Toon firmware - update script
Sundown89
Post by Sundown89 »
Yes. Well, I took my Toon off the wall to gain console access again. Set the password (since I removed it) and put it back together.
Thanks for the explanation.
Post by TheHogNL »
I have put the latest version 2.0 of the script in the first post. This version has much more checks and also has a fixing step at the end of the upgrade process.
It will fix important files which are changed during the upgrade, like Globals.qml, InternetSettings.qml and some more. It will also reinstall the latest Toonstore and the Busybox mod if necessary.
I could not test the script from the beginning to the end on my Toon as it is already on the latest version. But I did try to test each part and improvement in the script so it should work. Please let me know if you run into any issues running the script.
balans
Post by balans »
ok couldn`t resist ,part because somethings didn`t work correctly yet so i used youre 2.0 to upgrade from 4.11 to 4.12
./update*
Welcome to the rooted Toon upgrade script. This script will try to upgrade your        Toon using your original connection with Eneco. It will start the VPN if necessa        ry.
Version: 2.0 - ThehogNL - 24-3-2018
You are currently running version 4.11.6
Which version do you want to upgrade to? You can look at the list of currently k        nown Toon versions at https://notepad.pw/raw/6fmm2o8ev
4.12.0
Alright, I will try to upgrade to 4.12.0
Tunnel is alive and configured.
Upgrade script downloaded. Ready for upgrade process. Do you want to proceed downloading the packages?
yes
Starting the upgrade prepare option which downloads all necessary files. No upgrade is done yet.
Done preparing.
Are your sure you want to upgrade to 4.12.0? This is the last moment you can stop the upgrade. Answer with 'yes' will start the upgrade.
yes
Starting the upgrade now! Just wait a while...
You can follow the upgrade if you open another SSH to the Toon and run this command:
tail -f /mnt/data/update/upgrade-qb2.sh.log
Upgrade done!
Restoring your iptables and passwd files so you can login again after rebooting.
Upgrade is done. However each firmware upgrade will revert the changes to some files needed for a working rooted Toon. Do you want me me to try and fix a few well known issue's for you right now?
yes
FIXING: Trying to fix Global.qml now to add all the Toonstore installed apps again.
Restoring boilerstatus in Globals.qml
Restoring temperaturelogger in Globals.qml
Restoring fileinfo in Globals.qml
Restoring buienradar in Globals.qml
Restoring toonstore in Globals.qml
FIXING: Now fixing internet settings app to fake ST_TUNNEL mode.
Modification in InternetSettingsApp.qml is missing. Fixing it now.
FIXING: Now modifying notifications bar to not show any network errors
Modification in NotificationBar.qml is missing. Fixing it now.
FIXING: Now installing latest toonstore app. This fixes some files also.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps//toonstore-1.1.4/toonstore_1.1.4-r0_qb2.ipk.
Installing toonstore (1.1.4-r0) to root...
Executing pre-install script for toonstore-1.1.4
Previous installation detected.
Creating backup for /qmf/etc/qmf_release.xml ...
Patching /qmf/etc/qmf_release.xml for 403-forbidden error ...
Restarting http server ...
killall: lighttpd: no process killed
Collected errors:
 * pkg_run_script: package "toonstore" preinst script returned status 1.
 * preinst_configure: Aborting installation of toonstore.
 * opkg_install_cmd: Cannot install package toonstore.
FIXING: Now installing latest busybox mod. This is necessary to enable console output again which is disabled in 4.10 by Eneco.
Installing custom busybox to replace the native busybox from Eneco so we have a working getty.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/busybox-1.27.2-r4/busybox_1.27.2-r4_qb2.ipk.
Installing busybox (1.27.2-r4) to root...
Configuring busybox.
ln: /usr/sbin/i2cget: File exists
ln: /usr/sbin/i2cset: File exists
ln: /usr/sbin/i2cdump: File exists
ln: /usr/sbin/i2cdetect: File exists
update-alternatives: Linking //usr/bin/ar to ../../bin/busybox
update-alternatives: Linking //bin/gunzip to busybox
update-alternatives: Linking //bin/zcat to busybox
update-alternatives: Linking //usr/bin/bunzip2 to ../../bin/busybox
update-alternatives: Linking //usr/bin/bzcat to ../../bin/busybox
update-alternatives: Linking //usr/bin/lzcat to ../../bin/busybox
update-alternatives: Linking //usr/bin/lzma to ../../bin/busybox
update-alternatives: Linking //usr/bin/unxz to ../../bin/busybox
update-alternatives: Linking //usr/bin/xzcat to ../../bin/busybox
update-alternatives: Linking //usr/bin/xz to ../../bin/busybox
update-alternatives: Linking //bin/cpio to busybox
update-alternatives: Linking //bin/gzip to busybox
update-alternatives: Linking //bin/lzop to busybox
update-alternatives: Linking //usr/bin/unlzop to ../../bin/busybox
update-alternatives: Linking //usr/bin/lzopcat to ../../bin/busybox
update-alternatives: Linking //bin/tar to busybox
update-alternatives: Linking //usr/bin/unzip to ../../bin/busybox
update-alternatives: Linking //usr/bin/chvt to ../../bin/busybox
update-alternatives: Linking //usr/bin/clear to ../../bin/busybox
update-alternatives: Linking //usr/bin/deallocvt to ../../bin/busybox
update-alternatives: Linking //bin/dumpkmap to busybox
update-alternatives: Linking //usr/bin/fgconsole to ../../bin/busybox
update-alternatives: Linking //bin/kbd_mode to busybox
