[Node-RED] Some Examples
Forum about MQTT, machine-to-machine (M2M), "Internet of Things" and Node.js
Moderators: Digit, Rene, Willem4ever, Bwired
Postby raymonvdm » Tue Apr 12, 2016 2:20 pm
I`m using Node-Red for some time now and have created some usage functions. But not all are working yet
MQTT to Domoticz (works)
Note: The data is send by OTmonitor to my MQTT broker and picked up by Node-RED to send it to Domoticz JSON interface
[{"id":"48aef6ac.596238","type":"mqtt-broker","z":"","broker":"mqtt.domain.nl","port":"1883","clientid":"","usetls":false,"verifyservercert":true,"compatmode":true,"keepalive":"15","cleansession":true,"willTopic":"","willQos":"0","willRetain":null,"willPayload":"","birthTopic":"","birthQos":"0","birthRetain":null,"birthPayload":""},{"id":"c960d3e9.369f3","type":"mqtt in","z":"15db5742.ea24a9","name":"","topic":"events/central_heating/otmonitor/boilerwatertemperature","broker":"48aef6ac.596238","x":324,"y":134,"wires":[["77efb6b9.881048"]]},{"id":"84a421c5.7b5be","type":"debug","z":"15db5742.ea24a9","name":"","active":false,"console":"false","complete":"payload","x":1175,"y":163,"wires":[]},{"id":"e1da43c7.1e25c","type":"debug","z":"15db5742.ea24a9","name":"","active":false,"console":"false","complete":"false","x":987,"y":30,"wires":[]},{"id":"7a8e615d.8571a","type":"http request","z":"15db5742.ea24a9","name":"IDX7","method":"POST","ret":"txt","url":"http://192.168.110.64:8080/json.htm?type=command&param=udevice&nvalue=0&idx=7&svalue={{payload}}","x":919,"y":164,"wires":[["84a421c5.7b5be"]]},{"id":"77efb6b9.881048","type":"json","z":"15db5742.ea24a9","name":"","x":701,"y":133,"wires":[["e1da43c7.1e25c","7a8e615d.8571a"]]}]
MySQL to Domoticz (issues)
[{"id":"ba8f12c8.4570f","type":"MySQLdatabase","z":"","host":"192.168.110.200","port":"3306","db":"database","tz":""},{"id":"675893bb.98a76c","type":"debug","z":"350bd099.caf43","name":"","active":false,"console":"false","complete":"payload","x":1160,"y":183,"wires":[]},{"id":"60d1442d.9f2ebc","type":"debug","z":"350bd099.caf43","name":"","active":false,"console":"false","complete":"false","x":1143,"y":69,"wires":[]},{"id":"936ee025.6c912","type":"http request","z":"350bd099.caf43","name":"IDX20","method":"POST","ret":"txt","url":"http://192.168.110.64:8080/json.htm?type=command&param=udevice&nvalue=0&idx=20&svalue={{payload}}","x":904,"y":156,"wires":[["675893bb.98a76c"]]},{"id":"cb1dd684.34e228","type":"json","z":"350bd099.caf43","name":"","x":681,"y":79,"wires":[["60d1442d.9f2ebc","936ee025.6c912"]]},{"id":"eea128b5.115ed8","type":"mysql","z":"350bd099.caf43","mydb":"ba8f12c8.4570f","name":"database","x":433,"y":155,"wires":[["cb1dd684.34e228","38f0f2dd.c70f0e"]]},{"id":"5b0aa461.a4f55c","type":"function","z":"350bd099.caf43","name":"Select","func":"msg.topic = \"SELECT value as '' FROM splog WHERE pdu = '4901' AND register = 'omkwht' AND channel = '1' ORDER BY id DESC LIMIT 1\";\nreturn msg;","outputs":1,"noerr":0,"x":270,"y":155,"wires":[["eea128b5.115ed8"]]},{"id":"5ed73170.a128d","type":"http in","z":"350bd099.caf43","name":"","url":"/pdudata","method":"get","swaggerDoc":"","x":97,"y":155,"wires":[["5b0aa461.a4f55c"]]},{"id":"38f0f2dd.c70f0e","type":"http response","z":"350bd099.caf43","name":"","x":666,"y":230,"wires":[]}]
The problem is that the flow gives me the following output and not only the value
[{"":6531}]
"payload": 18.19,
"payload": [ { "": 6531 } ],
raymonvdm
Re: [Node-RED] Some Examples
Postby raymonvdm » Tue Apr 12, 2016 4:59 pm
I have added two change nodes, which seem to do the trick
msg.payload
Search for [{"value":
Replace with
and
msg.payload
Search for }]
Replace with
But now i need to find a way to add 3 extra digits behind the payload to fix a issue with domotigz
raymonvdm
Return to MQTT & Node.js
