makkie2002
Post by makkie2002 »
Hi guys,
I am strugling with my webcam app.
I want to download images only when the webcam is fullscreen or when the small webcam tile is shown.
I managed to let the app detect when the fullscreen widget is shown, however I do not know how to detect that the small tile is actively shown ... any suggestions are welcome !
Marc
webcam-0.0.6.zip
(13.28 KiB) Downloaded 482 times
michel30
Post by michel30 »
I have a small problem with ClockTile.qml date and time in dim function.
The problem is when the TOON goes in dim mode it does not show the date.
When I edit the following file ClockTile.qml and I remove this ! in visible: !dimState than the date will show in the dim function but not in the normal function.
In what file I could edit this so it will show me the date and time in dim and normal mode?
Post by TheHogNL »
michel30 wrote:When I edit the following file ClockTile.qml and I remove this ! in visible: !dimState than the date will show in the dim function but not in the normal function.
What do you think the ! means in front of the dimState :)
visible: !dimState = visible when screen is NOT in dimstate
visible: dimState = visible when screen IS in dimstate
So, just remove the whole line when you want to have the txtDate to be visible always :)
michel30
Post by michel30 »
Super thanks for your help and explaining :D
It works.
makkie2002
Does anybody know what are the memberfunctions/membervariables of the screenStateController?
I want to know because my Toon has issue with going into dim-state.
walberg
Post by walberg »
Anybody else has some ideas?[/quote]
How do you get the file domoticz.zip to de Toon? as no ftp program on Windows or Mac work with Toon
TerrorSource
Post by TerrorSource »
walberg wrote:Anybody else has some ideas?
How do you get the file domoticz.zip to de Toon? as no ftp program on Windows or Mac work with Toon[/quote]
What do you want to do with the file? Is it the official Domoticz installation? That's not going to work as it cannot run on a Toon.
walberg
Post by walberg »
sorry i was confused with the app domoticzboard. I have been Domoticz for 2 years on my Synology. In this topic there are many applications to install but the problem is that you can not copy a file from your Mac or Windows to the Toon with an ftp program.
walberg wrote:... l but the problem is that you can not copy a file from your Mac or Windows to the Toon with an ftp program.
That's not true.
Install the sftp server (see downloads thread) and you can shuttle files to toon and back as much as you like.
klaphekje
Post by klaphekje »
Or use something like SCP if you have trouble installing the sftp server.
scp is installed together with dropbear. Since you have a rooted toon, that should work.
walberg
Post by walberg »
Yes, with Winsscp on an old pc laptop i can transfer files. I have copied openssh-sftp-server_7.3p1-r10.0_qb2.ipk to /root and then opkg install openssh-sftp-server_7.3p1-r10.0_qb2.ipk Now i can connect with Filezilla from Mac.
Thanks.
walberg
Post by walberg »
Schermafbeelding 2017-09-22 om 15.16.09.jpg (99.47 KiB) Viewed 14086 times
How do I get a (double) tile away? I was busy adding domoticzBoard, could only find all of gas and energy, had nothing selected from it, but 2 tiles were used with gas.
Post by TheHogNL »
Press and hold the tile a few seconds, then a delete option will show
Vibestar
Post by Vibestar »
Maybe more hardware and software related: is there a way to controle the state of the boiler with a movementsensor?
I had a thermostat of ICY for many years. Of I wasnt in the room for 30 min the thermostat was set back to a colder state. I was wondering if it could be done by the TOON?