update-alternatives: Linking //usr/sbin/loadfont to ../../bin/busybox
update-alternatives: Linking //usr/sbin/setfont to ../../bin/busybox
update-alternatives: Linking //sbin/loadkmap to ../bin/busybox
update-alternatives: Linking //usr/bin/openvt to ../../bin/busybox
update-alternatives: Linking //usr/bin/reset to ../../bin/busybox
update-alternatives: Linking //sbin/setconsole to ../bin/busybox
update-alternatives: Linking //usr/bin/showkey to ../../bin/busybox
update-alternatives: Linking //usr/bin/basename to ../../bin/busybox
update-alternatives: Linking //bin/cat to busybox
update-alternatives: Linking //bin/chgrp to busybox
update-alternatives: Linking //bin/chmod to busybox
update-alternatives: Linking //bin/chown to busybox
update-alternatives: Linking //usr/sbin/chroot to ../../bin/busybox
update-alternatives: Linking //bin/cp to busybox
update-alternatives: Linking //usr/bin/cut to ../../bin/busybox
update-alternatives: Linking //bin/date to busybox
update-alternatives: Linking //bin/dd to busybox
update-alternatives: Linking //bin/df to busybox
update-alternatives: Linking //usr/bin/dirname to ../../bin/busybox
update-alternatives: Linking //usr/bin/dos2unix to ../../bin/busybox
update-alternatives: Linking //usr/bin/unix2dos to ../../bin/busybox
update-alternatives: Linking //usr/bin/du to ../../bin/busybox
update-alternatives: Linking //bin/echo to busybox
update-alternatives: Linking //usr/bin/env to ../../bin/busybox
update-alternatives: Linking //usr/bin/expr to ../../bin/busybox
update-alternatives: Linking //usr/bin/factor to ../../bin/busybox
update-alternatives: Linking //bin/false to busybox
update-alternatives: Linking //bin/fsync to busybox
update-alternatives: Linking //usr/bin/head to ../../bin/busybox
update-alternatives: Linking //usr/bin/groups to ../../bin/busybox
update-alternatives: Linking //usr/bin/id to ../../bin/busybox
update-alternatives: Linking //bin/link to busybox
update-alternatives: Linking //bin/ln to busybox
update-alternatives: Linking //usr/bin/logname to ../../bin/busybox
update-alternatives: Linking //bin/ls to busybox
update-alternatives: Linking //usr/bin/md5sum to ../../bin/busybox
update-alternatives: Linking //usr/bin/sha3sum to ../../bin/busybox
update-alternatives: Linking //usr/bin/sha256sum to ../../bin/busybox
update-alternatives: Linking //usr/bin/sha512sum to ../../bin/busybox
update-alternatives: Linking //bin/mkdir to busybox
update-alternatives: Linking //usr/bin/mkfifo to ../../bin/busybox
update-alternatives: Linking //bin/mknod to busybox
update-alternatives: Linking //bin/mktemp to busybox
update-alternatives: Linking //bin/mv to busybox
update-alternatives: Linking //bin/nice to busybox
update-alternatives: Linking //usr/bin/nl to ../../bin/busybox
update-alternatives: Linking //usr/bin/nohup to ../../bin/busybox
update-alternatives: Linking //usr/bin/nproc to ../../bin/busybox
update-alternatives: Linking //usr/bin/od to ../../bin/busybox
update-alternatives: Linking //usr/bin/paste to ../../bin/busybox
update-alternatives: Linking //usr/bin/printf to ../../bin/busybox
update-alternatives: Linking //bin/pwd to busybox
update-alternatives: Linking //usr/bin/readlink to ../../bin/busybox
update-alternatives: Linking //usr/bin/realpath to ../../bin/busybox
update-alternatives: Linking //bin/rm to busybox
update-alternatives: Linking //bin/rmdir to busybox
update-alternatives: Linking //usr/bin/seq to ../../bin/busybox
update-alternatives: Linking //usr/bin/shred to ../../bin/busybox
update-alternatives: Linking //usr/bin/shuf to ../../bin/busybox
update-alternatives: Linking //bin/sleep to busybox
update-alternatives: Linking //usr/bin/sort to ../../bin/busybox
update-alternatives: Linking //bin/stty to busybox
update-alternatives: Linking //bin/sync to busybox
update-alternatives: Linking //usr/bin/tail to ../../bin/busybox
update-alternatives: Linking //usr/bin/tee to ../../bin/busybox
update-alternatives: Linking //usr/bin/test to ../../bin/busybox
update-alternatives: Linking //usr/bin/[ to ../../bin/busybox
update-alternatives: Linking //usr/bin/[[ to ../../bin/busybox
update-alternatives: Linking //usr/bin/timeout to ../../bin/busybox
update-alternatives: Linking //bin/touch to busybox
update-alternatives: Linking //usr/bin/tr to ../../bin/busybox
update-alternatives: Linking //bin/true to busybox
update-alternatives: Linking //usr/bin/truncate to ../../bin/busybox
update-alternatives: Linking //usr/bin/tty to ../../bin/busybox
update-alternatives: Linking //bin/uname to busybox
update-alternatives: Linking //usr/bin/uniq to ../../bin/busybox
update-alternatives: Linking //usr/bin/unlink to ../../bin/busybox
update-alternatives: Linking //bin/usleep to busybox
update-alternatives: Linking //usr/bin/uudecode to ../../bin/busybox
update-alternatives: Linking //bin/base64 to busybox
update-alternatives: Linking //usr/bin/uuencode to ../../bin/busybox
update-alternatives: Linking //usr/bin/wc to ../../bin/busybox
update-alternatives: Linking //usr/bin/who to ../../bin/busybox
update-alternatives: Linking //usr/bin/whoami to ../../bin/busybox
update-alternatives: Linking //usr/bin/yes to ../../bin/busybox
update-alternatives: Linking //bin/run-parts to busybox
update-alternatives: Linking //sbin/start-stop-daemon to ../bin/busybox
update-alternatives: Linking //usr/bin/which to ../../bin/busybox
update-alternatives: Linking //bin/chattr to busybox
update-alternatives: Linking //sbin/fsck to ../bin/busybox
