Rooting Toon (or boxx)
jumperone
Re: Rooting Toon (or boxx)
Post by jumperone »
activate Toon
I have seen what I did wrong
The location was good.
/mnt/data/qmf/config/config_happ_scsync.xml
<visibility>0</visibility><StartDate>0</StartDate><EndDate>0</EndDate
I should have stood before the rule and walked in with the cursor .
Then press I (insert) to adjust it.and the previous delete
I also solved my previous post (no gas display).
<GasDisplay>0</GasDisplay> <GasDisplay>1</GasDisplay>
On that line I also adjusted that from 0 after 1.
For further adjustment see
TerrorSource
viewtopic. ... 971#p83254
I have the toon with Version: 2.0 - ThehogNL - 24-3-2018 upgrade from version 2.9.26 upgrade to 4.10.6. Update failled / Bus error
OPKG Do Not Work / Bus error / orange screen with 2 points.
What can I do
Markie13
Post by Markie13 »
@Markie13:
Sounds like a serial IO issue. Are you sure RxD and TxD are in the right place? Is your serial converter working properly with other hardware?
From the "Fully automated rooting script" topic to here.
It finally succeeded. I added password toon right after reboor. I didn't wait till "enter password". After ten times rebooting i succeeded :D
Now i get stuck at this
Restoring the boot loader and accessing toon through a shell
The only eneco i see is this
Lease failing, starting in bg: udhcpc -b -R -i eth0 -A 5 -p /var/run/udhcpc.eth0.pid -H eneco-001-******
Replaced serial number with asteriks
My reset button seems not to work so at the and of
Locate the password file /etc/passwd and edit the line:
root:DISABLED:0:0:root:/root:/bin/sh
to read:
root::0:0:root:/root:/bin/sh
so i can not reset.
Markie13
Post by Markie13 »
I have fully rooted my toon. For installing dropbear and openssh i used unpacked .ipk files from http://files.domoticaforum.eu/index.php?cam=/Toon. Maybe an idea to adjust/add this to your guide Marcel. Makes rooting much easier.
Post by TheHogNL »
Markie13 wrote:I have fully rooted my toon. For installing dropbear and openssh i used unpacked .ipk files from http://files.domoticaforum.eu/index.php?cam=/Toon. Maybe an idea to adjust/add this to your guide Marcel. Makes rooting much easier.
Why? You don't need 'unpacked' ipk. Just install it with opkg as the manual states.
Markie13
Post by Markie13 »
Normally it will work, but wget on my toon had some problems with wget and https. So I was searching for solutions. So this was mine.
Post by TheHogNL »
Markie13 wrote: Normally it will work, but wget on my toon had some problems with wget and https. So I was searching for solutions. So this was mine.
The domotica forum files url is in HTTP and not HTTPS.
But nice to see you managed to worked around your issue yourself.
Post by TheHogNL »
I noticed that in newer release there is another connection going to quby/eneco outside of the VPN.
If you don't like Eneco/Quby to get any information from your toon:
Make a backup of the /qmf/etc/qmf_tenant.xml first:
eneco-001-xxxxxx:/qmf/etc# cp qmf_tenant.xml qmf_tenant.xml.org
Then edit the file and remove all lines between the <hcb_bxtproxy> secion:
        <hcb_bxtproxy>
                <proxiedDevice env="TST" uuid="b4990910-2ed8-11e5-a2cb-0800200c9a66" url="https://test.datalab.toon.eu/receive/actionWithDataValuesXml"/>
                <proxiedDevice           uuid="b4990910-2ed8-11e5-a2cb-0800200c9a66" url="https://eneco.bd.toon.eu/receive/actionWithDataValuesXml"/>
                <!-- countly -->
                <proxiedDevice env="TST" uuid="cc7418e9-a723-4bed-b523-732955c7c520" url="https://quby.count.ly/i/bulk?app_key=xxxxxxxxxxxxxxxxxxx" contentArg="data" contentType="application
                <proxiedDevice env="ACC" uuid="cc7418e9-a723-4bed-b523-732955c7c520" url="https://quby.count.ly/i/bulk?app_key=xxxxxxxxxxxxxxxxxxx" contentArg="data" contentType="application
                <proxiedDevice           uuid="cc7418e9-a723-4bed-b523-732955c7c520" url="https://quby.count.ly/i/bulk?app_key=xxxxxxxxxxxxxxxxxxx" contentArg="data" contentType="application
        </hcb_bxtproxy>
Should be:
        <hcb_bxtproxy>
        </hcb_bxtproxy>
Any clue what type of data they collect?
Post by TheHogNL »
I'm thinking of KPI data (key performance indicator data). How is your Toon doing, performance, issue's etc. They probably know if your Toon is rooted using this link also. If your Toon is reporting using this link but not working on the service center (via openvpn) that would be an indication for a rooted toon (or a toon with vpn problems).
bwbboot
Post by bwbboot »
I can see my Toon connects with the URLs. For now I have blocked that complete domain. Its not much data, only couple of kb..
Edit: remarkable choice of domain btw...
Bjorns-iMac:~ bwbboot$ whois quby.count.ly
% IANA WHOIS server
% for more information on IANA, visit http://www.iana.org
% This query returned 1 object
refer: whois.nic.ly
domain: LY
organisation: General Post and Telecommunication Company
address: Al Zawia st.
address: GPTC Tower
address: Tripoli
address: Libya
michaelology
Post by michaelology »
Will I lose SSH access if I reset my toon to factory settings?
No, but you will lose all data and all SC settings. You will have to reactivate your toon. Unless you really want to do all of this, it's a pointless exercise.
Post by TheHogNL »
TheHogNL wrote:I'm thinking of KPI data (key performance indicator data). How is your Toon doing, performance, issue's etc. They probably know if your Toon is rooted using this link also. If your Toon is reporting using this link but not working on the service center (via openvpn) that would be an indication for a rooted toon (or a toon with vpn problems).
Adding to this a report of this has been made on the Eneco forum: https://forum.toon.nl/algemene-vragen-o ... eving-2088
RoadXY
Post by RoadXY »
bwbboot wrote:I can see my Toon connects with the URLs. For now I have blocked that complete domain. Its not much data, only couple of kb..
This is a hired service which aggegrates the data for them.
The first one yes, the second one is just one of Quby's own servers without any aggregation
Return to “Toon Rooting”
