Toon app: Afvalwijzer
- Starting Member
@Toonz,
I f&**cked up the upgrade to firmware 4.x, eventually -with the help of Marcel, im back online, but i cant get afvalwijzer to work.
Downloaded the ICS from the katwijk site, placed it in /root/waste/waste-calendar.ics.. But the tile keeps empty...
Is there something that i miss??? Or maybe another file location in 4.8?
Please push me a bit in the right direction please!
Have you selected waste provider 5 in the config screen (access by clicking on the tile) ?
Secondly, the correct filename is /root/waste/waste_calendar.ics (not a '-' between waste and calendar but a '_')
- Starting Member
Excellent, running in the tile with the upcoming pickup rounds...
is there a way to test the dimstate icon??
Just patience.....till 18.00 the day before next collection day...
- Starting Member
OK, i'll hold my horses and keep my fingers crossed...
#volvertrouwen
#volvertrouwen
- Starting Member
Just to inform you..
Everything all right; got the icon in dim state )))
Thanks for the feedback, much appreciated
Toonz,
The app Domoticz/Dashticz V2 also has a list of Garbage collectors, check out this file for more info: github.com/robgeerts/dashticz_v2/blob/m ... garbage.js
Thanks, I know, but I only add new providers on request. It doesn't make sense to spend time on adding providers which no one is using on Toon.Templar wrote:Toonz,
Hi All
is it possible to add http://www.omrin.nl/bij-mij-thuis/servi ... alkalender in the waste app.
thanks
thanks
Yes, can do. The website is using the POST method to submit zipcode/housenr. Unfortunately Toon is not supporting the POST method.Demif wrote:Hi All
thanks
The standard workaround is to access to page on your PC, enter your zipcode, save the results page and copy it over to Toon.
As the file contains the dates for the whole year you only have to do this once per year around Jan 1st (or whenever they publish the new calendar for the year)
Will put it on my to-do list.
thank you,
but i had no succes, thry the manual (option 3) and the result is a white tile. on toon is no Omrin number, is number 14 ok?
greetz Freark
greetz Freark
I have not yet implemented Omrin. Will be in the next release (isn't like any other waste provider so far so needs a bit of coding).Demif wrote:thank you,
greetz Freark
I will post here when done.
@Toonz,
The issue what is in google chrome or safari for downloading the page RD4 is for the year 2018 also in internet explorer.
The layout looks complete different:
See: https://www.rd4info.nl/NSI/Burger/Aspx/ ... &nr=141&t=
Or I need to wait till january to see if go's okay because when I download it now I see Rd4 Navraagsysteem Inzamelgegevens_htm.htm ( double htm ) the 2017 has only one htm.
Thanks for your great work.
<div id="Afvalkalender1_pnlAfvalKalender">
<strong>Januari</strong><table class="plaintextMonth"><tr><td>Dinsdag 2 januari 2018</td><td>Restafval</td></tr><tr><td>Woensdag 3 januari 2018</td><td>
I cannot seem to download an .ics file from afvalkalender anymore. The link you provided: http://afvalkalender.dar.nl/download_ic ... 41XK&h=401 has been removed or something. How to proceed?Toonz wrote:Hi all,
I enhanced the app with the waste provider 'dar.nl'.
The calendar.ics file from their website needs to be manually downloaded and copied to: '/root/waste/waste_calendar.ics' .
Shouldn't be too much of an hassle as the file contains all dates for the rest of the year.
Configuration:
You need to edit WastecollectionApp.qml at the top to select one of the six supported waste providers
And edit your zipcode/house nr (not needed for Cure Avalbeheer, Cyclus NV, Dar.nl and Katwijk.nl).
This version is fully compatible with the thermostat_mod V1.2 posted earlier.
Currently supported:
"mijnafvalwijzer.nl"
"deafvalapp.nl"
"cure-afvalbeheer.nl"
"cyclusnv.nl"
"katwijk.nl"
"dar.nl"
Let me know if you want support for additional providers.
Regardsz,
