http://www.thirstylight.com/
The Thirsty Light™ is a convenient digital plant moisture sensor designed to be unobtrusive when left in the soil of a plant where it continuously monitors conditions, testing the moisture level once per second. The Thirsty Light blinks a LED light to alert the user when its time to water. With the Thirsty Light™, you will never have to guess when your plants need watering.
Now if we could only monitor this from a pc somehow..
Thirstylight
Thirstylight
Once a second ??? Pff...
My wife does it once a week!
Thirstylight
Hi Eric,
Have you ever found such sensor with wireless 433.92MHz option?
There are some but very expensive.
Erwin
Erwin
- Snelvuur
- Forum Moderator
- Contact:
Thirstylight
Well you can make your own..
1x Weerstand 330
1x Weerstand 1k
1x Weerstand 100k
1x LED
1x Transistor BC 547
You could use instead of a led a visionic water sensor perhaps? Or any of the "on/off" circuit sensors of visionic. (http://www.waakzaamwonen.nl/catalog/pro ... r-detector)
And ofcourse, you can attach some x10 device from marmitek, if you want it at the mhz you want.
1x Weerstand 330
1x Weerstand 1k
1x Weerstand 100k
1x LED
- Snelvuur
- Forum Moderator
- Contact:
Thirstylight
http://www.easybloom.com/buy/overview.html
to check if you got a good place to plant your seeds
