Today received a message from my Roomba dealer about the availability (2nd half of 2013) of a Roomba add-on to remotely control it via WiFi. Android / iPhone apps will be available and it mentions there will be a json-API available as well.
If I understood everything correctly a webserver is run from the device allowing you to contact it and make settings/schedules etc. Don't know if it will always use the ThinClean servers or that these just serve as a dynDNS substitute.
You can read the website and pdf-glossary at http://www.thinkingcleaner.com/
Pricing is preliminary set at 99euro.
(I have no connections with ThinkingCleaner or iRoomba-dealers apart from being a satisfied customer)
Roomba WiFi control
Re: Roomba WiFi control
You can signin if you are intrested with the dutch Cyberhouse website
This is a Wifi option including a new top housing, so this looks like a very solid wifi option for the Roomba.
You can subscribe for it at the bottom of page.
cyberhuis.info/ThinkingCleaner/?utm_sou ... -215556053
