Marmitek new CM15 computer interface
http://www.marmitek.com/en/catalogus/su ... ubgroep=83 English
http://www.marmitek.com/nl/catalogus/su ... ubgroep=83 Dutch
- With new activeHomePro software!
- This is the Pro-version of the CM11.
More programming possibilities because of conditional macros. For instance; the simulation of presence is executed only when your alarm is activated.
- More memory; possibility to use approximately 1.400 macros/timers.
- Ready built X-10 RF transmitter and X-10 transceiver (like the TM13) for specific or all home codes.
- User friendly software for beginners, with numerous extension possibilities for the experienced X-10 user.
- Software in English.
- Can be placed out of sight because of the supplied 1 metre power cord.
- See table for similarities and differences CM11 - CM15Pro.
- See www.activehomepro.eu for more information and free updates!
Signals used
With extras like extended codes, conditional macros and a built in transceiver, this product offers the functionality of a computer interface and a transceiver in one. In combination with the CM15Pro you only need receivers in order to control your lighting and equipment. With your computer you can program whatever you like. Switching on your lights at set or varying times (intelligent presence simulation), creating a home movie theatre, switching your outside lighting or having a fresh pot of coffee ready when you are woken up by the atmospheric lighting in your bedroom. Once everything is set according to your wishes, you can enter this into the memory of the CM15Pro and turn off your computer. You can also pre-set the CM15Pro for use in another house.
Signals used
- b_weijenberg
is it possible to disable the RF transmitter and/or receiver?
You can select for which housecodes the CM15 will act as an tranceiver.
You can also select if a X-10 code to send has to be RF or PLC.
Is it "compatible" with CM11 old software? or does it require special drivers, etc?
It has completly new software: ActiveHomePro.
It also has different drivers.
See http://www.activehomepro.eu/
What I meant was: is it easy to develop for using "custom" software? in java, VB, C#, etc?
You can ask Marmitek if they have an SDK.
- Snelvuur
I presume it just works as the old one, but with some extra's...
I have asked Marmited for the CM15 SDK ... but they only have an Active Home SDK which is unfortunately not the same.
Ive also heard that the price of the cm15pro is the same as the cm11.
I'm curious if someone got this cm15pro working in homeseer.
No SDK.
You need to develop to connect USB port with the Windows API, and implement the protocol
David Rodriguez
Multidomo Networks
www.multidomo.com
David Rodriguez
Multidomo Networks
www.multidomo.com
Does anyone know if the CM15 is a native USB device? Or does it just uses the same USB "serial port" (which is a lot more likely)?
It has a native USB driver, not a Serial-USB converter like CM11
David Rodriguez
Multidomo Networks
www.multidomo.com
David Rodriguez
Multidomo Networks
www.multidomo.com
Guess I won't be upgrading my CM11 to the CM15 after all...
Gracias David.
Gracias David.
Does anyone know if there will be a Homeseer plugin, which will support all the new features off CM15pro ??? Or is it compatible with another one ??
/RdP
/RdP
