Toon firmware - update script
TerrorSource
Post by TerrorSource »
mAiden wrote:Can your script also downgrade @TheHogNL ?
Get the following notification to a forced update to 4.18.8..
INIT: Id "qtqt" respawning too fast: disabled for 5 minutes
Why did you do that! :roll:
4.18.8 is not (yet) supported by the update script and the ToonStore...
mAiden
Post by mAiden »
For status used it was necessary to do a factory reset. Quby / Eneco force nowadays the latest version when you do to the end of installation wizard.
soepie78
Post by soepie78 »
I used the update script, chose 4.16.8, and now my toon won't boot.
It stays in a grey screen with a Logo light grey.
Luckely i've got my ssh up again, but when i try the scipt this is my output:
Which version do you want to upgrade to?
4.16.8
Alright, I will try to upgrade to 4.16.8
Could not enable VPN in a normal reasonable time!
DEBUG information:
192.168.178.0/24 dev eth0 scope link  src 192.168.178.48
default via 192.168.178.1 dev eth0  metric 10
# <persistent /etc/hosts content from /etc/hosts.template file>
127.0.0.1 ping.quby.nl
# </persistent /etc/hosts content from /etc/hosts.template file>
127.0.0.1               localhost.localdomain           localhost              eneco-001-071382
172.19.16.1             feed.hae.orig           feed
127.0.0.1  feed.hae.int  feed
END DEBUG information
killall: openvpn: no process killed
what can i do?
Post by TheHogNL »
PM me your mobile number. I will then contact you and start a teamviewer session to check your Toon.
mAiden
Post by mAiden »
soepie78 wrote:I used the update script, chose 4.16.8, and now my toon won't boot.
4.16.8
DEBUG information:
what can i do?
How looks you're inittab?
soepie78
Post by soepie78 »
this is my inittab:
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
# HCBv2 static stuff
ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev
qtqt:245:respawn:/usr/bin/startqt >/dev/null 2>&1
gett:235:respawn:/sbin/getty -L 115200 ttymxc0 vt102
# automatic (re)start of x11vnc:
#x11v:5:respawn:/usr/bin/x11vnc
# WARNING: auto-managed by '/etc/init.d/HCBv2 inittabwrap' with '/HCBv2/etc/star
#          lines containing 'inittabwrap' will be removed automagically.
netc:235:respawn:/etc/init.d/HCBv2 inittabwrap hcb_netcon
comm:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_comm
even:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_eventmgr
kpik:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_kpi
pwru:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_pwrusage
scsy:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_scsync
smar:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_smartplug
ther:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_thermstat
user:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_usermsg
weat:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_weather
bxtp:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_bxtproxy
conf:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_config
logl:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_log
rrdr:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_rrd
watc:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_watchdog
hueh:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_hue
p1p1:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_p1
zwav:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_zwave
ligh:345:respawn:/etc/init.d/HCBv2 inittabwrap lighttpd
# end of 'inittabwrap' section.
- /etc/inittab 60/60 100%
mAiden
Post by mAiden »
soepie78 wrote:this is my inittab:
# of runlevel.
That one looks good.
Give Toon a error on you're console? when you boot them? Connect Toon to serial interface, you can see everything what happends.
Post by TheHogNL »
Just had a chance to look wat was wrong with your Toon.
After starting qt manually (/usr/bin/startqt) it immediatly stopped with message 'drawables.rcc' not found.
It seemed that the symbolic links in /qmf/qml towards the rcc files where missing. Not sure yet how this is possible as I am currently unaware when these links are made during the upgrade to 4.16.8
However, it was easily fixed using these commands:
cd /qmf/qml
ln -s resources-static-base.rcc resources.rcc
ln -s drawables-base.rcc drawables.rcc
Post by TheHogNL »
Ok, just found where these links normally are created.
In /qmf/bin/qmf-tenantize.sh, which is started just after a upgrade, the tenant version (in most of our cases Eneco) is checked and then the correct resource file is linked (base or Electrabel for Boxx devices).
So, running /qmf/bin/qmf-tenantize.sh again should have fixed your issue also. Probably the update went wrong somewhere causing this not to run.
soepie78
Post by soepie78 »
Fantastic Hogg!
Up and running agian, with 0.1 degree steps temp reading!
makkie2002
Post by makkie2002 »
After a long time I decided it was time to upgrade my Toon by the script. As suggested I first upgraded to 4.10.6, which was succesfull!
I then upgraded to 4.15.6 ... which was not successfull as after reboot the Toon seems to be stuck at the orange Toon bootscreen. Now and then Toon seems to reboot by itself as the screen briefly flashes to black. But I do not get into the GUI. I can connect over ssh, but also this seems to indicate a reboot from time to time. I can see "/HCBv2/sbin/qt-gui -platform linuxfb -plugin Tslib" using most of the CPU.
Please help.
Post by TheHogNL »
Try to start qt manually (/usr/bin/startqt) and try to understand the output. Or just PM me if you want me to help you remotely.
Post by TheHogNL »
In a PM conversation I adviced him to install 4.16.8. The logs from qt where not that conclusive but my best guess what that the 4.15.8 installation had failed somewhere.
After the update to 4.16.8 his Toon is working fine.
@Toonz, please make a 4.16.8 (and 4.18.8 ) resources file for the Boxx for him so he can tentantize towards Boxx (he's belgian :) )
That 's fine. Can do after I return from holiday.
Do we have the original boxx resource files already?
Post by TheHogNL »
Yes it is installed on each Toon also (called resources-static-ebl.rcc or something). Only need to reverse engineer all the code again (very hard labour.. but worth it).
Return to “Toon Firmware”
