Setting temperature on a monthly or even yearly basis
Vince78
Post by Vince78 »
In toon I can program the temperatures based on a weekly schedule.
But the building this Toon thermostate hangs, is only used a few times each month. Is there a possibility to schedule it using dates? Like a year or month schedule?
Re: Setting temperature on a monthly or even yearly basis
No, this is not possible. What you can do is switch off the program when you leave and set the temperature manually to a low value
Return to “Toon Firmware”
