Page 21 of 24
Re: Toon firmware: issues (and solutions)
Posted: Sun Mar 18, 2018 9:15 pm
by TheHogNL
PowerAce wrote:Hi TheHogNL,
I've tried your mod for the NotificationBar.qml file. Unfortunately for my Toon (FW 4.10.6) this is not working. When i reboot Toon it stops somewhere halfway and ends with a 'white' screen. Luckily i was still able to log in using SSH.
I had the mod inserted around line 27 is that correct? It looks by the way that your file is different anyway, when i look at the very last line of your code just after '#end mod'. Yours says something about blockConditions which i don't see in my NotificationBar.qml
Regards
Hmm ok.. I'm at 4.13.7. Probably there is some difference there which I was not expecting. (line 29 at my toon).
The "notifications.removeByTypeSubType" is also used in /qmf/qml/apps/boilerMonitor/BoilerMonitorApp.qml
From your information I would expect that this function is not available in your versions so it should also not be used in that boilermonitorapp. Could you check?
Posted: Sun Mar 18, 2018 10:57 pm
by PowerAce
Hi TheHogNL,
I searched in BoilerMonitorApp.qml and indeed at line 275 i found this function "notifications.removeByTypeSubType". So i'm curious why it's not working for me. Let's see what Fietspomp finds.
When i rebooted after having your mod enabled and the white screen appeared i waited at least 5 minutes to be sure it wasn't just a temp halt during boot process. After those 5 mins i logged in by SSH and found out by the top command that still 75 MB of memory was free for me an indication that Toon didn't fully finish the boot process.
Greetz
Posted: Mon Mar 19, 2018 9:16 am
by Sundown89
TheHogNL wrote:PowerAce wrote:Hi TheHogNL,
Regards
I had the same issue on 4.13.7, white screen on rebooting. Luckily SSH access was still there like PowerAce mentioned.
Then I inserted the code you mentioned on page 19 to have the message only popup once after a reboot.
Posted: Mon Mar 19, 2018 10:52 am
by Fietspomp
I have 2 Toons with the 4.13.7 firmware, and both also give a white screen after reboot.
So for now I just disabled the banner completely
Posted: Mon Mar 19, 2018 11:53 am
by TheHogNL
Weird.. i'll remove the code from the post and will figure out why it only works for me then
Posted: Mon Mar 19, 2018 12:13 pm
by TheHogNL
duh, i feel so stupid right now..
the comments in the code was wrong. I used # instead of // to make a commented line and did only put it there in the post and not on my own Toon
So change the # in // and it works.
function show(expanded) {
//mod to remove network errors in notification bar
notifications.removeByTypeSubType("error","network");
//end mod
if (notifications.count === 0 || blockConditions)
Posted: Mon Mar 19, 2018 1:07 pm
by Fietspomp
TheHogNL wrote:duh, i feel so stupid right now..
//end mod
Hahaha well I also didn't see that myself...
Trying right now to see if it works!
Posted: Mon Mar 19, 2018 4:10 pm
by PowerAce
He TheHogNL,
Indeed that's one i could have seen myself too never mind now it works!
Thanks!
Posted: Tue Mar 20, 2018 12:17 am
by Sundown89
That is what we get for plain copy/pasting!
Should have noticed this myself. Thank you TheHog!
Will change tomorrow.
Posted: Tue Mar 20, 2018 8:53 pm
by TheHogNL
If you want to test the message is indeed being removed you can try with this:
/qmf/bin/bxt -d :happ_usermsg -s Notification -n CreateNotification -a text -v "Hello world!" -a type -v error -a subType -v network
compare it with when a info network message is being sent:
/qmf/bin/bxt -d :happ_usermsg -s Notification -n CreateNotification -a text -v "Hello world!" -a type -v info -a subType -v network
Posted: Tue Jun 19, 2018 2:39 pm
by EJanus
On a Toon running on firmware 4.10.6 I did an 'opkg remove base-qb2-ene' (don't ask why
Does anybody know which command in SSH I can use to download/install it again?
Posted: Tue Jun 19, 2018 9:03 pm
by TheHogNL
EJanus wrote:On a Toon running on firmware 4.10.6 I did an 'opkg remove base-qb2-ene' (don't ask why
Switch on the Eneco VPN on your toon.
Then install the package directly from the source:
opkg install http://feed.hae.int/feeds/qb2/POOL/base-qb2-ene_4.10.6-1196-0_qb2.ipk
Posted: Wed Jun 20, 2018 12:05 am
by EJanus
Thank you! I knew it was something like this, but I couldn't get it right!
Posted: Fri Dec 07, 2018 5:18 pm
by blue-label1989
Hi Guys,
I hope this is the right place for my question.
I have rooted my 2nd Toon (testmodel) , but i can't use the script: "
http://raw.githubusercontent.com/IgorYb ... -rooted.sh" "Version: 3.37 - 24-11-2018"
When i deploy the lines, i get an error from the script:
wget --no-check-certificate
chmod +x *
./update-rooted.sh
The error code that i get is: Unable to determine your current running version! (but when i lookup into my Toon, i see the version 4.19.10)
Please help!
Roy
Posted: Sat Dec 08, 2018 9:41 am
by TheHogNL
Please run
and post the result. The script uses this result to determine the version.
