Toon app: Buienradar
jnieuw
Re: Toon app: Buienradar
Post by jnieuw »
Here is
/etc/ssl/certs/
lrwxrwxrwx    1 root     root            62 Apr 16 16:44 09789157.0 -> Starfield_Services_CA-G2-12-2037-dpc_qutility-hcb_bxtproxy.pem
lrwxrwxrwx    1 root     root            49 Apr 16 16:44 2c543cd1.0 -> GeoTrust_Global_CA-05-2022-Myfox_API-hdrv_hue.pem
lrwxrwxrwx    1 root     root            35 Apr 16 16:44 2e5ac55d.0 -> DST_Root_CA_X3-meethue-hdrv_hue.pem
lrwxrwxrwx    1 root     root            52 Apr 16 16:44 3513523f.0 -> DigiCert_GlobalRoot_CA-11-2031-Buienradar-qt-gui.pem
lrwxrwxrwx    1 root     root            33 Apr 16 16:44 5a4d6896.0 -> GovernmentoftheNetherlands_G3.pem
lrwxrwxrwx    1 root     root            22 Apr 16 16:44 5ad8a5d6.0 -> GlobalSign_Root_CA.pem
lrwxrwxrwx    1 root     root            19 Apr 16 16:44 6354599d.0 -> ca-certificates.crt
lrwxrwxrwx    1 root     root            55 Apr 16 16:44 8d28ae65.0 -> comodo-rsa-domain-validation-sha-2-w-root.ca-bundle.pem
lrwxrwxrwx    1 root     root            78 Apr 16 06:02 Comodo_RSA_CA-01-2038-Quby_Countly-hcb_bxtproxy.pem -> /usr/share/ca-certificates/Comodo_RSA_CA-01-2038-Quby_Countly-hcb_bxtproxy.crt
lrwxrwxrwx    1 root     root            79 Apr 16 06:02 DigiCert_GlobalRoot_CA-11-2031-Buienradar-qt-gui.pem -> /usr/share/ca-certificates/DigiCert_GlobalRoot_CA-11-2031-Buienradar-qt-gui.crt
lrwxrwxrwx    1 root     root            71 Apr 17 21:55 DigiCert_Global_Root_CA-meethue-hdrv_hue.pem -> /usr/share/ca-certificates/DigiCert_Global_Root_CA-meethue-hdrv_hue.crt
-rw-r--r--    1 root     root          1360 Jan 11 08:21 DigiCert_Global_Root_CA.pem
lrwxrwxrwx    1 root     root            76 Apr 16 06:02 GeoTrust_Global_CA-05-2022-Myfox_API-hdrv_hue.pem -> /usr/share/ca-certificates/GeoTrust_Global_CA-05-2022-Myfox_API-hdrv_hue.crt
lrwxrwxrwx    1 root     root            57 Apr 17 21:55 GlobalSign_Root_CA.pem -> /usr/share/ca-certificates/mozilla/GlobalSign_Root_CA.crt
-rw-r--r--    1 root     root          1952 Jan 11 08:21 GovernmentoftheNetherlands_G3.pem
lrwxrwxrwx    1 root     root            89 Apr 16 06:02 Starfield_Services_CA-G2-12-2037-dpc_qutility-hcb_bxtproxy.pem -> /usr/share/ca-certificates/Starfield_Services_CA-G2-12-2037-dpc_qutility-hcb_bxtproxy.crt
lrwxrwxrwx    1 root     root            99 Apr 16 06:02 VeriSign_Class_3_Public_Primary_Certification_Authority_-_G5.pem -> /usr/share/ca-certificates/mozilla/VeriSign_Class_3_Public_Primary_Certification_Authority_-_G5.crt
lrwxrwxrwx    1 root     root            64 Apr 16 16:44 b204d74a.0 -> VeriSign_Class_3_Public_Primary_Certification_Authority_-_G5.pem
-rw-r--r--    1 root     root          2342 Apr 16 06:10 ca-bundle.crt
-rw-r--r--    1 root     root         11904 Apr 17 21:55 ca-certificates.crt
-rw-r--r--    1 root     root          9181 Apr 17 06:02 ca-certificates.crt.tsc_backup
-rw-r--r--    1 root     root          5714 Jan 11 08:21 comodo-rsa-domain-validation-sha-2-w-root.ca-bundle.pem
lrwxrwxrwx    1 root     root            51 Apr 16 16:44 d6325660.0 -> Comodo_RSA_CA-01-2038-Quby_Countly-hcb_bxtproxy.pem
lrwxrwxrwx    1 root     root            13 Apr 16 16:44 e58eb220.0 -> ca-bundle.crt
lrwxrwxrwx    1 root     root            44 Apr 16 06:02 eneco.pem -> /usr/share/ca-certificates/mozilla/eneco.crt
mine looks like this, I see more entries in your folder.
