Toon firmware - update script
Postby stijnpeeters » Tue Mar 12, 2019 10:48 pm
With your help i got it to work again:
perhaps my steps wil help someone else aswell:
created a VPN manually as informed by theHognl:
eneco-001-064929:~# /usr/sbin/openvpn --config /etc/openvpn/vpn.conf
Tue Mar 12 20:29:22 2019 DEPRECATED OPTION: --tls-remote, please update your configuration
Tue Mar 12 20:29:22 2019 OpenVPN 2.3.11 arm-hae-linux-gnueabi [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Nov 30 2016
Tue Mar 12 20:29:22 2019 library versions: OpenSSL 1.0.2h  3 May 2016, LZO 1.08
Tue Mar 12 20:29:22 2019 Control Channel Authentication: using '/etc/openvpn/vpn/ta.key' as a OpenVPN static key file
Tue Mar 12 20:29:22 2019 Attempting to establish TCP connection with [AF_INET]34.253.116.121:443 [nonblock]
Tue Mar 12 20:29:23 2019 TCP connection established with [AF_INET]34.253.116.121:443
Tue Mar 12 20:29:23 2019 TCPv4_CLIENT link local: [undef]
Tue Mar 12 20:29:23 2019 TCPv4_CLIENT link remote: [AF_INET]34.253.116.121:443
Tue Mar 12 20:29:25 2019 [VPN-Eneco] Peer Connection Initiated with [AF_INET]34.253.116.121:443
Tue Mar 12 20:29:27 2019 TUN/TAP device tap0 opened
Tue Mar 12 20:29:27 2019 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Tue Mar 12 20:29:27 2019 /sbin/ifconfig tap0 172.28.143.153 netmask 255.255.240.0 mtu 1500 broadcast 172.28.143.255
Tue Mar 12 20:29:27 2019 Initialization Sequence Completed
Run the script, kinda didn't work, or i don't use it correct
eneco-001-064929:~# echo `/sbin/ip route | /bin/grep ^172.*via.*tap0 | /usr/bin/
awk '{print $1}'| /usr/bin/awk 'BEGIN {FS="."}; {print $1"."$2"."$3}'`.1
-sh: /sbin/ip: not found
.1
eneco-001-064929:~# cd /sbin/
... but... the same commands manually gave the correct info from tap0:
manually looking for the grep it seems that is would be: 172.28.128.1
eneco-001-064929:/sbin# ip route
192.168.1.0/24 dev eth0 scope link  src 192.168.1.120
172.28.128.0/20 via 172.28.128.1 dev tap0
172.28.128.0/20 dev tap0 scope link  src 172.28.143.153
default via 192.168.1.254 dev eth0  metric 10
eneco-001-064929:/sbin# ping 172.28.128.1
PING 172.28.128.1 (172.28.128.1): 56 data bytes
64 bytes from 172.28.128.1: seq=0 ttl=64 time=77.141 ms
64 bytes from 172.28.128.1: seq=1 ttl=64 time=33.743 ms
so put that into etc/hosts file for .int
127.0.0.1     localhost.localdomain           localhost
172.23.16.1   feed.hae.orig           feed
172.28.128.1  feed.hae.int  feed
127.0.0.1     ping.quby.nl
test:
eneco-001-064929:/etc# ping feed.hae.int
PING feed.hae.int (172.28.128.1): 56 data bytes
64 bytes from 172.28.128.1: seq=0 ttl=64 time=36.642 ms
64 bytes from 172.28.128.1: seq=1 ttl=64 time=38.864 ms
but eventually it seemd that not .int has to be this ip address but feed.hae.orig.
after setting the ip to .orig; the command opkg update worked.
however: command opkg install base-qb2-uni gave an error:
so also tried opkg upgrade and let it run.
after this the command shows it;s up 2 date:
eneco-001-064929:~# opkg install base-qb2-uni
Package base-qb2-uni (5.0.4-1286-0) installed in root is up to date.
rebooted; no toon yet so rerun the update script:
eneco-001-064929:~# sh /root/update-rooted.sh -f
Version: 3.71  - TheHogNL & TerrorSource & yjb - 5-3-2019
Only fixing files.
creating backup of inittab...
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 5.0.4.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-2.1.2/toonstore_2.1.2-r0_qb2.ipk.
Installing toonstore (2.1.2-r0) to root...
Executing pre-install script for toonstore-2.1.2
Previous installation detected.
Creating backup for /qmf/etc/qmf_release.xml ...
Patching /qmf/etc/qmf_release.xml for 403-forbidden error ...
Restarting http server ...
Cleaning garbage....
rm: can't remove '/HCBv2/qml/apps/toonstore/*.qmlc': No such file or directory
rm: can't remove '/HCBv2/qml/apps/toonstore/*.jsc': No such file or directory
ToonStore pre-install script completed ...
Configuring toonstore.
Executing post-install script for toonstore-2.1.2 ...
Writing app version number to /HCBv2/qml/apps/toonstore-2.1.2/version.txt ...
Adding toonstore key to opkg keyring ...
OK
This is a Toon QB2, checking to Globals.qml
No settings to be restored
Removing stale link /HCBv2/qml/apps/toonstore ...
Creating symbolic link /HCBv2/qml/apps/toonstore to /HCBv2/qml/apps/toonstore-2.1.2
Firmware version 5 or greater detected, changing app for firmware compatibility...
Posting message ...
