Rooting Toon (or boxx)
glsf91
Re: Rooting Toon (or boxx)
Post by glsf91 »
iMars wrote:Hi all,
This weekend I'd like to work on it, I haven't opened it yet, so I don't know the currect software version and so on.
You don't have to open it to get the software version. You can find it in the settings under software.
iMars
Post by iMars »
marcelr wrote:@iMars:
You point at a document that comprehensively describes the steps to take to get into a Toon. So yes, this is the way to go.
Ok, thanks! I'll go from there :)
Last question before i'll begin, my Toon has now software version 3.6.3 and it's asking me to upgrade him to 4.10.6. Shall I do that? Or not?
I'd root it first, and then upgrade. Saves some hassle in rooting.
iMars
Post by iMars »
Ok, done everything till the moment you have to reboot...
Instead of that, I've read that you can also use the reset button...
I get this:
usb 2-1: SerialNumber: 00e04c000001
 (print_boot_msg)
Please wait: booting... (print_boot_msg)
* Kernel            2.6.36-R10-h27 (print_boot_msg)
* Firmware          qb2/ene/4.10.6-1196-0 (print_boot_msg)
* Hostname          eneco-001-016676 (print_boot_msg)
==DriverVersion: v2.6.6.0.20120405==
MAC Address from efuse= 6c-71-d9-3c-42-48
usbcore: registered new interface driver r871x_usb_drv
usbcore: registered new interface driver rt2870
Loading iptables settings: iptables.
 (print_boot_msg)
Configuring network interfaces...  (print_boot_msg)
Running 'ifup -a' in the foreground (ifup-fg)
ifup: interface lo already configured
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:10, irq=-1)
udhcpc: started, v1.27.2
udhcpc: sending discover
Lease failing, starting in bg: udhcpc -b -R -i eth0 -A 5 -p /var/run/udhcpc.eth0.pid -H eneco-001-016676
udhcpc: option -h NAME is deprecated, use -x hostname:NAME
udhcpc: no lease, failing
Successfully initialized wpa_supplicant
rfkill: Cannot get wiphy information
ioctl[SIOCSIWAP]: Operation not permitted
Lease failing, already running in bg: udhcpc -b -R -i eth0 -A 5 -p /var/run/udhcpc.eth0.pid -H eneco-001-016676
udhcpc: no lease, forking to background
Lease failing, starting in bg: udhcpc -b -R -i wlan0 -A 5 -p /var/run/udhcpc.wlan0.pid -H eneco-001-016676
* Wired (eth0)      00:0f:11:01:f6:0f  [No IP from DHCP Server] (print_boot_msg)
* Wireless (wlan0)  6c:71:d9:3c:42:48  [No IP from DHCP Server] (print_boot_msg)
Setting up IP spoofing protection: rp_filter.
udhcpc: sending select for 10.0.0.110
udhcpc: lease of 10.0.0.110 obtained, lease time 600
/etc/udhcpc.d/50default: Adding DNS 10.0.0.1
/etc/udhcpc.d/50default: Adding DNS 84.116.46.21
INIT: Entering runlevel: 5dding
/etc/udhcpc.d/70prepend-google-pub-dns: Prepending DNS 8.8.8.8 (skip with /mnt/persist/udhcpc-skip-prepend-google-pub-dns)
Starting syslogd/klogd: done
HCBv2 apps started via runlevels, performing 'addstartables && reload && init 5 or 5'.
HCBv2 adding: comm eventmgr kpi pwrusage scsync smartplug thermstat usermsg weather bxtproxy config log rrd watchdog hue p1 zwave lighttpd.
HCBv2 startables unchanged, not writing /etc/inittab.
getty: applet not found
imx-fb imx-fb.0: PreserveUBootFramebuffer(4): xres=800, yres=480 [do _update_lcdc]
INIT: Id "gett" respawning too fast: disabled for 5 minutes
r8711_wx_set_scan: IW_SCAN_THIS_ESSID, ssid=iRouter, len=7
I've got bootloader: U-Boot 2010.09-R8, so that works fine...
iMars
Post by iMars »
Frustrating I can't edit my post, as it isn't posted yet...
This is what I get whilst reboot:
/ # reboot
WARNING: could not determine runlevel - doing soft reboot
  (it's better to use shutdown instead of reboot from the command line)
shutdown: timeout opening/writing control channel /dev/initctl
init: timeout opening/writing control channel /dev/initctl
/ # shutdown
Usage:    shutdown [-akrhHPfnc] [-t secs] time [warning message]
                  -a:      use /etc/shutdown.allow
                  -k:      don't really shutdown, only warn.
                  -r:      reboot after shutdown.
                  -h:      halt after shutdown.
                  -P:      halt action is to turn off power.
                  -H:      halt action is to just halt.
                  -f:      do a 'fast' reboot (skip fsck).
                  -F:      Force fsck on reboot.
