Toon looks Empty?
walberg
Toon looks Empty?
Post by walberg »
I have recently bought an Eneco Toon. Just put the Toon to the network and 2 lines to the boiler adapter, which is not yet installed. Power on it and I'll see Eneco Toon, after a few seconds, faded and then Eneco will show nothing but the lights will remain on, but nothing on the screen. According to my router, the Toon is on 192.168.178.69 (I have many devices on my network) so on my browser I open with 192.168.178.69 and then I see on my bar http://192.168.178.69/HCBv2/www/ and on browser text field State: 404 not found. Would the files have been deleted?
michel30
Re: Toon looks Empty?
Post by michel30 »
I have also the 404 error when I enter http://IPnumber/HCBv2/www/
Can you try this: http://IPnumber/happ_thermstat?action=getThermostatInfo this will show you some text files.
walberg
Post by walberg »
On the document rooting Toon is written:
wget https://domoticaforum.eu/download/file.php?id=2987 i tried it on my mac (logged in on the Toon) and also on a borrowed pc laptop, but on both machines i got HTTPS support not compiled in.
walberg
Post by walberg »
Michel sorry i dit not see your reply i just entered firefox again
I just try it:
{"result":"ok", "currentTemp":"2554", "currentSetpoint":"1500", "currentInternalBoilerSetpoint":"6", "programState":"0", "activeState":"3", "nextProgram":"-1", "nextState":"-1", "nextTime":"0","nextSetpoint":"0","randomConfigId":"1804289383","errorFound":"255","connection":"0","burnerInfo":"0","otCommError":"1","currentModulationLevel":"0"}
Post by TheHogNL »
Looks like something missing indeed.
Try to do the hack, get into the console and from there try to find out wat is missing. Maybe a software update from there could be possible. But first thing, open it, root it and get into the console.
walberg
Post by walberg »
Tried from rooting.txt
eneco-001-089496:~# eneco-001-089496:# ping ping.quby.nl
-sh: eneco-001-089496:#: not found
eneco-001-089496:~# /etc/host.template
-sh: /etc/host.template: not found
eneco-001-089496:~#
There is only a white screen, after restart i got Eneco toon after about 15 seconds restart and Eneco toon and after a few seconds an empty screen.
Post by TheHogNL »
walberg wrote:Tried from rooting.txt
eneco-001-089496:~#
I think you copied some commands wrong :-)
It is: "ping ping.quby.nl" (without the " ofcourse), so don't put the eneco-001-etc in front :)
But try to run these commands:
opkg update
opkg upgrade
Hopefully that will upgrade and restore your normal toon.
Post by TheHogNL »
Also, run a "ps" command (without the ") and paste the results here so I can compare your output with mine and hopefully discover what is missing.
Sounds like your toon boots the kernel, and then fails to start up the user interface.
Can you post /etc/inittab and the firmware version?
and possibly the output of
top -n2
walberg
Post by walberg »
nope there is an empty screen. So i could not see any information about the software version.
I also tried opkg update then i got:
Downloading http://feed.hae.int/feeds/qb2/ene/3.6.3/Packages.gz.
But thats about 5 minutes ago and i just got
Downloading http://feed.hae.int/feeds/qb2/ene/3.6.3/Packages.sig.
walberg
Post by walberg »
eneco-001-089496:~# opkg update
Signature check failed.
Remove wrong Signature file.
Downloading http://feed.hae.int/feeds/qb2/oe/2.6.36 ... ackages.gz.
Downloading http://feed.hae.int/feeds/qb2/oe/2.6.36 ... ckages.sig.
Collected errors:
* opkg_download: Failed to download http://feed.hae.int/feeds/qb2/ene/3.6.3/Packages.gz: Couldn't connect to server.
* opkg_download: Failed to download http://feed.hae.int/feeds/qb2/ene/3.6.3/Packages.sig: Couldn't connect to server.
* opkg_download: Failed to download http://feed.hae.int/feeds/qb2/oe/2.6.36 ... ackages.gz: Couldn't connect to server.
* opkg_download: Failed to download http://feed.hae.int/feeds/qb2/oe/2.6.36 ... ckages.sig: Couldn't connect to server.
eneco-001-089496:~#
eneco-001-089496:~#
If you can run a shell, you should at least be able to produce the output of
top -n2
and show the contents of /etc/inittab:
less /etc/inittab
and post it.
Probably there's quite some stuff missing/not working on your toon, since signature checks do not work.
