Although, not really automation.. there still fun the stand alone ones.
This weather clock provides the data you need to plan your day—including weather forecast, precise Atomic time, day, indoor temperature and outdoor temperature with trend indicator. Instead of displaying all information at the same time, this smart weather clock uses motion sensor technology to detect how close you are to the device before displaying select information. The current time, day and weather forecast display in large digits and icons when you are far away from the weather clock. As you approach the unit, the Weather In Motion switches to showing the indoor and outdoor temperature readings, while the time and weather forecast icons automatically reduce in size. You can also set to auto “scroll” mode and the display will smoothly shift the information every five seconds.
Oregon weather new model bar200
Jump to
- Forum matters
- ↳ News Forum
- Hardware Forum (English)
- ↳ Z-Wave Forum
- ↳ Fibaro
- ↳ Plugwise Forum
- ↳ Gadgets Forum
- ↳ Visonic Alarm systems
- ↳ LEDS, DMX & Lights Forum
- ↳ Opentherm Gateway Forum
- ↳ 1-Wire Forum
- ↳ PLCBUS Forum
- ↳ Smart Metering Forum
- ↳ ZigBee Forum
- ↳ Toon news and information
- ↳ Manuals/tutorials
- ↳ Toon Apps
- ↳ Toon Rooting
- ↳ Toon Hardware
- ↳ Toon Firmware
- ↳ Toon external control
- ↳ Toon miscellaneous
- ↳ Toon software development
- Software Forum (English)
- ↳ Announcements & News
- ↳ Linux Forum
- ↳ Windows Forum
- ↳ DomotiGa Forum
- ↳ OpenHAB Forum
- ↳ MQTT & Node.js
- Projects Forum (English)
- ↳ Home Automation Projects
- ↳ Bwired Forum
- ↳ Homeseer algemeen Forum
- ↳ Homeseer Scripts Forum
- ↳ Homeseer HStouch Forum
- ↳ Homeseer Plugins Forum
- Other (English)
- ↳ Off Topic
- ↳ Downloads & Links Forum
- ↳ Domoticaboek Heino Peters
- ↳ Dealers Corner
- ↳ Test
