Toon app: DomoticzBoard
TerrorSource
Post by TerrorSource »
This is a somewhat improved version of DomoticzLights.
Switches:
5 Switches, programmable via IDX value
Name, Status automatically retrieved from Domoticz
Scenes:
3 Scenes, always takes the first 3 scenes. (so make sure that the scenes you want to use are the ones with the lowest IDX's ! )
Name - IDX - Status > Retreived from Domoticz JSON
Icons will adjust to the current status of the Status for Switch and Scenes.
cygnusx
Re: Toon app: DomoticzBoard
Post by cygnusx »
Is this like a page from the menu?
TerrorSource
cygnusx wrote:Is this like a page from the menu?
It's an App which can be launched from the top-bar, where "buienradar" is located too.
klaphekje
Post by klaphekje »
Nice improvements!
The status icon of switch 4, 5 and 6 and of the scenes do not update accordingly.
Only switches 1 and 2 do.
Is this also the case in your Toon?
TerrorSource
klaphekje wrote:Nice improvements!
Well, it should work, will take a look at it asap.
How much Scenes/Groups do you use? DomoticzBoards preferes Groups(as ON/OFF switch, Scenes can only be triggerd ON). Think that 2 will suffice, 3 is overkill for normale users i guess.
klaphekje
Post by klaphekje »
I have one scene and one group.
Ps.
It works really well, also without the on/off feedback offcourse :)
TerrorSource
klaphekje wrote:I have one scene and one group.
Ps.
So only 2 buttons at the right column will do?
What's the issue with the switches in the left column not updating? The script for each button should be the same.
Still need to tweak around. Names of Groups are %NAME%-%IDX%-%STATUS% now, you dont need the %IDX%-%STATUS% part, is just for testing purposes.
Blacky's Boss
Post by Blacky's Boss »
This is about what I had in mind when I bought my Toon at Marktplaats. Rooting went fine due to the perfect tutorial.
But I'm having troubles installing your App. After restarting the GUI Toon goes blank
What name should I add to the Globals.qml file?
Is this normally the module name mentioned in the qmldir file? "DomoticzBoard" ?
TerrorSource
Blacky's Boss wrote:This is about what I had in mind when I bought my Toon at Marktplaats. Rooting went fine due to the perfect tutorial.
You should add a line between the existing ones into the Globals.qml:
"DomoticzBoard",
Dont forget the , or the ] at the end of the tag.
klaphekje
Post by klaphekje »
Ps.
I did edit some pieces of your program but i'm still unable to get the status indicator working for "Keuken" en "Eettafel". The other switches work just fine.
The code is identical to the other switches and scenes.
See the images below.
Knipsel (Custom).PNG (57.27 KiB) Viewed 34669 times
TerrorSource
klaphekje wrote:
Ps.
Ah, i see the issue here. This version of DomoticzBoard only allows ON/OFF switching, while "dimming" is between OFF(value=0) and ON(value=100).
klaphekje
Post by klaphekje »
Ah, so in my case it only shows the status if its 100% on?
Why did'nt i ask earlier... hours wasted on finding the typo in in the lines :roll: :lol:
Anyway, thanks for the help. Is it hard to adjust the app to show the status and percentage?
TerrorSource
klaphekje wrote:Ah, so in my case it only shows the status if its 100% on?
This version of DomoticzBoard was only for testing purposes.
Still need to find the knowledge and know-how to build it the way i want it to have :)
Can you PM me the things you've changed in the code so i can slightly improve this version?
klaphekje
Post by klaphekje »
I have mailed the zip file to you.
What kind of functionality do you like to add to DB? I probably don't have the required knowledge or skills available but i wouldn't be surprised if we want similar things.
Maybe i can help in some way.
Blacky's Boss
klaphekje wrote:Maybe i can help in some way.
Yeah, me too. I have some programming skills, but this language is new to me. But if I get DomoticzBoard working in the first place, then I would be happy to take a look at making it even better!
@klaphekje: Can I get your changes too?
