Toon app: Sonos Control
Hi All,
After rooting my Toon i wanted to use my Toon as controller for my Sonos Devices, and start developing this application. There is just one requirement to use this application, you have to use the SONOS HTTP API: for more information follow this link: https://github.com/jishi/node-sonos-http-api. This HTTP API is controlling your Sonos device by HTTP commands.
The application have several functions/options,
you will have a menu item which will forward you to the menuscreen. This menuscreen is used for connecting to your SONOS HTTP API, so please fill in your Hostname and Portnumber, it will automaticly check your available zones. You can also enable your Systray icon.
When you filled in the correct information and you have 1 or more active zones in the application you can access the MediaScreen and Tiles. When you have multiple zones you can choose which zone you want to control on the Media Screen (you will have a drop down menu). After selecting a zone this will also be the active zone for the tiles.
If you have any issues or feature requests please let me know
Ps. This application could be found in the Toon Store soon.
- Menu Screen
- Menu Screen.png (41.16 KiB) Viewed 21053 times
- Both tiles
- Sonos Tiles (1).png (51.98 KiB) Viewed 21127 times
- Favorites Screen
- Sonos Favorites.PNG (28.86 KiB) Viewed 21127 times
- Media Screen
- Sonos Screen (1).png (104.68 KiB) Viewed 21127 times
- Menu Item
- Menu item.PNG (30.45 KiB) Viewed 21127 times
Re: Toon app: Sonos Control
Update: Sonos Control v1.0.0 could be found in ToonStore.
- Administrator
Nice work!
Can you add the "Title" from the API so it's shows the Artists/Songname from the radio station in the Tiles?
The new version will be soon in the Toonstore. Changes made:
- the textlabels in the menuscreen had an issue when you are working on firmware 3.x. So it should be compatible with firmware 3.x
- when radio is playing it will also show the title which is playing on the radio.
Just updated the app to 1.0.2 which would be packaged for the ToonStore, two fixes in this update:
- When you are playing your playlist your thumbs will be displayed in your playlist queue
- The title which was updated in 1.0.1 was not aligned correctly on the mediascreen, this is now fixed and would be aligned correctly.
This app looks very promising. Thanks for all your efforts. Right now i'm facing this problem. I have setup my sonos to recieve a fixed ip by dhcp.
When i connect to http://192.168.1.11:1400/status i get basic status info. So far so good.
The app however keeps sending me to the 'menuScherm' due to wrong ip/port or not working http api. When i try to reach http://192.168.1.11:5005/ with putty/telnet i get a connection refused.
Any thoughts?
Edit: Ah, i figured it out :- ) I thought this node http api was part of the app, but instead the app wants to connect to this remote http api installed on a Raspberry pi or similar device. Too bad the http api isn't/cant be part of the app.
Any thoughts?
Tried this app to controll the my sonos.
Installed the Sonos Http API on my Synolgy nas (docker container)
controlling the Sonos is possible, and favorite list is availiable.
but not all vissual functions are working on FW 4.19, is there going to be an update?
Highly unlikely, I'm afraid.
The guy who made it hasn't been spotted on this forum since october 2017.
i found out that toonstore has installed V1.0.1, the issues i see are fixed in 1.0.2.
now looking for the 1.0.2 source.
- Administrator
How do you know that the issues are fixed in 1.0.2 while there is no 1.0.2 of this app available?legalr wrote:i found out that toonstore has installed V1.0.1, the issues i see are fixed in 1.0.2.
assumtions from a few post above.TerrorSource wrote:How do you know that the issues are fixed in 1.0.2 while there is no 1.0.2 of this app available?legalr wrote:i found out that toonstore has installed V1.0.1, the issues i see are fixed in 1.0.2.
Happy to put it on ToonStore but I never received the 1.0.2 source files....
- Administrator
Yes i saw that. but the problem is that the author never made 1.0.2 public or available for testing. so there's no 1.0.2 to download/find somewhere.legalr wrote:assumtions from a few post above.TerrorSource wrote:How do you know that the issues are fixed in 1.0.2 while there is no 1.0.2 of this app available?legalr wrote:i found out that toonstore has installed V1.0.1, the issues i see are fixed in 1.0.2.
Author of the app hasn't been online in a while, guess he lost his interest
EDIT: i have received v1.0.2 from the author (i know him personally).
Will give it to Toonz asap.
Harmen's Sonos 1.0.2 app is now available in the ToonStore.
Changelog v1.0.2:
- sonos IP wordt nu opgehaald voor het weergeven van queue thumbs in de playlist (op het mediascreen)
- item Time (op het mediascreen) wordt nu netjes uitgelijnt bij radio (onder titel) bij de gewone playlist onder de item naam zelf.
Changelog v1.0.2:
- Starting Member
Hi guys,
Any plans to update the Sonos player for the TOON 2???
Dennis
Dennis
