AXA Remote Ventilation RV2900, Window opener
Postby Henk » Mon Mar 23, 2009 1:05 pm
Thanks for your suggestions ... but replacing the IR circuit is not that easy .... it is coded IR so very hard to crack so you will need the AXA remote control
Henk
Henk
Postby Fantic » Mon Mar 23, 2009 6:54 pm
Maybe this type of solutions is just what the IPPower is made for?
Regards, Maarten.
Fantic
Postby Rebel » Mon Mar 23, 2009 7:42 pm
Nope thats no possible, the IR-cirquit is integrated in the "overload" of the motor to detect the full open of close position of the window. There are no switches for and it stop the motor by a obstruction.
By the way, i have it working with a Marmitek SW10, two Smitt relais and placed the IR led in the housing of the AXA. The remote is placed on the wall, for local operation.
Rebel
Postby Fantic » Mon Mar 23, 2009 11:00 pm
Not really what I meant, I meant using the IPPower for controlling the remote buttons. This instead of ZAX or SW10 and separate relais.
Regards, Maarten.
Fantic
Postby TANE » Mon Mar 23, 2009 11:06 pm
I don't know any thing about coded IR.
Is it possible to capture the code using Irtrans or any other remote like Pronto?
Postby Henk » Tue Mar 24, 2009 9:55 am
Rebel/Maarten
Did you remove the 4 AA batteries and replaced is by an external power supply ... if so what voltage and the central pin/bus of the connector has the plus voltage ?
Henk
Henk
Postby LostDreamer » Tue Apr 28, 2009 3:09 pm
Does anyone know to what range this remote is working?
ie. If i solder wires to the remote, and hang the remote on 1 side of the room, can it still operate the window +/- 6 meter from there?
ps. Perhaps handy for someone:
I'm using the VM110 / K8055 from velleman.be (which has 8 dig outputs) to controll a few remotes that use secure IR.
The card costs +/- 50 euro's and has 8 dig outputs, 5 inputs, 2 analoge inputs and 2 analoge outputs (0-5 V).
Don't know what kind of relais others are using, but I think this is one of the cheaper ones out there....
LostDreamer
Re: AXA Remote Ventilation RV2900, Window opener
Postby Irritanterik » Sun Feb 03, 2013 8:01 pm
Just found this short press release: http://expomatch.bouwbeurs.nl/exhibitor/News/12362 (or search for AXA on bouwbeurs.nl)
Nu ook bedienbaar via:
- smartphone
- tablet
- PC
- een vaste wandknop
Anyone planning a visit to this bouwbeurs? Sounds like interfacing with a AXA Remote will be supported!
Irritanterik
Postby raymonvdm » Wed Mar 06, 2013 9:52 pm
I currently own two "AXA Remote 2.0" modules these are both equipped with there own remote
I`m currently pending on a solution on how to remotely control these (I will start testing with my logitech 525 or 900)
https://s3-eu-west-1.amazonaws.com/expo ... /43070.pdf
raymonvdm
Postby wjdevisser » Tue Apr 16, 2013 3:13 pm
The infra-red signal of the remote control is aes256 encripted. A much easier way of operating the window device is by putting a signal in one of the two connection ports.
The Axa Remote 2.0 is equipped with two RJ25 connection ports. This makes it possible to operate your window from distance by computer or home-automation-system. Possible commands are: open / close / stop. Also the status of the window can be requested (window is opened / closed). Also an adapter can be fitted in the port (as alternative to batteries).
The RJ25 connection has 6 wires/contacts, the wires have the following function:
• Port 1: +
• Port 2: -
• Port 3: Data
• Port 4: Data
• Port 5: -
• Port 6 +
The cord is symmetrical, so it does not matter how the plug on the cable is placed.
Contact 1, 2, 5 and 6 are for supplying power to the Remote window device (5-10 volts) .
Wire 3 and 4 are identical, and meant for data transfer in the two directions.
Example: control window-unit by computer:
What do you need for computer control:
1. Computer with USB port
2. Software program like HyperTerminal (or similar programs Freeware), Data transfer: 19200 BPS, 8 data bit
3. Connection cable consisting of: USB to UART TTL Cable + print with a TTL converter LIN (Microchip MCP 2003)+ 2x Resistor 3K3 (3300 ohm) serial connected on chip + RJ25 cable connector
4. To apply the UART-USB cable, you need a driver
5. AXA Remote 2.0 Window device
wjdevisser
Postby Digit » Tue Apr 16, 2013 11:02 pm
Can I also use this for windows of approx. 120 x 120 cm, so-called "kiep/kantel ramen" with the hinge (scharnier) @ the bottom ?
And if I understand correctly, if I can get a TTL signal near the AXA remote, all I need to connect to the RJ25 connector is a MCP2003 + some resistors?
MCP203 is available in DIP so that should be doable ;)
Cause the only acceptable solution for me would be to do this wireless (Wifi, cause I don't have a computer within 5m (USB) range of the windows...)
Postby GertK » Wed Apr 17, 2013 12:44 am
I asked AXA and got a PDF with information. Can someone help me to post it here ?
GertK
Postby Bwired » Thu Apr 18, 2013 10:16 pm
Here is the Axa Remote 2.0 Domotica connect manual
http://files.domoticaforum.eu/index.php?cam=/Axa
Thanks to GertK and Axa :)
Postby Irritanterik » Fri Apr 19, 2013 11:16 pm
Thank Axa for sharing this documentation! This looks workable.
Fortunately I can easily get cables near my window.
Irritanterik
Postby raymonvdm » Thu Jul 11, 2013 1:40 pm
I just found this topic again and want to do something with it. However i`m not yet understanding what i need to order to get it to work. I have two of these units in the living room.
Can somebody tell me what i need to order?
- USB to TTL converter ? http://link.marktplaats.nl/693684955
- Resistors 3K3 (I have them in stock)
- RS25 converter board with Microchip MCP 2003 (where to buy?)
raymonvdm
PreviousNext
Return to Announcements & News Forum
cron