update-alternatives: Linking //usr/bin/awk to ../../bin/busybox
update-alternatives: Linking //usr/bin/cmp to ../../bin/busybox
update-alternatives: Linking //usr/bin/diff to ../../bin/busybox
update-alternatives: Linking //usr/bin/patch to ../../bin/busybox
update-alternatives: Linking //bin/sed to busybox
update-alternatives: Linking //bin/vi to busybox
update-alternatives: Linking //usr/bin/find to ../../bin/busybox
update-alternatives: Linking //bin/grep to busybox
update-alternatives: Linking //bin/egrep to busybox
update-alternatives: Linking //bin/fgrep to busybox
update-alternatives: Linking //usr/bin/xargs to ../../bin/busybox
update-alternatives: Linking //sbin/bootchartd to ../bin/busybox
update-alternatives: Linking //sbin/halt to halt.sysvinit
update-alternatives: Linking //sbin/poweroff to poweroff.sysvinit
update-alternatives: Linking //sbin/reboot to reboot.sysvinit
update-alternatives: Linking //sbin/init to /sbin/init.sysvinit
update-alternatives: Linking //linuxrc to /bin/busybox
update-alternatives: Error: cannot register alternative addgroup to /usr/sbin/addgroup since it is already registered to /bin/addgroup
update-alternatives: Error: cannot register alternative adduser to /usr/sbin/adduser since it is already registered to /bin/adduser
update-alternatives: Linking //usr/sbin/chpasswd to ../../bin/busybox
update-alternatives: Linking //usr/bin/cryptpw to ../../bin/busybox
update-alternatives: Linking //usr/bin/mkpasswd to ../../bin/busybox
update-alternatives: Error: cannot register alternative deluser to /usr/sbin/deluser since it is already registered to /bin/deluser
update-alternatives: Error: cannot register alternative delgroup to /usr/sbin/delgroup since it is already registered to /bin/delgroup
update-alternatives: Linking //sbin/getty to ../bin/busybox
update-alternatives: Linking //bin/login to busybox
update-alternatives: Linking //usr/bin/passwd to ../../bin/busybox
update-alternatives: Linking //bin/su to busybox
update-alternatives: Linking //sbin/sulogin to ../bin/busybox
update-alternatives: Linking //usr/bin/vlock to ../../bin/busybox
update-alternatives: Linking //usr/bin/beep to ../../bin/busybox
update-alternatives: Linking //bin/conspy to busybox
update-alternatives: Linking //usr/bin/dc to ../../bin/busybox
update-alternatives: Linking //sbin/fbsplash to ../bin/busybox
update-alternatives: Error: not linking //usr/sbin/i2cget to ../../bin/busybox since //usr/sbin/i2cget exists and is not a link
update-alternatives: Error: not linking //usr/sbin/i2cset to ../../bin/busybox since //usr/sbin/i2cset exists and is not a link
update-alternatives: Error: not linking //usr/sbin/i2cdump to ../../bin/busybox since //usr/sbin/i2cdump exists and is not a link
update-alternatives: Error: not linking //usr/sbin/i2cdetect to ../../bin/busybox since //usr/sbin/i2cdetect exists and is not a link
update-alternatives: Linking //usr/bin/less to /usr/bin/less.less
update-alternatives: Linking //usr/bin/lsscsi to ../../bin/busybox
update-alternatives: Linking //sbin/makedevs to /sbin/makedevs.makedevs
update-alternatives: Linking //usr/bin/microcom to ../../bin/busybox
update-alternatives: Linking //usr/sbin/partprobe to ../../bin/busybox
update-alternatives: Linking //bin/setserial to busybox
update-alternatives: Linking //usr/bin/strings to ../../bin/busybox
update-alternatives: Linking //usr/bin/time to ../../bin/busybox
update-alternatives: Linking //usr/sbin/ubiattach to ../../bin/busybox
update-alternatives: Linking //usr/sbin/ubidetach to ../../bin/busybox
update-alternatives: Linking //usr/sbin/ubimkvol to ../../bin/busybox
update-alternatives: Linking //usr/sbin/ubirmvol to ../../bin/busybox
update-alternatives: Linking //usr/sbin/ubirsvol to ../../bin/busybox
update-alternatives: Linking //usr/sbin/ubiupdatevol to ../../bin/busybox
update-alternatives: Linking //usr/sbin/ubirename to ../../bin/busybox
update-alternatives: Linking //usr/bin/volname to ../../bin/busybox
update-alternatives: Linking //sbin/modinfo to /sbin/modinfo.26
update-alternatives: Linking //usr/sbin/ftpd to ../../bin/busybox
update-alternatives: Linking //bin/dnsdomainname to busybox
update-alternatives: Linking //bin/hostname to busybox
update-alternatives: Linking //sbin/ifconfig to ../bin/busybox
update-alternatives: Error: cannot register alternative ifplugd to /usr/sbin/ifplugd since it is already registered to /usr/bin/ifplugd
update-alternatives: Linking //sbin/ifup to ../bin/busybox
update-alternatives: Linking //sbin/ifdown to ../bin/busybox
update-alternatives: Error: cannot register alternative ip to /sbin/ip since it is already registered to /bin/ip
update-alternatives: Linking //sbin/ipneigh to ../bin/busybox
update-alternatives: Linking //usr/sbin/nbd-client to ../../bin/busybox
update-alternatives: Linking //usr/bin/nc to ../../bin/busybox
update-alternatives: Linking //bin/netstat to busybox
update-alternatives: Linking //usr/bin/nslookup to ../../bin/busybox
update-alternatives: Linking //usr/sbin/ntpd to ../../bin/busybox
update-alternatives: Linking //bin/ping to busybox
update-alternatives: Linking //bin/ping6 to busybox
update-alternatives: Linking //usr/bin/pscan to ../../bin/busybox
update-alternatives: Linking //sbin/route to ../bin/busybox
update-alternatives: Linking //usr/bin/ssl_client to ../../bin/busybox
update-alternatives: Linking //usr/bin/telnet to ../../bin/busybox
update-alternatives: Linking //usr/bin/tftp to ../../bin/busybox