EDITING: Adding serial connection
TOON is alive again!
stijnpeeters
Postby TheHogNL » Wed Mar 13, 2019 9:47 am
Ok great! The "opkg upgrade" fixed the missing files for you. As you where in the middle of a previous update.
But I recommend others not to run this to soon. Only in specific circumstances this can fix your toon.
Good work!
Postby Heronimo » Tue Mar 26, 2019 8:50 am
Trying to upgrade, but run in to a libssl missing error:
5.2.11
Alright, I will try to upgrade to 5.2.11
Tunnel is alive and configured.
/usr/bin/wget: error while loading shared libraries: libssl.so.0.9.8: cannot open shared object file: No such file or directory
Could not download the upgrade script from the source.
Already ran a 'opkg upgrade', but that doesn't fix it.
Heronimo
Postby TerrorSource » Tue Mar 26, 2019 11:37 am
Heronimo wrote:Trying to upgrade, but run in to a libssl missing error:
5.2.11
Try installing the libssl from http://files.domoticaforum.eu/index.php ... on/ipk/qb2 and try again
TerrorSource
Postby ams123 » Thu Apr 11, 2019 2:05 am
After update from 4.16.8 to 4.19.10 my toon keep going on loading in the black screen whit the logo whte line goin up for hrs now
Toon solarpannels
ams123
Postby TheHogNL » Thu Apr 11, 2019 7:17 am
try to update to 5.0.4 or 5.2.11. This probably will fix it because I think you are missing some files
Postby ams123 » Thu Apr 11, 2019 8:05 am
ok wil do
Toon solarpannels
ams123
Postby ams123 » Thu Apr 11, 2019 9:16 am
ok now all works
i have update to 5.0.4 and all prroblems are gone
user and password input work now to
thanks for help
Toon solarpannels
ams123
Postby RichardGorter » Sun Apr 14, 2019 1:52 pm
I'm trying to update my rooted toon, version 4.2 something. but when I run te script I get this:
    pi@raspberrypi:~ $ sudo sh /root/update-rooted.sh
    Version: 3.81 - TheHogNL & TerrorSource & yjb - 22-3-2019
    /root/update-rooted.sh: 41: [: f911981092daafcd453018267a7ed53b: unexpected operator
    strings: '/HCBv2/sbin/hcb_config': No such file
    grep: /etc/opkg/arch.conf: Bestand of map bestaat niet
    /root/update-rooted.sh: 1: /root/update-rooted.sh: opkg: not found
    /root/update-rooted.sh: 854: [: unexpected operator
    /root/update-rooted.sh: 324: /root/update-rooted.sh: /usr/sbin/iptables-save: not found
    /root/update-rooted.sh: 389: /root/update-rooted.sh: /usr/sbin/iptables: not found
    /root/update-rooted.sh: 390: /root/update-rooted.sh: /usr/sbin/iptables: not found
    /root/update-rooted.sh: 393: /root/update-rooted.sh: /usr/sbin/iptables: not found
    /root/update-rooted.sh: 395: /root/update-rooted.sh: /usr/sbin/iptables: not found
    /root/update-rooted.sh: 396: /root/update-rooted.sh: /usr/sbin/iptables: not found
    /root/update-rooted.sh: 405: [: unexpected operator
    /root/update-rooted.sh: 417: /root/update-rooted.sh: /usr/sbin/openvpn: not found
    Could not enable VPN in a normal reasonable time!
    DEBUG information:
    default via 192.168.178.1 dev eth0 src 192.168.178.234 metric 202
    192.168.178.0/24 dev eth0 proto kernel scope link src 192.168.178.234 metric 202
    127.0.0.1 localhost
    ::1 localhost ip6-localhost ip6-loopback
    ff02::1 ip6-allnodes
    ff02::2 ip6-allrouters
    127.0.1.1 raspberrypi
    END DEBUG information
    openvpn: geen proces gevonden
    /root/update-rooted.sh: 595: /root/update-rooted.sh: /usr/sbin/iptables-restore: not found[/list]
Can somebody help me?
RichardGorter
Postby _Arjen_ » Sun Apr 14, 2019 4:54 pm
You need to run the script on Toon itself ;)
_Arjen_
Postby yjb » Sun Apr 14, 2019 5:21 pm
It looks like you are running the script on your raspberry pi:
The script should run on the toon. Also, the current version is 3.85 and normally it will ask you to update the version at the start of the script.
Just copy the script to your Toon and run it from there as root.
yjb
Postby RichardGorter » Sun Apr 14, 2019 6:00 pm
How do i put the script on the toon? :$
I'm sorry just a mega rooky
RichardGorter
Postby yjb » Sun Apr 14, 2019 6:54 pm
No problem:
scp -p update-rooted.sh <ip of your toon>:/root
Then login to your toon as root and make the script executable:
chmod 700 update-rooted.sh
The you can run it:
./update-rooted.sh
yjb
Postby TheHogNL » Sun Apr 14, 2019 6:59 pm
RichardGorter wrote:How do i put the script on the toon? :$
Did you read the readme? https://github.com/IgorYbema/update-rooted
Postby mAiden » Sun Apr 14, 2019 7:01 pm
curl -Nks https://raw.githubusercontent.com/IgorYbema/update-rooted/master/update-rooted.sh -o /root/update-rooted.sh
It stands also in the readme.... Just read it, before you ask.
mAiden
PreviousNext
Return to Toon Firmware