                  -n:      do not go through "init" but go down real fast.
                  -c:      cancel a running shutdown.
                  -t secs: delay between warning and kill signal.
                  ** the "time" argument is mandatory! (try "now") **
/ # shutdown -r now
/ # shutdown -rf now
/ # cat /etc/inittab
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
# HCBv2 static stuff
#ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
qtqt:245:respawn:/usr/bin/startqt >/dev/null 2>&1
gett:235:respawn:/sbin/getty -L 115200 ttymxc0 vt102
# WARNING: auto-managed by '/etc/init.d/HCBv2 inittabwrap' with '/HCBv2/etc/start.d/*'
#          lines containing 'inittabwrap' will be removed automagically.
netc:235:respawn:/etc/init.d/HCBv2 inittabwrap hcb_netcon
comm:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_comm
even:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_eventmgr
kpik:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_kpi
pwru:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_pwrusage
scsy:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_scsync
smar:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_smartplug
ther:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_thermstat
user:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_usermsg
weat:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_weather
bxtp:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_bxtproxy
conf:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_config
logl:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_log
rrdr:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_rrd
watc:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_watchdog
hueh:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_hue
p1p1:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_p1
zwav:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_zwave
ligh:345:respawn:/etc/init.d/HCBv2 inittabwrap lighttpd
# end of 'inittabwrap' section.
/ # cat /etc/passwd
root::0:0:root:/root:/bin/sh
daemon:*:1:1:daemon:/usr/sbin:/bin/sh
bin:*:2:2:bin:/bin:/bin/sh
sys:*:3:3:sys:/dev:/bin/sh
sync:*:4:65534:sync:/bin:/bin/sync
games:*:5:60:games:/usr/games:/bin/sh
man:*:6:12:man:/var/cache/man:/bin/sh
lp:*:7:7:lp:/var/spool/lpd:/bin/sh
mail:*:8:8:mail:/var/mail:/bin/sh
News:*:9:9:News:/var/spool/News:/bin/sh
uucp:*:10:10:uucp:/var/spool/uucp:/bin/sh
proxy:*:13:13:proxy:/bin:/bin/sh
www-data:*:33:33:www-data:/var/www:/bin/sh
backup:*:34:34:backup:/var/backups:/bin/sh
list:*:38:38:Mailing List Manager:/var/list:/bin/sh
irc:*:39:39:ircd:/var/run/ircd:/bin/sh
gnats:*:41:41:Gnats Bug-Reporting System (admin):/var/lib/gnats:/bin/sh
nobody:*:65534:65534:nobody:/nonexistent:/bin/sh
If you can get in through dropbear (ssh) upload the busybox packages from this forum to toon and install.
You can find them here:
viewtopic.php?f=87&t=11230&start=315#p84518
Then your gettys work again :-)
and your password manager too :-)
iMars
Post by iMars »
marcelr wrote:If you can get in through dropbear (ssh) upload the busybox packages from this forum to toon and install.
How do I download it to Toon? In the first shell there isn't a network connection... or is it possible to get it via USB drive?
Do you have dropbear working on your toon?
If so, you also have scp, which can transfer files from one computer to another and back.
You will need to connect your toon to a network (wired or wireless).
iMars
Post by iMars »
marcelr wrote:Do you have dropbear working on your toon?
I have no network after “run boot_nand”...
I’ll try tomorrow wired on my switch
iMars
Post by iMars »
Made some great steps today. I used my linux skills and found out that there was no connection because the link was down.
So I brought up the interface, added an ip address and a route:
/ # ip
BusyBox v1.27.2 (2017-10-03 14:20:01 CEST) multi-call binary.
