the thermostat app in version 4.7.23 did change quite a lot. I updated the waste collection mod to be compatible with this firmware.
Icons are now shown above the temperature.
The attachment contains the full thermostat app for firmware 4.7.23 but only two files have been changed: ThermostatApp.qml and ThermostatSidepanel.qml.
All code changes are marked between the lines 'waste display start' and 'waste display end'.
Note: the icon will show only 6 minutes after restart of the gui and will be updated daily at 18.01 to show the icon for the next day
Summarizing:
- use the earlier posted version 1.2 of the mod for firmware version 3.7.9 (manually apply to other 3.x versions)
- use this earlier posted version 1.3 for firmware 4.4.21 (manually apply to other 4.x versions)
- use this version 1.3 on firmware 4.7.23
all are compatible with any recent version of the wastecollection app.
The screenshot below shows the thermostat panel for one and two waste icons.
- waste_mod_1.png (9.6 KiB) Viewed 11381 times
- waste_mod_2.png (11.53 KiB) Viewed 11381 times