update-alternatives: Linking //usr/bin/traceroute to ../../bin/busybox
update-alternatives: Linking //usr/bin/traceroute6 to ../../bin/busybox
update-alternatives: Linking //sbin/tunctl to ../bin/busybox
update-alternatives: Linking //usr/bin/whois to ../../bin/busybox
update-alternatives: Linking //usr/bin/free to ../../bin/busybox
update-alternatives: Linking //usr/bin/fuser to ../../bin/busybox
update-alternatives: Linking //bin/iostat to busybox
update-alternatives: Linking //bin/kill to busybox
update-alternatives: Linking //usr/bin/killall to ../../bin/busybox
update-alternatives: Linking //usr/bin/lsof to ../../bin/busybox
update-alternatives: Linking //bin/mpstat to busybox
update-alternatives: Linking //usr/bin/pgrep to ../../bin/busybox
update-alternatives: Linking //usr/bin/pkill to ../../bin/busybox
update-alternatives: Linking //bin/pidof to pidof.sysvinit
update-alternatives: Linking //usr/bin/pmap to ../../bin/busybox
update-alternatives: Error: cannot register alternative powertop to /usr/sbin/powertop since it is already registered to /bin/powertop
update-alternatives: Linking //bin/ps to busybox
update-alternatives: Linking //usr/bin/pstree to ../../bin/busybox
update-alternatives: Linking //usr/bin/pwdx to ../../bin/busybox
update-alternatives: Linking //usr/bin/smemcap to ../../bin/busybox
update-alternatives: Linking //sbin/sysctl to ../bin/busybox
update-alternatives: Linking //usr/bin/top to ../../bin/busybox
update-alternatives: Linking //usr/bin/uptime to ../../bin/busybox
update-alternatives: Linking //bin/watch to busybox
update-alternatives: Linking //usr/bin/svc to ../../bin/busybox
update-alternatives: Linking //bin/ash to busybox
update-alternatives: Linking //bin/sh to busybox
update-alternatives: Linking //bin/bash to busybox
update-alternatives: Linking //sbin/klogd to ../bin/busybox
update-alternatives: Linking //usr/bin/logger to ../../bin/busybox
update-alternatives: Linking //sbin/logread to ../bin/busybox
update-alternatives: Linking //sbin/syslogd to ../bin/busybox
update-alternatives: Linking //sbin/acpid to ../bin/busybox
update-alternatives: Linking //sbin/blkid to ../bin/busybox
update-alternatives: Linking //sbin/blockdev to ../bin/busybox
update-alternatives: Linking //bin/dmesg to busybox
update-alternatives: Linking //usr/bin/fallocate to ../../bin/busybox
update-alternatives: Linking //bin/fatattr to busybox
update-alternatives: Linking //usr/sbin/fbset to ../../bin/busybox
update-alternatives: Linking //sbin/fdisk to ../bin/busybox
update-alternatives: Linking //usr/bin/flock to ../../bin/busybox
update-alternatives: Linking //sbin/freeramdisk to ../bin/busybox
update-alternatives: Linking //sbin/fsck.minix to ../bin/busybox
update-alternatives: Linking //usr/sbin/fsfreeze to ../../bin/busybox
update-alternatives: Linking //sbin/fstrim to ../bin/busybox
update-alternatives: Linking //bin/getopt to busybox
update-alternatives: Linking //usr/bin/hexdump to ../../bin/busybox
update-alternatives: Linking //usr/bin/xxd to ../../bin/busybox
update-alternatives: Linking //sbin/hwclock to ../bin/busybox
update-alternatives: Linking //bin/ionice to busybox
update-alternatives: Linking //usr/bin/last to last.sysvinit
update-alternatives: Linking //sbin/losetup to ../bin/busybox
update-alternatives: Linking //usr/bin/lspci to ../../bin/busybox
update-alternatives: Linking //usr/bin/lsusb to ../../bin/busybox
update-alternatives: Linking //sbin/mdev to ../bin/busybox
update-alternatives: Linking //sbin/mke2fs to ../bin/busybox
update-alternatives: Linking //sbin/mkfs.ext2 to ../bin/busybox
update-alternatives: Linking //sbin/mkfs.minix to ../bin/busybox
update-alternatives: Linking //sbin/mkdosfs to ../bin/busybox
update-alternatives: Linking //sbin/mkfs.vfat to ../bin/busybox
update-alternatives: Linking //sbin/mkswap to ../bin/busybox
update-alternatives: Linking //bin/more to busybox
update-alternatives: Linking //bin/mount to busybox
update-alternatives: Linking //sbin/pivot_root to ../bin/busybox
update-alternatives: Linking //usr/sbin/rdate to ../../bin/busybox
update-alternatives: Linking //usr/sbin/rdev to ../../bin/busybox
update-alternatives: Linking //usr/sbin/readprofile to ../../bin/busybox
update-alternatives: Linking //usr/bin/renice to ../../bin/busybox
update-alternatives: Linking //bin/rev to busybox
update-alternatives: Error: cannot register alternative rtcwake to /usr/sbin/rtcwake since it is already registered to /usr/bin/rtcwake
update-alternatives: Linking //bin/scriptreplay to busybox
update-alternatives: Linking //bin/linux32 to busybox
update-alternatives: Linking //bin/linux64 to busybox
update-alternatives: Linking //bin/setpriv to busybox
update-alternatives: Linking //sbin/swapon to ../bin/busybox
update-alternatives: Linking //sbin/swapoff to ../bin/busybox
update-alternatives: Linking //sbin/switch_root to ../bin/busybox
update-alternatives: Linking //sbin/uevent to ../bin/busybox
update-alternatives: Linking //bin/umount to busybox
update-alternatives: Linking //usr/bin/unshare to ../../bin/busybox
update-alternatives: Linking //usr/bin/wall to wall.sysvinit
update-alternatives: Linking //sbin/udhcpc to ../bin/busybox
update-alternatives: Linking //usr/sbin/udhcpd to ../../bin/busybox
update-alternatives: Linking //usr/sbin/dhcprelay to ../../bin/busybox
update-alternatives: Linking //usr/bin/dumpleases to ../../bin/busybox
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/busybox-1.27.2-r4/busybox-mountall_1.27.2-r4_qb2.ipk.
