Toon firmware: issues (and solutions)
- Starting Member
Re: Toon firmware: issues (and solutions)
Hallo,
Please a little question about how to use, in specific to run the update _script, for all those they want to update there Toon, and so as i don't now how to use this script after pasting it to Toon?
So how to command the running of this file/script: update-rooted.sh?
Thanks in advance.
Thanks in advance.
You can start the script with
sh update-rooted.sh
Hello Thehognl,
i've treid your script, but receive an error:
grep: 4.11.6: No such file or directory
Unable to determine your current running version!
DEBUG information:
base-qb2-ene - 4.9.23-1183-1
base-qb2-uni - 4.11.6-1205-0
END DEBUG information
My toon has currectly 4.11.6.
Is there something i can do?
Thanks.
Jos
EDIT: Found the problem, i copy a base from 4.11.6 from another toon and did the upgrade. I now removed the old 4.9.23 with opkg remove base-qb2-ene and now the script is working. The update to 4.12.0 is now busy. Thanks.
DEBUG information:
Thanks.
Jos
i gave it a try but get this error "Could not enable VPN in a normal reasonable time.. exiting!" debug information ect.
VPN is open ?? any idea's (it looks that vpn isn't open)
Correct. Somehow you had the two base versions installed (ene and uni). That should never happen. You probably did a manual install/update with opkg I guess beforejozg wrote: EDIT: Found the problem, i copy a base from 4.11.6 from another toon and did the upgrade. I now removed the old 4.9.23 with opkg remove base-qb2-ene and now the script is working. The update to 4.12.0 is now busy. Thanks.
Please post the debug information.Demif wrote:i gave it a try but get this error "Could not enable VPN in a normal reasonable time.. exiting!" debug information ect.
This means that the script can not determine a proper vpn connection.
Can you try 'ping feed.hae.int' ?
Ok the information
ping = 64 bytes from 127.0.0.1: seq=0 ttl=64 time=1.74 ms ect ect.
log
DEBUG information:
192.xxx.x.x/24 dev wlan0 src 192.xxx.x.xx
default via 192.xxx.x.x dev wlan0
# <persistent /etc/hosts content can be added to /etc/hosts.template file>
127.0.0.1 localhost.localdomain localhost eneco-001-265919
127.0.0.1 feed.hae.int feed
i have seen in an earlier attempt something like" Kill all openvnp"
thanks
log
DEBUG information:
thanks
:~# ./update-rooted.sh
Please be advised that running this script is to your own risk!
Version: 1.2 - ThehogNL - 3-3-2018
You are currently running version 4.11.6
Available versions:
1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.9.15 2.9.26 3.0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.3.8 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.10.6 4.11.6 4.12.0 4.13.6
Which version do you want to upgrade to?
4.13.6
./update-rooted.sh: line 79: 6: not found
Smartass.. 4.13.6 is not a upgrade for 4.11.6!
i think a little bug
EDIT:
its not a bug, i copied and paste it in the terminal i guess line 79 is not copied properly. i copied the script using Filezilla and its working! thanks!
Your VPN is not working. If it works it will overwrite the 127.0.0.1 feed.hae.int of /etc/hosts to point to the correct IP address.Demif wrote:Ok the information
log
DEBUG information:
thanks
Try running the openvpn manually with
/usr/sbin/openvpn --config /etc/openvpn/vpn.conf
Post the output.
there is a problem !
the result after starting vpn
Tue Mar 6 17:40:12 2018 DEPRECATED OPTION: --tls-remote, please update your configuration
Tue Mar 6 17:40:12 2018 OpenVPN 2.3.11 arm-hae-linux-gnueabi [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Nov 30 2016
Tue Mar 6 17:40:12 2018 library versions: OpenSSL 1.0.2h 3 May 2016, LZO 1.08
Tue Mar 6 17:40:12 2018 MANAGEMENT: Socket bind failed on local address [AF_INET]127.0.0.1:8000: Address already in use
Tue Mar 6 17:40:12 2018 Exiting due to fatal error
if i read this, a adress conflict?
There is already a (not working) openvpn running.
Strange, because if openvpn is running but not working correctly the Toon software will restart it automatically.
Is there a reason you have openvpn still running? The script will start it temporarily for the update to work and stop it again.
Only reason to have the openvpn running is when you have a working subscription, but then you would already have the update
To shutdown the current openvpn:
- check your /etc/inittab (there should be a # in front of the openvpn config line)
- if there was NOT a #, put it there, save the file and restart your Toon
- if there was a # already, check with "ps w | grep openvpn" if it is indeed still running, then type "killall -9 openvpn" and check with "ps w | grep openvpn" again if it is indeed killed
If there is no openvpn running but you are still getting the 'already in use' message, then private message me a complete "ps w" output
I just read on the toon forum that 4.13 is released.
Did they skipped 4.12?
@TheHogNL
When I want to use your new scrip to upgrade my Toon from 4.11 to 4.13 can this directly?
Do I also need to uninstall some software? and do I need to add something on my Toon for receiving new package and do I need to open the vpn first and reboot and than start the scrip and wait.
Or just start the scrip and wait and everything is installed?
Thanks
@TheHogNL
Thanks
4.12.0 was only targeted at Warmtewinner customers to fix a bug. No other new functionality in that releasemichel30 wrote:I just read on the toon forum that 4.13 is released.Did they skipped 4.12?
Ah, okay thanks for the information.
In the scrip it says:
But on the forum site it says: Software update 4.13.7
Maybe a new scrip is needed? with 4.13.7 in it and not 4.13.6 ?
Available versions:
4.13.7 is indeed just released, just after I created the script. I will update the script to also add newer versions. But for just edit line 21 and add 4.13.7 to the end of it. Would not be hard I guessmichel30 wrote:
