Toon firmware - update script
RomMon
Post by RomMon »
@TheHogNL
Maybe not an enforcing check but e.g.
if [ "$lastKnownHash" -eq "$dlScripHash" ]; then
continue upgrade without warning
else
echo "Warning: The script you downloaded has changed from the verified script. Please only continue after confirming the changes are ok."
only continue if user gives ok
fi
Post by TheHogNL »
Good idea. I'll do that in the next update.
jnieuw
Post by jnieuw »
Just wanted to thank you for the script.
Upgraded from 4.8.25 to 4.10.6 and then to 4.13.7! :D
hansgrave
Post by hansgrave »
After a succesfull update to 4.10.6 now my Toon hangs after a reboot to update to 4.13.7 .... I can acces the Toon with ssh, how can i solve this problem?
Homey, rooted Toon 1 and HomeAssistent.
Post by TheHogNL »
By hangs you mean the screen keeps on his orange 'TOON' display?
If yes, it's the QT-GUI that is not starting due to an error.
Try starting the GT-GUI with logging enabled. Change this in /etc/inittab and reboot.
normal:
qtqt:245:respawn:/usr/bin/startqt >/dev/null 2>&1
change to:
qtqt:245:respawn:/usr/bin/startqt >/var/log/qt 2>&1
You could read the /var/log/qt then after rebooting (for example "tail -f /var/log/qt") and hopefully find the error why qt-gui isn't starting
hansgrave
Post by hansgrave »
TheHogNL wrote:By hangs you mean the screen keeps on his orange 'TOON' display?
normal:
change to:
I changed the the file and reboot several times, at this time i have no longer have acces by ssh...
Post by TheHogNL »
hansgrave wrote:I changed the the file and reboot several times, at this time i have no longer have acces by ssh...
Weird. Just rebooting should not break your ssh access. Did the Toon change IP? Try to follow the 'how to root' manual again to gain console access and check what is going on.
FunFair
Post by FunFair »
Used the script to go from 4.9 to 4.13.
I thought it would make the upgrade in 1 time, but it seemed the script installed 4.10 first.
Had to open the openvpn connection to eneco servers first. But didn't have to uninstall Toonstore. That's great.
Afterwards I had to disable the vpn connection again, cause it kept resetting the 'enddate' from -1 to something else.
Thanks for the work on this script! And opening another session with the logging file helped alot to see what was happening!
Post by TheHogNL »
"had to open the vpn first" ? The script does this for you and will also protect your Toon so your enddate will not be overwritten.
I think you used the Eneco upgrade-qb2.sh script manually and not thise update-rooted.sh script?
FunFair
Post by FunFair »
TheHogNL wrote:"had to open the vpn first" ? The script does this for you and will also protect your Toon so your enddate will not be overwritten.
I used v1.8 and it paused (I think) because it was waiting for the VPN to connect. Maybe I was just impatient.. I went in the inittab file and uncommented the VPN part.
I think the script continued on its own while I was doing this oops. I'll remember that for next time :)
BTW is it possible to update without the VPN connection? Someone in the domoticz forum asked me if that was possible. He has a rooted toon done by quby, but has no VPN data anymore. So he can't seem to update his toon with this script.
Post by TheHogNL »
The 'wait' moment was opening the vpn for you indeed. Just uncommenting the inittab does nothing without a reboot. But now I understand why your enddate changed because after the reboot you still had the openvpn uncommented resulting in the servicecenter from eneco to connect again and change the value.
Next time be more patient indeed. Maybe I need to change the text to be even more stupid proof :lol:
Updating the Toon from another source could be possible as it is just a bunch of files which are downloaded and then installed. However I am not planning to build that into the script as that might open the route to unsollicated software/mallware and I'm not sure copying the files to another server is legally allowed.
Fietspomp
Post by Fietspomp »
Tried your script today, but it can't download the update script, this is the outcome of the log:
Please be advised that running this script is to your own risk!
Version: 1.8 - ThehogNL - 8-3-2018
You are currently running version 3.2.18
Which version do you want to upgrade to? You can look at the list of currently known Toon versions at https://notepad.pw/raw/6fmm2o8ev
4.10.6
Alright, I will try to upgrade to 4.10.6
Waiting for tunnel to be alive and configured...
Tunnel is alive and configured. Now trying to download upgrade script...
/mnt/data/update/upgrade-qb2.sh: No such file or directory
Could not download the upgrade script from the source. Exiting...
Root is working properly, tried it several times also after a reboot.
Any suggestions howto debug this?
EDIT: Fixed it, found that my mnt dir was empty.
So I changed location in your script
PKGCACHE='/HCBv2/tmp/opkg-cache'
if [ ! -d "$PKGCACHE" ]
then
fi
Probably a dirty change but it works :-)
Post by TheHogNL »
Yes I already changed that in another release which I'm building. Your Toon was already supporting the new directory /mnt/data/update but the old dir was still there. Causing the Eneco Upgrade to fail because it expects in in the new dir.
So the script uses the old dir. The new logic is that it uses the new dir if that dir is supported by the toon.
So the proper fix is:
PKGCACHE='/mnt/data/update'
if ! strings /HCBv2/sbin/hcb_config | grep -q -e "^${PKGCACHE}\$"
then
        #this toon still uses the old PKGCACHE
fi
Post by TheHogNL »
Thinking about this makes me me wonder if I need to create the directory if it doesn't exists. However, according to the upgrade script the /mnt/data/update dir should be automatically created upon booting of the toon
Fietspomp
Post by Fietspomp »
Just used your script for my own Toon (2nd hand now hanging on the wall :D ).
This has the latest firmware and old u-boot, works perfect as well!
Only manually installed latest busybox, using your payload files to transfer them.
So your script works fine for me!
Return to “Toon Firmware”
