.
Hopefully I didn't create too much commercial talk while being enthusiastic.
Detailed info can be found on http://www.cer.com.
Also all manuals are available there (when registered)
I'm looking forward for your response and comments.
Ad van den Broek
email: domoticaforum-at-cer-dot-com
FieldCommander
- Snelvuur
- Forum Moderator
- Contact:
FieldCommander
Soon also X10.. i dont want to sound as if i speak for everyone. But most of us use a form of X10 or Xanura for there home automation.
EIB/KNX is usually for a new house, which most people dont have. I am getting a new house, and i'am building in Xanura and not EIB/KNX since the mainstream people are working around xanura/x10 which is more common.
Except for that it might be a nice embedded box with lots of options/ports with little power needs. If its also open source then it might be interesting.
Having a pricelist of items is also a plus
p.s. and it should have been in english, it is!
FieldCommander
Hi Ad,
welcome on this forum! All Home automation (DOMOTICA) information is sure welcome. A good thing that the Fieldcommander eventually is going to support X10, it was your plan also for years ago?
Pieter Knuvers
Pieter Knuvers
FieldCommander
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">
p.s. and it should have been in english.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Agreed - and now I'm curious about what you guys said!
FieldCommander
Hi Pieter,
<br />welkom op het forum! Alle Domotica informatie is zeker welkom.
Mooi dat de fieldcommander nu eindelijk ook X10 gaat ondersteunen, je was dit eigenlijk jaren geleden al van plan toch?
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Yes, you are right,
we wanted to implement X10 already several years ago,
but every installer I mentioned this idea,
is doing his best to stop me,
telling me they are so disappointed with this unreliable Marmitek based powerline technolgy (sorry, their words....)
but nevertheless we are willing to implement it to support the home-users.
For us it is no issue, we are handy implementing protocols and we are even willing to implement support for Heino-Peters-Domotica-Modules
Met vriendelijke domus groet,
FieldCommander
Yes, although traditional "x10" can have a lot of issues, if there are standards like "homeplug" using the AC power line for "reliable" data transmission, we should be able to also use it as a10 2way communication... etc...
Or else, I wouldn't mind using zigbee for most communication. It's mesh design would make it simple to easily cover the entire house even at low power.
- Snelvuur
- Forum Moderator
- Contact:
FieldCommander
Also implement Xanura support, thats real easy (its plain text)
- Snelvuur
- Forum Moderator
- Contact:
FieldCommander
Niknik, in the case of zigbee.. http://www.z-wavealliance.org/modules/i ... =168820736 i'am not to shabby about it yet.
FieldCommander
<br />Niknik, in the case of zigbee.. http://www.z-wavealliance.org/modules/i ... =168820736 i'am not to shabby about it yet.
Thanks for the link, I wasn't aware of that... damn.
