Re: The new Toon 2 has been rooted!
Posted: Wed Jul 15, 2020 12:09 pm
by freddie
I just called Eneco (my current energy supplier) to order a Toon and they offered me the following:
Eneco KetelComfort Standaard (biyearly maintenance to the boiler / https://www.eneco.nl/energieproducten/cv-onderhoud/)
for a minimum of 12 months
for 8,95 euro/month
first 3 months for free
Total price: 80,55 euro (9 months * 8,95)
For this price I will receive boiler maintenance, a FREE Toon with installation and a Toon membership for 4,50 euro/month which can be cancelled within 30 days.
I've also added the 'Zon op Toon' module to track my solar panels for an additional on-time payment of 99,95 euro.
This looks like a good deal since I will not be tied down to Eneco for 4 years and the Toon normally costs 200 euro.
Now all I need is someone to help me root the Toon so I can unleash the full potential and use it with my Home Assistant setup. They are going to install my Toon in seven days, so after that I can send the Toon by post or visit one of you. I live near Utrecht. Anyone?
Posted: Thu Jul 16, 2020 2:54 pm
by TerrorSource
freddie wrote:I just called Eneco (my current energy supplier) to order a Toon and they offered me the following:
for 8,95 euro/month
Sure, send me a PM or contact me via Marktplaats https://link.marktplaats.nl/m1563338272
Does that 8,95 included the Toon 4,50 a month contract and you don't need an energy contract with Eneco? If you don't need an energy contract it looks like a pretty good deal
Btw. ask the mechanic who installs the ZonOpToon to put a Qubino Smart Meter in place for no extra charge ;) That's the digital z-wave version of the "simple" kwh-meter.
Posted: Thu Jul 16, 2020 4:21 pm
by freddie
TerrorSource wrote: Sure, send me a PM or contact me via Marktplaats https://link.marktplaats.nl/m1563338272
No, the 4,50 is extra and i assume that a contract with Eneco is mandatory. Nevertheless the monthly subscription for Toon can be cancelled. Maybe I can even avoid subscribing at all. I will contact you as soon as everything is installed. Thanks for the tip about the Qubino.
Posted: Thu Jul 16, 2020 6:41 pm
by timkoers
TerrorSource wrote: That's the digital z-wave version of the "simple" kwh-meter.
Will the ZonOpToon function wirelessly then?
Posted: Thu Jul 16, 2020 6:51 pm
by marcelr
timkoers wrote:Will the ZonOpToon function wirelessly then?
Yep. No hassle with optical sensors anymore.
Posted: Thu Jul 16, 2020 7:07 pm
by timkoers
Out of the box, on the Toon1?
I just started working out the idea of using two ESP-01's as a relay for the signal to transfer it down the house.
Posted: Thu Jul 16, 2020 8:08 pm
by TerrorSource
Yes. On Toon1 and Toon2.
Just connected mine yesterday. It works but Toon thinks that it’s an Analog sensor while it’s not. But he, it works.
Posted: Thu Jul 16, 2020 8:46 pm
by timkoers
TerrorSource wrote: Yes. On Toon1 and Toon2.
Cool!
But damn €135,-
Posted: Thu Jul 16, 2020 9:09 pm
by TerrorSource
Cool!
But damn €135,-
You can buy them cheaper but don't buy it at MaxICT.
Ps. I'll create a new topic to discuss this further (this is a topic for rooting Toon2)
EDIT: Separate topic: viewtopic.php?f=95&t=12857
ZonOpToon - Qubino Smart Meter
Posted: Thu Jul 16, 2020 9:20 pm
by TerrorSource
Created this topic to discuss the Qubino Smart Meter to use with solar panels - ZonOpToon.
Qubino Smart Meter is a digital meter for Kwh's on a group. This Qubino Smart Meter can be connected to a Z-wave controller and the Toon (as it is a Z-wave controller).
It replaces a analoge KWh-meter with an Analog cable.
This Qubino Smart Meter can be purchased from different webshops
See: https://tweakers.net/pricewatch/1373028 ... meter.html
(Warning, don't buy from MaxICT)
Posted: Thu Jul 16, 2020 9:22 pm
by TheHogNL
timkoers wrote: I just started working out the idea of using two ESP-01's as a relay for the signal to transfer it down the house.
I'm doing this for a few years already now. 3x ESP, two each on a inverter (have two seperate solar installations) and the third combining the numbers and presenting it to the meteradapter as pulses. Much cheaper than the qubino solution :)
Re: ZonOpToon - Qubino Smart Meter
Posted: Fri Jul 17, 2020 10:02 pm
by marcelr
Moved a bunch of posts from the toon 2 rooted thread to this one.
Posted: Mon Nov 02, 2020 10:06 pm
by Joco18
Hello i also installed the qubino 3 fase smart meter to connect with the toon for
my solar panels.
It works great but i have a question:
Does anybody know how to turn of the orange led2 (blinking).
It has to do with changing the parameter 100 but i don't know how to connect with the Z-wave Qubino
Thank you.
Greetings Jos
Posted: Wed Nov 04, 2020 9:28 am
by TheHogNL
Joco18 wrote:Hello i also installed the qubino 3 fase smart meter to connect with the toon for
my solar panels.
Thank you.
Greetings Jos
Don't have it myself but try on http://toon-ip/hdrv_zwave/
Posted: Mon Jan 11, 2021 9:35 pm
by Arnout2000
I am having an Envoy/Enphase solar system installed within a few months.
I want to install a 3 phase Qubino Smart Meter in order to see on my Toon Thermostat what power is delivered back to the grid.
Part of the Envoy system system is a Q-Relais module which disconnects the PV system in case of problems.
Is it correct that the Qubino Smart Meter needs to be installed directly after the Q-Relais?