Installing busybox-mountall (1.27.2-r4) to root...
Configuring busybox-mountall.
update-alternatives: Linking //etc/default/mountall to mountall.busybox
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/busybox-1.27.2-r4/busybox-syslog_1.27.2-r4_qb2.ipk.
Installing busybox-syslog (1.27.2-r4) to root...
Configuring busybox-syslog.
update-alternatives: Linking //etc/init.d/syslog to syslog.busybox
update-rc.d: /etc/init.d/syslog exists during rc.d purge (continuing)
 Removing any system startup links for syslog ...
  /etc/rc0.d/K90syslog
  /etc/rc1.d/K90syslog
  /etc/rc2.d/S20syslog
  /etc/rc3.d/S20syslog
  /etc/rc4.d/S20syslog
  /etc/rc5.d/S20syslog
  /etc/rc6.d/K90syslog
 Adding system startup for /etc/init.d/syslog.
Starting syslogd/klogd: /sbin/syslogd is already running
667
Everything done! You should reboot now! But before that take some time to check if your /etc/passwd file is still valid (contains encrypted password for user root) and if /etc/default/iptables.conf is not blocking SSH access.
as you can see everything worked out fine, got my tiles firewall and passwd after the upgrade plus i got my complete tiles for the zon so now i`m more then happy , cant wait for the sun to shine tomorrow.
Post by TheHogNL »
Thanks for running it and posting the complete output! I see that it went fine. However toonstore failed to install due to a process wat was not running.
Is toonstore working correctly and can you access you Toon via the browser?
If not try to reinstall toonstore:
opkg install http://files.domoticaforum.eu/uploads/Toon/apps//toonstore-1.1.4/toonstore_1.1.4-r0_qb2.ipk
balans
Post by balans »
Toonstore is there i did not try to remove or install any will try that tomorrow i`m off this weekend
Post by TheHogNL »
Ok if toonstore is working don't touch it anymore :P
michel30
Post by michel30 »
@ TheHogNL
I am using the upgrade scrip 2.0 on my TOON I see REBOOTING with circle and my log file is stopped here:
/tmp/update.status.vars: Installing 96% (168/171) hcb-config
Upgrading hcb-watchdog on root from 1.69-master to 1.71-master...
Copying /mnt/data/update/hcb-watchdog_1.71-master_qb2.ipk.
update-rc.d: /etc/init.d/samba exists during rc.d purge (continuing)
 Removing any system startup links for samba ...
Updating certificates in /etc/ssl/certs...
1 added, 0 removed; done.
Running hooks in /etc/ca-certificates/update.d...
done.
0 added, 0 removed; done.
done.
done.
* Installing -dist files
   Installing /etc/timezone, -dist identical, so removed
* Installing -override files
   Installing /etc/init.d/functions.hae, from -override, identical
   Installing /etc/init.d/banner, from -override, identical
   Installing /etc/samba/smb.conf, from -override, identical
* Regenerating '/etc/modules' & '/etc/init.d/modutils.sh start' them too
Loading modules: snd-soc-ecr2-aic3100 snd-soc-ecr2-ed20-aic3100 snd-pcm-oss rtl8191su rt5370sta
QIconvCodec::convertToUnicode: using Latin-1 for conversion, iconv_open failed
QIconvCodec::convertFromUnicode: using Latin-1 for conversion, iconv_open failed
Updating '/qmf/qml/qb/lang/lang_fr_BE.qm'...
    Generated 88 translation(s) (88 finished and 0 unfinished)
Updating '/qmf/qml/qb/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/qb/lang/lang_es_ES.qm'...
Updating '/qmf/qml/qb/lang/lang_en_GB.qm'...
Updating '/qmf/qml/qb/lang/lang_it_IT.qm'...
    Generated 87 translation(s) (87 finished and 0 unfinished)
    Ignored 1 untranslated source text(s)
Updating '/qmf/qml/qb/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/qb/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_fr_BE.qm'...
    Generated 43 translation(s) (43 finished and 0 unfinished)
    Ignored 6 untranslated source text(s)
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_fr_FR.qm'...
    Generated 40 translation(s) (40 finished and 0 unfinished)
    Ignored 9 untranslated source text(s)
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_es_ES.qm'...
    Generated 41 translation(s) (41 finished and 0 unfinished)
    Ignored 8 untranslated source text(s)
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_en_GB.qm'...
    Generated 49 translation(s) (49 finished and 0 unfinished)
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/domesticHotWater/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/settings/lang/lang_fr_BE.qm'...
    Generated 2 translation(s) (2 finished and 0 unfinished)
Updating '/qmf/qml/apps/settings/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/settings/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/settings/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/settings/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/settings/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/settings/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/traffic/lang/lang_fr_BE.qm'...
    Generated 13 translation(s) (13 finished and 0 unfinished)
Updating '/qmf/qml/apps/traffic/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/traffic/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/traffic/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/traffic/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/traffic/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/traffic/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_fr_BE.qm'...
    Generated 1 translation(s) (1 finished and 0 unfinished)
    Ignored 101 untranslated source text(s)
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_en_GB.qm'...
    Generated 102 translation(s) (102 finished and 0 unfinished)
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/boilerMonitor/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/homescreen/lang/lang_fr_BE.qm'...
