SolarBridge - For SolarEdge
Posted: Fri Sep 18, 2020 3:26 pm
Hi SolarEdge owners,
If you have a toon (hacked) you can feed your solaredge cloud data to ZonOpToon using a bridge that runs on a WEMOS D mini (3 USD). and a optocoupler (1 USD). The idea came from oepi-loepi who did this for a growatt convertor. Since SolarEdge exposes roughly the same data from the cloud (using a similar API) I decided to fork this project to a solaredge version. Please check this forum for more info:
viewtopic.php?f=95&t=12751
To build this project you will need platformio (free opensource IDE) which will build the binary and allows you to upload this to a WEMOS D mini. The bridge will expose as an AP (which has a catch portal that takes you to the config screen) you choose your WIFI and API credentials and thats it. The Wemos will query the API every minute and simulate pulse for the ENECO METER ADAPTER. This solution is handy if you have:
- A PV group (instead of a clean solar group in your house)
- No KWh meter in place
- No Eneco ZonOpToon HW
- Hacked Toon with ZonOpToon (which you can enable)
project file:
https://github.com/mvdbr4nd/solarbridge-solaredge
project file:
