Firmware 5.30.4
Firmware 5.30.4
Postby bekke517 » Thu Jun 25, 2020 7:02 pm
I'd like to know if it is save to install thenew version of the firmware 5.30.4
bekke517
Re: Firmware 5.30.4
Postby TerrorSource » Thu Jun 25, 2020 8:32 pm
Yes it is.
We've tested it and runs fine :)
TerrorSource
Re: Firmware 5.30.4
Postby michel30 » Tue Jun 30, 2020 10:00 pm
Ip updated my Toon 1 and all okay..
Thanks again for the nice update script.
michel30
Re: Firmware 5.30.4
Postby Flarrestein » Fri Jul 03, 2020 1:25 pm
Works perfect here.
Flarrestein
Re: Firmware 5.30.4
Postby Ossegek » Thu Jul 23, 2020 9:00 pm
Where can i find the change log
Ossegek
Re: Firmware 5.30.4
Postby TheHogNL » Thu Jul 23, 2020 9:07 pm
Ossegek wrote:Where can i find the change log
Check the (dutch) forum https://toonforum.nl/d/4-softwareversie-overzicht/57
Re: Firmware 5.30.4
Postby Hmmbob » Sat Aug 01, 2020 9:10 pm
I'm on 5.30.4, but my Toon v1 keeps saying the "new TSC resource file available, reboot gui" message and reboots on its own but then the message appears again.
It's also rather slow, way slower than after the last update.
Any idea what's happening?
Hmmbob
Re: Firmware 5.30.4
Postby TheHogNL » Sat Aug 01, 2020 9:56 pm
Hmmbob wrote:I'm on 5.30.4, but my Toon v1 keeps saying the "new TSC resource file available, reboot gui" message and reboots on its own but then the message appears again.
It should not reboot on its own. A new TSC resource file is published which includes some new icons for new toonstore apps. Nothing important.
That message should only appear when you hit 'check update' in TSC menu and it will then download the new resource file and asks you to restart the GUI.
You probably have seen the 'there is a new TSC resource file availabe. Please update using the TSC menu'. This directs you to this.
In your case, I think something else is wrong. Disk full? Too many apps running?
Re: Firmware 5.30.4
Postby Hmmbob » Sun Aug 02, 2020 2:05 pm
Thanks!
Diskspace does not seem to be an issue:
eneco-001-392594:~# df -h
Filesystem                Size      Used Available Use% Mounted on
ubi0:rootfs             103.3M     80.5M     22.8M  78% /
tmpfs                    61.6M    368.0K     61.3M   1% /var/volatile
Apps:
Boilerstatus 1.0.7
Newsreader 1.1.3
Buienradar 8.5.6
Toonstore 5.0.9
This is the message:
I've rebooted "the hard way" (unplugged it from the wall, waited 30sec, replugged) - let's see if that helps.
Hmmbob
Re: Firmware 5.30.4
Postby TheHogNL » Sun Aug 02, 2020 5:35 pm
Hmmbob wrote:Thanks!
Apps:
Boilerstatus 1.0.7
Newsreader 1.1.3
Buienradar 8.5.6
Toonstore 5.0.9
You do need to confirm that message by pressing the > in the message
Re: Firmware 5.30.4
Postby mAiden » Sun Aug 02, 2020 6:01 pm
Nice to see you here Hmmbob !!
Look what TheHogNL say, just tap on the ">", message will be gone.
This shows only a new TSC resource file is published which includes some new icons for new toonstore apps. Nothing important
mAiden
Return to Toon Firmware