    Generated 18 translation(s) (18 finished and 0 unfinished)
Updating '/qmf/qml/apps/homescreen/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/homescreen/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/homescreen/lang/lang_en_GB.qm'...
    Generated 19 translation(s) (19 finished and 0 unfinished)
Updating '/qmf/qml/apps/homescreen/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/homescreen/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/homescreen/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/weather/lang/lang_fr_BE.qm'...
    Generated 24 translation(s) (23 finished and 1 unfinished)
    Ignored 59 untranslated source text(s)
Updating '/qmf/qml/apps/weather/lang/lang_fr_FR.qm'...
    Generated 67 translation(s) (66 finished and 1 unfinished)
    Ignored 16 untranslated source text(s)
Updating '/qmf/qml/apps/weather/lang/lang_en_GB.qm'...
    Generated 83 translation(s) (82 finished and 1 unfinished)
Updating '/qmf/qml/apps/weather/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/weather/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/weather/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/weatherInt/lang/lang_fr_BE.qm'...
    Generated 45 translation(s) (45 finished and 0 unfinished)
Updating '/qmf/qml/apps/weatherInt/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/weatherInt/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/weatherInt/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/weatherInt/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/weatherInt/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/weatherInt/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_fr_BE.qm'...
    Generated 277 translation(s) (277 finished and 0 unfinished)
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_es_ES.qm'...
    Generated 273 translation(s) (273 finished and 0 unfinished)
    Ignored 5 untranslated source text(s)
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_it_IT.qm'...
    Generated 256 translation(s) (256 finished and 0 unfinished)
    Ignored 22 untranslated source text(s)
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/eMetersSettings/lang/lang_nl_NL.qm'...
    Generated 278 translation(s) (278 finished and 0 unfinished)
Updating '/qmf/qml/apps/controlPanel/lang/lang_fr_BE.qm'...
    Generated 179 translation(s) (179 finished and 0 unfinished)
    Ignored 14 untranslated source text(s)
Updating '/qmf/qml/apps/controlPanel/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/controlPanel/lang/lang_es_ES.qm'...
    Generated 178 translation(s) (178 finished and 0 unfinished)
    Ignored 15 untranslated source text(s)
Updating '/qmf/qml/apps/controlPanel/lang/lang_en_GB.qm'...
    Generated 193 translation(s) (192 finished and 1 unfinished)
Updating '/qmf/qml/apps/controlPanel/lang/lang_it_IT.qm'...
    Generated 165 translation(s) (165 finished and 0 unfinished)
    Ignored 28 untranslated source text(s)
Updating '/qmf/qml/apps/controlPanel/lang/lang_nl_BE.qm'...
    Generated 193 translation(s) (193 finished and 0 unfinished)
Updating '/qmf/qml/apps/controlPanel/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/customerService/lang/lang_fr_BE.qm'...
    Generated 10 translation(s) (10 finished and 0 unfinished)
Updating '/qmf/qml/apps/customerService/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/customerService/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/customerService/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/customerService/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/customerService/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/customerService/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/statusUsage/lang/lang_fr_BE.qm'...
    Generated 83 translation(s) (83 finished and 0 unfinished)
Updating '/qmf/qml/apps/statusUsage/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/statusUsage/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/statusUsage/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/statusUsage/lang/lang_it_IT.qm'...
    Generated 22 translation(s) (22 finished and 0 unfinished)
    Ignored 61 untranslated source text(s)
Updating '/qmf/qml/apps/statusUsage/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/statusUsage/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/systemSettings/lang/lang_fr_BE.qm'...
    Generated 148 translation(s) (148 finished and 0 unfinished)
Updating '/qmf/qml/apps/systemSettings/lang/lang_fr_FR.qm'...
    Generated 148 translation(s) (136 finished and 12 unfinished)
Updating '/qmf/qml/apps/systemSettings/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/systemSettings/lang/lang_en_GB.qm'...
    Generated 147 translation(s) (135 finished and 12 unfinished)
Updating '/qmf/qml/apps/systemSettings/lang/lang_it_IT.qm'...
    Generated 126 translation(s) (122 finished and 4 unfinished)
Updating '/qmf/qml/apps/systemSettings/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/systemSettings/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/clock/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/clock/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/clock/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/clock/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/clock/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/clock/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/clock/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/graph/lang/lang_fr_BE.qm'...
    Ignored 3 untranslated source text(s)
Updating '/qmf/qml/apps/graph/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/graph/lang/lang_es_ES.qm'...
    Generated 86 translation(s) (86 finished and 0 unfinished)
Updating '/qmf/qml/apps/graph/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/graph/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/graph/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/graph/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/inbox/lang/lang_fr_BE.qm'...
    Generated 6 translation(s) (6 finished and 0 unfinished)
    Ignored 2 untranslated source text(s)
Updating '/qmf/qml/apps/inbox/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/inbox/lang/lang_es_ES.qm'...
    Generated 8 translation(s) (8 finished and 0 unfinished)
Updating '/qmf/qml/apps/inbox/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/inbox/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/inbox/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/inbox/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/benchmark/lang/lang_fr_BE.qm'...
    Generated 217 translation(s) (217 finished and 0 unfinished)
Updating '/qmf/qml/apps/benchmark/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/benchmark/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/benchmark/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/benchmark/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/benchmark/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/benchmark/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/solar/lang/lang_fr_BE.qm'...
    Generated 38 translation(s) (38 finished and 0 unfinished)
Updating '/qmf/qml/apps/solar/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/solar/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/solar/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/solar/lang/lang_it_IT.qm'...
    Generated 37 translation(s) (37 finished and 0 unfinished)
Updating '/qmf/qml/apps/solar/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/solar/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/smokeDetector/lang/lang_fr_BE.qm'...
    Generated 117 translation(s) (117 finished and 0 unfinished)
    Ignored 7 untranslated source text(s)
Updating '/qmf/qml/apps/smokeDetector/lang/lang_fr_FR.qm'...