Oh by the way, your FW version is probably 3.5.4 (the last before 3.6.3, which fails to install now).
walberg
Post by walberg »
marcelr wrote:Sounds like your toon boots the kernel, and then fails to start up the user interface.
top -n2
Mem: 52944K used, 72704K free, 0K shrd, 0K buff, 22872K cached
CPU: 1% usr 3% sys 0% nic 94% idle 0% io 0% irq 0% sirq
Load average: 0.48 0.62 0.28 1/136 1173
PID PPID USER STAT VSZ %MEM %CPU COMMAND
684 1 root S 38764 31% 2% HCBv2 hdrv_zwave [OK] [EDD1723D SIS 3.67] [S1|N1]
674 1 root S 21536 17% 1% HCBv2 hcb_watchdog [OK] [S20|N1]
1173 1162 root R 3048 2% 1% top -n2
652 1 root S 334m 273% 1% HCBv2 hcb_comm [OK] [20 clients] [S1|N1]
3 2 root SW 0 0% 0% [ksoftirqd/0]
656 1 root S 20584 16% 0% HCBv2 happ_scsync [OK] [S1|N1]
665 1 root S 12356 10% 0% HCBv2 hcb_log [OK] [S1|N1]
649 1 root S 53940 43% 0% /HCBv2/sbin/qt-gui -platform linuxfb -plugin Tslib
675 1 root S 22792 18% 0% HCBv2 hdrv_hue [OK] [S1|N1]
658 1 root S 21680 17% 0% HCBv2 happ_thermstat [OK] [S20|N1]
654 1 root S 21600 17% 0% HCBv2 happ_kpi [OK] [S1|N1]
655 1 root S 21552 17% 0% HCBv2 happ_pwrusage [OK] [S30|N1]
666 1 root S 21116 17% 0% HCBv2 hcb_rrd [OK] [S1|N1]
651 1 root S 20884 17% 0% HCBv2 hcb_netcon [OK] [S1|N1]
657 1 root S 20708 16% 0% HCBv2 happ_smartplug [OK] [S1|N1]
676 1 root S 20680 16% 0% HCBv2 hdrv_p1 [OK] [Z:NCONN E:DIS (ANA) G:DIS] [S1|N1]
659 1 root S 20516 16% 0% HCBv2 happ_usermsg [OK] [S1|N1]
660 1 root S 14512 12% 0% HCBv2 happ_weather [OK] [S20|N1]
673 1 root S 14096 11% 0% HCBv2 hcb_upnp [OK] [S20|N1]
653 1 root S 13028 10% 0% HCBv2 happ_eventmgr [OK] [S1|N1]
663 1 root S 12872 10% 0% HCBv2 hcb_bxtproxy [OK] [S:0:0:4 R:0:0 Q:0 (PRD)] [S1|N1]
664 1 root S 12868 10% 0% HCBv2 hcb_config [OK] [S1|N1]
691 1 root S 5264 4% 0% /HCBv2/bin/lighttpd -D -m /HCBv2/lib/lighttpd -f /HCBv2/etc/lighttpd/lig
1035 1 root S 3472 3% 0% /usr/sbin/nmbd -s /etc/samba/smb.conf
1162 1157 root S 3048 2% 0% -sh
650 1 root S 2876 2% 0% /sbin/getty -L 115200 ttymxc0 vt102
609 1 root S 2872 2% 0% /sbin/klogd -n
607 1 root S 2872 2% 0% /sbin/syslogd -n -O /var/log/messages -s 128 -b 1 -m 20
517 1 root S 2872 2% 0% udhcpc -R -n -p /var/run/udhcpc.eth0.pid -i eth0 -H eneco-001-089496
1021 1 root S 2616 2% 0% /usr/sbin/chronyd -r
1157 604 root S 2336 2% 0% /usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
604 1 root S 2164 2% 0% /usr/sbin/dropbear -r /etc/dropbear/dropbear_rsa_host_key -p 22
1 0 root S 1600 1% 0% init [5]
5 2 root SW 0 0% 0% [kworker/u:0]
142 2 root SW 0 0% 0% [khubd]
509 2 root SW 0 0% 0% [flush-ubifs_0_0]
2 0 root SW 0 0% 0% [kthreadd]
274 2 root SW 0 0% 0% [kworker/0:2]
4 2 root SW 0 0% 0% [kworker/0:0]
6 2 root SW 0 0% 0% [watchdog/0]
7 2 root SW< 0 0% 0% [khelper]
8 2 root SW 0 0% 0% [kworker/u:1]
11 2 root SW< 0 0% 0% [pm]
125 2 root SW 0 0% 0% [sync_supers]
eneco-001-089496:~#
walberg
Post by walberg »
I also tried to login with Filezilla (ftp client Mac) i got: Fout: Received unexpected end-of-file from SFTP server
I think the seller have deleted too much out of the directories, not only personal files but also system files.
walberg
Post by walberg »
marcelr wrote:If you can run a shell, you should at least be able to produce the output of
top -n2
less /etc/inittab
and post it.
initab:
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
# HCBv2 static stuff
#ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
qtqt:245:respawn:/usr/bin/startqt >/dev/null 2>&1
# add serial console access: (added, MR!):
gett:235:respawn:/sbin/getty -L 115200 ttymxc0 vt102
# WARNING: auto-managed by '/etc/init.d/HCBv2 inittabwrap' with '/HCBv2/etc/start.d/*'
# lines containing 'inittabwrap' will be removed automagically.
netc:235:respawn:/etc/init.d/HCBv2 inittabwrap hcb_netcon
comm:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_comm
even:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_eventmgr
kpik:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_kpi
pwru:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_pwrusage
scsy:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_scsync
smar:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_smartplug
ther:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_thermstat
user:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_usermsg
