Marmitek DoorGuard400
Snelvuur
Post by Snelvuur »
http://www.marmitek.com/en/catalogus/pr ... roduct=376
A safe feeling now that you always know who is at the door.
Luxurious design; neat looks and provided with a 14cm / 5.5" colour LCD screen. Small, subtle, vandalism-resistant doorbell camera.
Always perfect sound and clear picture, also in the dark.
Easy installation and the camera fits on any narrow doorframe. No sawing or chipping required.
You install the small doorbell camera onto the doorframe and connect the wires. As soon as a visitor rings your doorbell, the picture will get displayed on the home monitor. This way you see who is at the door before you open it (or pretend you’re not at home). To speak to the caller, you simply press on the speech button. If you have also installed an electric door opener, you can open the door with the help of the monitor. If you have installed more monitors (optionally available) at home (maximum 3 extra), then you can also talk among each other (intercom).
Good looking doorcamera module, much more slim then the one I got.
To bad for the CMOS camera, why is Marmitek always doing this :-)
Resolution: 352x288 Pixels
Camera: CMOS
Lens en angle: F3.6 mm 78°
Light sensitivity: 0,1 LUX
Night vision: 4 bright LEDs
Sound: Built-in microphone en loudspeaker
Material: Impact-resistant casing
Dimensions: 58,5x134,5x40mm
Snelvuur
Post by Snelvuur »
Still the setup with the siemens phone + dooropener/webcam looks the nicest at the moment.
Yep looks great and very nice functionalities, much more functions then the Dutch GSM Deurbel and cheaper, but still no camera :-)
And we have a price for the Siemens Gigaset HC450
http://www.allesvoormijntelefoon.nl/pro ... cts_id=332
and the page special made by Siemens for the product range.
http://www.easy-welcome.com
Snelvuur
Post by Snelvuur »
Well thats not too expensive, but how about that automatic door opener?
Peterpc
Post by Peterpc »
DJF3
Post by DJF3 »
For sending the images, do they use the same frequency as all the other Marmitek video senders? In that case it wouldn't work for me. I have 3 WiFi Accesspoints in my house that interfere massively with the video-sender frequencies.
DJ
Peterpc
Post by Peterpc »
the camera is connected with a cable.
4 wires, normal audio and video so you can use the SD MemoryCam2
to record who is at your door!
Before buying this camera check the quality first in different light environment. I think it will not be very good!
Peterpc
Post by Peterpc »
The camera has very good light compensation.