jnieuw
Post by jnieuw »
Is it possible for you to export those? btw if I use openssl to check the api.buienradar.nl certificate it's OK. That would mean my certificates are OK(?):
 openssl s_client -showcerts -connect api.buienradar.nl:443
WARNING: can't open config file: /usr/lib/ssl/openssl.cnf
CONNECTED(00000003)
1074599120:error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol:s        23_clnt.c:794:
no peer certificate available
No client certificate CA names sent
SSL handshake has read 7 bytes and written 307 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
    Protocol  : TLSv1.2
    Cipher    : 0000
    Session-ID:
    Session-ID-ctx:
    Master-Key:
    Key-Arg   : None
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    Start Time: 1524142434
    Timeout   : 300 (sec)
    Verify return code: 0 (ok)
Last row:
Check for gadgets.buienradar.nl
 openssl s_client -showcerts -connect gadgets.buienradar.nl:443
CONNECTED(00000003)
1074590928:error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol:s23_clnt.c:794:
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
    Protocol  : TLSv1.2
    Cipher    : 0000
    Session-ID:
    Session-ID-ctx:
    Master-Key:
    Key-Arg   : None
    PSK identity: None
    SRP username: None
    Start Time: 1524142643
    Timeout   : 300 (sec)
And xml.buienradar.nl
 openssl s_client -showcerts -connect xml.buienradar.nl:443
CONNECTED(00000003)
1074410704:error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol:s23_clnt.c:794:
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
    Protocol  : TLSv1.2
    Cipher    : 0000
    Session-ID:
    Session-ID-ctx:
    Master-Key:
    Key-Arg   : None
    PSK identity: None
    SRP username: None
    Start Time: 1524142769
    Timeout   : 300 (sec)
Is there a way to log the connection?
I don't think openssl is used by Toon. It is using the XMLhttprequest object within QT.
The openssl.conf file is in the folder /etc/ssl by the way
jnieuw
Post by jnieuw »
Hi Toon,
Is your code open? Or could you send me the part where the https connection is done? I just want to know what and where it goes wrong.
The apps all have plain text code, which is stored in /HCBv2/qml/apps/<app_name>/
So you can go there and have a look.
jnieuw
Post by jnieuw »
marcelr wrote:The apps all have plain text code, which is stored in /HCBv2/qml/apps/<app_name>/
Thank you
jnieuw
Post by jnieuw »
Ok, I removed (some) of the https calls and redirected them to a http server and now buienrader is working again, so something is definitely screwed up in my qt or certificates.
Could someone post his/her /etc/ca-certificates.conf file?
jnieuw
Post by jnieuw »
Ok, fixed it. Did some changes to the buienradar/regen urls (to make sure it does not get the 301 redirects). Removed all the files in /etc/ssl/certs, did a update-ca-certifcates, reboot and all is working fine again.
Don't now how the certifcates got scrambled in the first place.
jnieuw wrote:Ok, fixed it. Did some changes to the buienradar/regen urls (to make sure it does not get the 301 redirects). Removed all the files in /etc/ssl/certs, did a update-ca-certifcates, reboot and all is working fine again.
Thanks for the feedback. Haven't seen this before, hope it is a one-off occurrence.
jossie67
Post by jossie67 »
is it posible to add a weerstation.
I'm living in Amsterdam and the schiphol is my weerstation.
So my Toon isn't correct in when it raining
jossie67 wrote:is it posible to add a weerstation.
No, I cannot add weatherstations, that is a fixed list provided by Buienradar.nl.
To get correct rainforecasts on the rain tile, set your exact location:
Go to the big radarscreen and press 'Locatie' in the top right corner.
You can then either enter your lon/lat coordinates or click on the map to set your location.
Zoom out a few times and click on the edge of the map to make that the new center.
Zoom in again when you are closer to your home.
The rain prediction data is delivered at .01 resolution for lon/lat coordinates, which is a few hundred meters.
Hope this helps.
A new release (8.3.5) is published on ToonStore.
Changelog 8.3.5:
- now compatible with firmware 4.16.8 (weather icon on the tile in dim state was not shown)
- no need to update when on earlier firmwares (can't harm either)
ewshop
Post by ewshop »
New release buienradar 8.3.5 on toon with firmware 3.4.4 does not working correct. The text is outside the tiles.
Regard Eric
ewshop wrote:New release buienradar 8.3.5 on toon with firmware 3.4.4 does not working correct. The text is outside the tiles.
Regard Eric
Thanks for flagging. This has to do with the recent changes Quby introduced for Toon 2.
I haven't been able to test this on firmware 3.X as all my Toons have been upgraded since.
My advice for now would be to rollback to an earlier release (8.3.4 should do).
Remove buienradar via Toonstore and install the old version manually:
files.domoticaforum.eu/uploads/Toon/app ... r0_qb2.ipk
P.S. this might be valid for most applications in Toonstore so you could consider upgrading to a newer firmware.
My advice would be to upgrade to 4.15.6 using the update script from TheHogNL.