    Generated 114 translation(s) (114 finished and 0 unfinished)
    Ignored 10 untranslated source text(s)
Updating '/qmf/qml/apps/smokeDetector/lang/lang_en_GB.qm'...
    Generated 124 translation(s) (124 finished and 0 unfinished)
Updating '/qmf/qml/apps/smokeDetector/lang/lang_it_IT.qm'...
    Generated 113 translation(s) (113 finished and 0 unfinished)
    Ignored 11 untranslated source text(s)
Updating '/qmf/qml/apps/smokeDetector/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/smokeDetector/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/thermostat.back/lang/lang_fr_BE.qm'...
    Generated 84 translation(s) (84 finished and 0 unfinished)
Updating '/qmf/qml/apps/thermostat.back/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/thermostat.back/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/thermostat.back/lang/lang_en_GB.qm'...
    Generated 90 translation(s) (90 finished and 0 unfinished)
Updating '/qmf/qml/apps/thermostat.back/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/thermostat.back/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/thermostat.back/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/thermostat/lang/lang_fr_BE.qm'...
    Generated 89 translation(s) (89 finished and 0 unfinished)
Updating '/qmf/qml/apps/thermostat/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/thermostat/lang/lang_es_ES.qm'...
    Ignored 21 untranslated source text(s)
Updating '/qmf/qml/apps/thermostat/lang/lang_en_GB.qm'...
    Generated 103 translation(s) (103 finished and 0 unfinished)
Updating '/qmf/qml/apps/thermostat/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/thermostat/lang/lang_nl_BE.qm'...
    Generated 104 translation(s) (104 finished and 0 unfinished)
Updating '/qmf/qml/apps/thermostat/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/heatRecovery/lang/lang_nl_NL.qm'...
    Generated 32 translation(s) (32 finished and 0 unfinished)
Updating '/qmf/qml/apps/winwit/lang/lang_fr_BE.qm'...
    Generated 4 translation(s) (4 finished and 0 unfinished)
Updating '/qmf/qml/apps/winwit/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/winwit/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/winwit/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/winwit/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/winwit/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/winwit/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/installWizard/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/installWizard/lang/lang_fr_FR.qm'...
    Generated 8 translation(s) (0 finished and 8 unfinished)
Updating '/qmf/qml/apps/installWizard/lang/lang_es_ES.qm'...
Updating '/qmf/qml/apps/installWizard/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/installWizard/lang/lang_it_IT.qm'...
    Generated 0 translation(s) (0 finished and 0 unfinished)
Updating '/qmf/qml/apps/installWizard/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/installWizard/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/internetSettings/lang/lang_fr_BE.qm'...
    Generated 125 translation(s) (124 finished and 1 unfinished)
Updating '/qmf/qml/apps/internetSettings/lang/lang_fr_FR.qm'...
    Generated 125 translation(s) (92 finished and 33 unfinished)
Updating '/qmf/qml/apps/internetSettings/lang/lang_es_ES.qm'...
    Generated 125 translation(s) (125 finished and 0 unfinished)
Updating '/qmf/qml/apps/internetSettings/lang/lang_en_GB.qm'...
    Generated 128 translation(s) (95 finished and 33 unfinished)
Updating '/qmf/qml/apps/internetSettings/lang/lang_it_IT.qm'...
    Generated 75 translation(s) (69 finished and 6 unfinished)
    Ignored 55 untranslated source text(s)
Updating '/qmf/qml/apps/internetSettings/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/internetSettings/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/imageViewer/lang/lang_fr_BE.qm'...
Updating '/qmf/qml/apps/imageViewer/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/imageViewer/lang/lang_en_GB.qm'...
Updating '/qmf/qml/apps/imageViewer/lang/lang_it_IT.qm'...
Updating '/qmf/qml/apps/imageViewer/lang/lang_nl_BE.qm'...
Updating '/qmf/qml/apps/imageViewer/lang/lang_nl_NL.qm'...
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_fr_BE.qm'...
    Generated 162 translation(s) (162 finished and 0 unfinished)
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_fr_FR.qm'...
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_es_ES.qm'...
    Generated 81 translation(s) (81 finished and 0 unfinished)
    Ignored 81 untranslated source text(s)
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_en_GB.qm'...
    Generated 153 translation(s) (153 finished and 0 unfinished)
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_it_IT.qm'...
    Generated 72 translation(s) (72 finished and 0 unfinished)
    Ignored 90 untranslated source text(s)
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_nl_BE.qm'...
    Generated 150 translation(s) (150 finished and 0 unfinished)
    Ignored 12 untranslated source text(s)
Updating '/qmf/qml/apps/thermostatSettings/lang/lang_nl_NL.qm'...
Succesfully loaded 15 items to be translated
/tmp/update.status.vars: Installing 100% (171/171) hcb-watchdog
Configuring libhcb-xml.
Configuring libhcb-boxtalk.
Configuring libhcb-com.
Configuring libhcb-base.
Configuring libhcb-drv.
Configuring hcb-netcon.
Configuring happ-pwrusage.
Configuring happ-kpi.
Configuring hcb-comm.
Configuring www-resources.
Configuring tenant-eneco-nl.
Configuring firmware-ma.
Configuring happ-scsync.
Configuring hdrv-zwave.
Configuring hdrv-p1.
Configuring hdrv-hue.
Configuring happ-thermstat.
Configuring happ-usermsg.
Configuring qt-gui.
Configuring hcb-bxtproxy.
Configuring happ-eventmgr.
Configuring happ-smartplug.
Configuring happ-weather.
Configuring hcb-config.
Configuring hcb-log.
Configuring hcb-watchdog.
Configuring base-qb2-uni.
>> exitcode for opkg --cache /mnt/data/update upgrade was 0
>> Removing /etc/rcS.d/S40upgrade-execute-resume.sh
>> Checking if these packages are not installed: hcb-upnp hcb-core hcb-web flash-gui flash-qwidget-diy flash-lite-adobe
checking hcb-upnp
checking hcb-core
checking hcb-web
checking flash-gui
removing flash-gui as it is no longer depended upon by base package and it isn't removed.
