Toon firmware - update script
Don't understand your question. You just need to update to 5.0.4 as the message is telling you
I have do this script first:
Then i have do this one:
But i got this message:
https://notepad.pw/share/xxfhxtqi1
So what i would like to try is, delete those files witch Toon have been downloaded, and try it again because i will get this error:
curl -Nks https://raw.githubusercontent.com/IgorYbema/update-rooted/master/update-rooted.sh -o /root/update-rooted.sh
sh /root/update-rooted.sh
Version: 3.62 - TheHogNL & TerrorSource & yjb - 18-2-2019
If you like the update script for rooted toons you can support me. Any donation is welcome and helps me developing the script even more.
https://paypal.me/pools/c/8bU3eQp1Jt
Your Toon already tried downloading version 5.0.4 before. Need to force this version!
iptables: Chain already exists.
Warning: upgrade script from Eneco server is changed. Do you want to continue downloading the files (if not sure, type no and report in the forums)?
yes
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (anything else)?
yes
Killing process... took to long!s takes a minute or two .
Prepare failed. Please check the logs at /mnt/data/update/upgrade-qb2.sh.log
Post the output of /mnt/data/update/upgrade-qb2.sh.log
How can i download it? Because its a file with 4440 rules.WickedMaster wrote:Post the output of /mnt/data/update/upgrade-qb2.sh.log
Updates are broken current. Eneco/Quby script is having some bugs...
Thanks for the update!TheHogNL wrote:Updates are broken current. Eneco/Quby script is having some bugs...
I will try it in a couple more days again.
I have currently disabled all updates in the newest script update (script version 3.63). When everything is working again I'll create a new version.
I just updated from 4.22.7 through the official way of updating (Toon software update). Seems like it's working sometimes.
Edit: The Toon has been crashed while doing the official update. Will have a look at it tomorrow.
I have a question about the update script. I have aborted yesterday the update script by entering quit. The script has already downloaded the new 5.0.4. Today I wanna proceed but now the script crash after the message that 5.0.4 is already downloaded with a lot of vertical Y.
My question is; where does the script store downloads so I can remove firmware 5.0.4 to start over again.
Thanks
Thanks
- Administrator
as mentioned a few times in this topic and on the forum. these 2 locationed are the update files locatedMarkie13 wrote:Hi all,
Thanks
\HCBv2\tmp\opkg-cache\ - before 4.x.x
\mnt\data\update\ - after 4.x.x
Can you post that 'vertical Y' logs? Don't understand where that is coming from.Markie13 wrote:Hi all,
Thanks
Removing the download files doesn't help. As soon as the Toon has started a version download the OPKG package information is stored and can not simply be removed. It should not be a problem to start 5.0.4 so I'm curious why this isn't working in your Toon now. The message "Your Toon already tried downloading version 5.0.4 before. Need to force this version!" is a new feature which I added last week. If this is causing issue's I need to check why.
Hi TheHogNL,TheHogNL wrote: Can you post that 'vertical Y' logs? Don't understand where that is coming from.
After many attempts I finally upgraded my Toon 1 to 5.0.4. Thanks for the script.
You asked for a Y log. Can I still apply this after the upgrade?
Thanks to you all for your hard work/effort on Toon 1 and Toon 2.TheHogNL wrote:No it is ok now.
- Starting Member
I think i made the mistake of updating from 3.9 to 5.0.2 in 1 step.
script stopped somehow and toon is not booting.
Is there a way to "unbrick" it?
