New firmware version released. Looks like they have been working on the dect part.
http://tweakers.net/meuktracker/22950/f ... 40481.html
DECT:
NEW read podcasts with FRITZ!Fon MT-D/MT-F
NEW internet radio with FRITZ!Fon MT-D/MT-F
Improved DECT radio transmission
Listen to current answering machines messages while they are being recorded
New ringtones
New menu options for HD-test samples
Improved editing of contacts
Integrated babyfon and room surveillance
Big watch as screen saver on standby screen
Set-up alarm clock on MT-D/MT-F
Activate or deactivate existing call forwarding via MT-D/MT-F
Improved contact search (vanity)
Internet:
NEW: Online-Monitor informs about internet connection, data transfer and online time
Option to disconnect internet connection manually (expert mode)
Removed PPPoE pass through
System:
NEW advanced energy monitor to check temperature, memory- and cpu load
improved remote access and WLAN connectivity for iPhone, Nokia E71 and Android devices
Extended TR-064-interface
Improved stability
Removed possibility to configure separate LANs for the ethernet ports in user interface
Telephony:
Multiple online contact lists supported
Automatically delete message answering machine messages after forwarding via eMail (expert mode)
Improved wizards for "telephony devices" and "numbers"
Transition from combined fixed line and DSL connection to All-IP connection simplified
Improved fax interoperability (T.38)
Improved audio quality (MOS)
USB/NAS:
Display available USB storage space in the USB device overview
Display technical detail information about USB storage devices in the USB device overview (mouseover)
Improved USB performance
Optimised power saving options with Samsung, Western Digital and Seagate hard drives
USB:
Longer passwords for FTP-/network memory (NAS)
Mediaserver: improved performance during boot of FRITZ!Box with activated media server
Mediaserver: improved compatibility with various UPnP-clients
Online-memory: optimised up- and downloads
WLAN:
New WLAN pages
Fixed crash while changing WEP encryption settings
WLAN interoperability with various WLAN clients improved
Performance and stability of WDS connections using 802.11N improved
Improved automatic channel selection
Faster availability of the WLAN module after changes in the user interface
Fritzbox Fon WLAN 7270 54.04.81
** edwin **
Re: New firmware 54.04.81 Fritzbox 7270
Has anyone tried this firmware yet, in combination with Siemens Gigasets as the previous version sucked for those.
Also wondering if this will work with the HS plugin which is critical functionality in my setup....
Evja
Evja
Running this version since last week.
All is working fine..much better including better support for Siemens.
Planning on using this as a basis for a freetz firmware in combination with openvpn and a more secure ftp.
Which siemens handsets do you use? C47 by any chance?
I'm running with this firmware for two days now without any problems. I've not tested all Gigaset phone options (like call transfer to other handset), but answering machine and missed call notification are working again (envelop symbol is blinking).
I'm using C59H and 4000micro handsets.
** Maurice **
No crackling anymore with the C47? Here that's the only handset that crackles, no matter the distance or other equipment.
I never had this problem with my C47
I think this is C47 firmware related.
What a coïncedence, AVM released the IPv6 Lab-version, based on .81. Now the C47 crackles much less if not at all. Nevertheless going to mail siemens to ask if the handset itself can be updated and if so, how.
Re: Fritzbox Fon WLAN 7270 54.04.81
It is working OK over here with Siemens C47 and C14 phones. The menu items are now also translated into Englisg with the exception of the 'Hauptmenu'. The envelope is working on both phones and I even found out (do not know whether this was the case with the previous version) I can browse the menu and phonebook on the C14 using the 2,4,5,6,8 keys where 2 is up, 8 is down, 4 is left, 6 is right and 5 is OK.