Removing package flash-gui from root...
checking flash-qwidget-diy
removing flash-qwidget-diy as it is no longer depended upon by base package and it isn't removed.
Removing package flash-qwidget-diy from root...
checking flash-lite-adobe
removing flash-lite-adobe as it is no longer depended upon by base package and it isn't removed.
Removing package flash-lite-adobe from root...
>> upgrade OK: removing package cache files...
HCBv2 apps started via runlvls, preparing startables for next boot.
HCBv2 adding: comm eventmgr kpi pwrusage scsync smartplug thermstat usermsg weather bxtproxy config log rrd watchdog hue p1 zwave lighttpd.
HCBv2 startables unchanged, not writing /etc/inittab.
>> Done, scheduling reboot in 2 secs...
>> 2018-04-02 11:33:43 +0000 (pid 22984) executed
>> 2018-04-02 11:33:43 +0000 (pid 22984) exit-0 upgrade-qb2.sh qb2 uni 4.13.7 execute
What now? is the upgrade finish and can I do an reboot?
Post by TheHogNL »
michel30 wrote: What now? is the upgrade finish and can I do an reboot?
This is the output from the "tail -f /mnt/data/update/upgrade-qb2.sh.log" and it indeed shows that the upgrade has finished.
However I'm missing the output from the main script (my update-rooted.sh 2.0 script). It will continu running some other commands just after this upgrade is done, like restoring your iptables etc.
What does that script say? Or did you reboot already fine (as my post is 3 hours laters than your post)
michel30
Post by michel30 »
indeed "tail -f /mnt/data/update/upgrade-qb2.sh.log" is the log file that was open.
The other one, where I run update-rooted.sh was doing nothing, so I wait for one hour and I hit on enter and it was disconnected from Toon.
I logged back in and I give the command reboot because on the display from the Toon is was still running circles.
After the Reboot I logged back in ( I build some safe options in it ) like every time when I do an reboot it will write the 2 login files.
When the Toon came back online I had to install the ToonStore manual so it looks like it did not installed everything automatic after the upgrade.
For the future is it also possible to run something in screen?
Where can I found the log file for update-rooted.sh?
Toon is now running on version 4.13.7 and it looks like that everything is still working okay.
Post by TheHogNL »
OK thanks for your info. Probably the main script got kill by a out-of-memory process. You are the first one to see this happen.
However it did run after the upgrade because your iptables where working fine. Or do you have the crontab @ reboot restore iptables file mod?
I'm looking into putting more info on the screen and output from the main script.
michel30
Post by michel30 »
Hello
I have have the crontab @ reboot restore iptables file mod and passwd.
When my connection was disconnected and I try to run your scrip again it was saying I am already on 4.13.7 so I give my toon the command reboot.
I think the crontab safe my problem with the reboot to restore these two files.
Post by TheHogNL »
Thanks for letting me know. Yes probably your crontab saved your SSH login. Without that you would be connecting your Toon again to the console output as described in the rooting manual and restoring the iptables.
I will try to make this even more monkey proof. Thinking about a restarting procedure of the script when it detects it is rebooten without ending properly.
RDNZL
Post by RDNZL »
Hello TheHog, after having this topic bookmarked for weeks, I finally tried it on a spare Toon.
It worked great, thanks!
Some minor issues I saw, maybe you can use them to make the script even better:
1. version mentioned
I was at 3.2.18, it said to upgrade to 4.10.16 first which didn't exist, tried 4.10.6 (typo?)
You are currently running version 3.2.18
Which version do you want to upgrade to? You can look at the list of currently known Toon versions at https://notepad.pw/raw/6fmm2o8ev
4.13.7
You need to upgrade to 4.10.16 first!
4.10.16
Please enter a valid version!
4.10.6
2 find syntax errors
Got a few of these..
+ find /qmf/config/ -ls
find: unrecognized: -ls
BusyBox v1.27.2 (2017-10-03 14:20:01 CEST) multi-call binary.
Usage: find [-HL] [PATH]... [OPTIONS] [ACTIONS]
3 automatic reboot didn't work
>> 2018-04-03 16:28:00 +0000 (pid 6019) executed
>> 2018-04-03 16:28:00 +0000 (pid 6019) exit-0 upgrade-qb2.sh qb2 ene 4.10.6 execute
I had to type 'reboot' manually
After this I did an upgrade from 4.10.6 to 4.13.7 successfully, thanks again!
Regards, Ron.
Post by TheHogNL »
RDNZL wrote: I was at 3.2.18, it said to upgrade to 4.10.16 first which didn't exist, tried 4.10.6 (typo?)
Thanks. Typo indeed. Fixed in next release.
RDNZL wrote: 2 find syntax errors
This isn't part of my script. Probably in the output of the Eneco upgrade script which is started. Can't do anything about their mistakes :)
This is also part of the Eneco upgrade script. The output from the tail command. From this point my script will continu and restore some files. Maybe I need to remove the 'tail -f' message because that confuses people. It is only there to check the progress of the real upgrade but you need to follow the output from my script only.
RDNZL wrote: After this I did an upgrade from 4.10.6 to 4.13.7 successfully, thanks again!
No problem! Most work goes to Eneco for providing us the updates. I have only build a interface around their upgrade environment so that our rooted Toons stay rooted when a upgrade is done.
RDNZL
Post by RDNZL »
Thanks for the reply, after the upgrade to 4.13.7 I seem to be a bit stuck in the 'installatie wizard' I have only the temp and +/0 buttons active, and need to add functionality by running it.
But I only see this, no idea how to select energiemeters or overrule the wizard to get the normal screen again with the basic toon features?
Regards, Ron.
Return to “Toon Firmware”