Usage: ip [OPTIONS] address|route|link|tunnel|neigh [COMMAND]
OPTIONS := -f[amily] inet|inet6|link | -o[neline]
COMMAND :=
ip addr add|del IFADDR dev IFACE | show|flush [dev IFACE] [to PREFIX]
ip route list|flush|add|del|change|append|replace|test ROUTE
ip link set IFACE [up|down] [arp on|off] | show [IFACE]
ip tunnel add|change|del|show [NAME]
        [mode ipip|gre|sit]
        [remote ADDR] [local ADDR] [ttl TTL]
ip neigh show|flush [to PREFIX] [dev DEV] [nud STATE]
/ # ip addr add 10.0.0.110 dev eth0
/ # ip link set eth0 up
/ # PHY: 1:10 - Link is Up - 100/Full
/ # ip route add 10.0.0.0/24 dev eth0
/ # cd /root/
	~ # wget http://10.0.0.10/html/busybox_1.27.2-r2_qb2.ipk
--2018-01-06 15:52:04--  http://10.0.0.10/html/busybox_1.27.2-r2_qb2.ipk
Connecting to 10.0.0.10:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 463368 (453K)
Saving to: `busybox_1.27.2-r2_qb2.ipk'
100%[======================================>] 463,368     --.-K/s   in 0.07s
2018-01-06 15:52:04 (6.47 MB/s) - `busybox_1.27.2-r2_qb2.ipk' saved [463368/463368]
~ # wget http://10.0.0.10/html/busybox-mountall_1.27.2-r2_qb2.ipk
--2018-01-06 15:52:20--  http://10.0.0.10/html/busybox-mountall_1.27.2-r2_qb2.ipk
Length: 1334 (1.3K)
Saving to: `busybox-mountall_1.27.2-r2_qb2.ipk'
100%[======================================>] 1,334       --.-K/s   in 0s
2018-01-06 15:52:20 (7.42 MB/s) - `busybox-mountall_1.27.2-r2_qb2.ipk' saved [1334/1334]
~ # busybox-syslog_1.27.2-r2_qb2.ipk
/bin/sh: busybox-syslog_1.27.2-r2_qb2.ipk: not found
~ # wget http://10.0.0.10/html/busybox-syslog_1.27.2-r2_qb2.ipk
--2018-01-06 15:52:33--  http://10.0.0.10/html/busybox-syslog_1.27.2-r2_qb2.ipk
Length: 2504 (2.4K)
Saving to: `busybox-syslog_1.27.2-r2_qb2.ipk'
100%[======================================>] 2,504       --.-K/s   in 0s
2018-01-06 15:52:33 (13.0 MB/s) - `busybox-syslog_1.27.2-r2_qb2.ipk' saved [2504/2504]
After reboot (by pressing the reset button) I was able to logon as root.
The link http://quby.nl/opensource/openembedded- ... r1.tar.bz2 is not working. (given in the handout. also quby.com isn't working). So I have to find that file somewhere else, is there somewhere else a link to download?
Edit: found it here: http://files.domoticaforum.eu/index.php?cam=/Toon
This is my i-tables.conf:
*nat
:PREROUTING ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
COMMIT
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:HCB-INPUT - [0:0]
-A INPUT -j HCB-INPUT
-A FORWARD -j HCB-INPUT
-A HCB-INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
# These are all closed for Quby/Toon:
-A HCB-INPUT -p tcp -m tcp --dport 22 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 10080 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 80 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
#-A HCB-INPUT -p udp -m udp --sport 67:68 --dport 67:68 -j ACCEPT
#-A HCB-INPUT -p udp -m udp --dport 137:138 -j ACCEPT
-A HCB-INPUT -i lo -j ACCEPT
-A HCB-INPUT -i tap+ -j ACCEPT
-A HCB-INPUT -i tun+ -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --tcp-flags SYN,RST,ACK SYN -j DROP
-A HCB-INPUT -p udp -m udp -j DROP
COMMIT
After reboot, I could ssh to Toon, so far so good :D
iMars wrote: The link http://quby.nl/opensource/openembedded- ... r1.tar.bz2 is not working. (given in the handout. also quby.com isn't working). So I have to find that file somewhere else, is there somewhere else a link to download?
You can find it at quby's website. Just scroll all the way down and click Open source.
globegrabber
Post by globegrabber »
Hy Members,
I a have buyed a rooted Toon as i don't wont to mes up this one because he is in function to control the environment here, for the hobby i have buy a elderly Toon, to learn about it and try to understand the programming, so far with no luck so far.
because i am trying to root an early Toon fw 2.9.26,
only thing as i try to root by following the Manuals/tutorials i can't get no verder then, /etc/inittab, as you can see a part out of the log,
what am i doeing wrong?
Wifi=disabled.
Serial communication with putty=ok
password for uboot version r6
=ok
U-Boot> run boot_nand setenv addmisc setenv bootargs \$\{bootargs\} mem=\$\{mem\} lpj=999424 init=/bin/sh
=ok
=ok
(bla bla bla until)
/bin/sh: can't access tty; job control turned off
/ # /etc/inittab
/bin/sh: /etc/inittab: Permission denied
here stops my luck? what am i doing wrong?
/ # /etc/inittab
The /bin/sh thing is a warning from the OS, nothing to worry about.
You are trying to execute a textfile. (/etc/inittab). That's a no-go.
If you want to edit /etc/inittab, you will need an editor. The one editor aboard Toon is vi, and it's a quirky one at that.
So, if you want to edit /etc/inittab you would say:
vi /etc/inittab
Before you start, I would read the manual pages of vi thoroughly if I were you, because it's not a very user-friendly editor, according to current standards.
iMars
Post by iMars »
Ok, Toon root'ed... and now further. How can I control the temperature setpoint? What are the next steps? (I'm feeling like a n00b :shock: :lol: :wink: )
globegrabber
Hallo marcelr,
Thanks for your reply, will take this with me in the next try, asap and first shell take notice of vi,
Grz, Globegrabber
Return to “Toon Rooting”
