Posted: Tue Mar 12, 2019 11:48 pm
With your help i got it to work again:
perhaps my steps wil help someone else aswell:
created a VPN manually as informed by theHognl:
Run the script, kinda didn't work, or i don't use it correct
... but... the same commands manually gave the correct info from tap0:
manually looking for the grep it seems that is would be: 172.28.128.1
but eventually it seemd that not .int has to be this ip address but feed.hae.orig.
after setting the ip to .orig; the command opkg update worked.
however: command opkg install base-qb2-uni gave an error:
so also tried opkg upgrade and let it run.
after this the command shows it;s up 2 date:
rebooted; no toon yet so rerun the update script:
TOON is alive again!
eneco-001-064929:~# /usr/sbin/openvpn --config /etc/openvpn/vpn.conf
Tue Mar 12 20:29:22 2019 DEPRECATED OPTION: --tls-remote, please update your configuration
Tue Mar 12 20:29:22 2019 OpenVPN 2.3.11 arm-hae-linux-gnueabi [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Nov 30 2016
Tue Mar 12 20:29:22 2019 library versions: OpenSSL 1.0.2h 3 May 2016, LZO 1.08
Tue Mar 12 20:29:22 2019 Control Channel Authentication: using '/etc/openvpn/vpn/ta.key' as a OpenVPN static key file
Tue Mar 12 20:29:22 2019 Attempting to establish TCP connection with [AF_INET]34.253.116.121:443 [nonblock]
Tue Mar 12 20:29:23 2019 TCP connection established with [AF_INET]34.253.116.121:443
Tue Mar 12 20:29:23 2019 TCPv4_CLIENT link local: [undef]
Tue Mar 12 20:29:23 2019 TCPv4_CLIENT link remote: [AF_INET]34.253.116.121:443
Tue Mar 12 20:29:25 2019 [VPN-Eneco] Peer Connection Initiated with [AF_INET]34.253.116.121:443
Tue Mar 12 20:29:27 2019 TUN/TAP device tap0 opened
Tue Mar 12 20:29:27 2019 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Tue Mar 12 20:29:27 2019 /sbin/ifconfig tap0 172.28.143.153 netmask 255.255.240.0 mtu 1500 broadcast 172.28.143.255
Tue Mar 12 20:29:27 2019 Initialization Sequence Completed
eneco-001-064929:~# echo `/sbin/ip route | /bin/grep ^172.*via.*tap0 | /usr/bin/
awk '{print $1}'| /usr/bin/awk 'BEGIN {FS="."}; {print $1"."$2"."$3}'`.1
-sh: /sbin/ip: not found
.1
eneco-001-064929:~# cd /sbin/
eneco-001-064929:/sbin# ip route
192.168.1.0/24 dev eth0 scope link src 192.168.1.120
172.28.128.0/20 via 172.28.128.1 dev tap0
172.28.128.0/20 dev tap0 scope link src 172.28.143.153
default via 192.168.1.254 dev eth0 metric 10
eneco-001-064929:/sbin# ping 172.28.128.1
PING 172.28.128.1 (172.28.128.1): 56 data bytes
64 bytes from 172.28.128.1: seq=0 ttl=64 time=77.141 ms
64 bytes from 172.28.128.1: seq=1 ttl=64 time=33.743 ms
so put that into etc/hosts file for .int
127.0.0.1 localhost.localdomain localhost
172.23.16.1 feed.hae.orig feed
172.28.128.1 feed.hae.int feed
127.0.0.1 ping.quby.nl
test:
eneco-001-064929:/etc# ping feed.hae.int
PING feed.hae.int (172.28.128.1): 56 data bytes
64 bytes from 172.28.128.1: seq=0 ttl=64 time=36.642 ms
64 bytes from 172.28.128.1: seq=1 ttl=64 time=38.864 ms
eneco-001-064929:~# opkg install base-qb2-uni
Package base-qb2-uni (5.0.4-1286-0) installed in root is up to date.
eneco-001-064929:~# sh /root/update-rooted.sh -f
Version: 3.71 - TheHogNL & TerrorSource & yjb - 5-3-2019
Only fixing files.
creating backup of inittab...
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 5.0.4.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps/toonstore-2.1.2/toonstore_2.1.2-r0_qb2.ipk.
Installing toonstore (2.1.2-r0) to root...
Executing pre-install script for toonstore-2.1.2
Previous installation detected.
Creating backup for /qmf/etc/qmf_release.xml ...
Patching /qmf/etc/qmf_release.xml for 403-forbidden error ...
Restarting http server ...
Cleaning garbage....
rm: can't remove '/HCBv2/qml/apps/toonstore/*.qmlc': No such file or directory
rm: can't remove '/HCBv2/qml/apps/toonstore/*.jsc': No such file or directory
ToonStore pre-install script completed ...
Configuring toonstore.
Executing post-install script for toonstore-2.1.2 ...
Writing app version number to /HCBv2/qml/apps/toonstore-2.1.2/version.txt ...
Adding toonstore key to opkg keyring ...
OK
This is a Toon QB2, checking to Globals.qml
No settings to be restored
Removing stale link /HCBv2/qml/apps/toonstore ...
Creating symbolic link /HCBv2/qml/apps/toonstore to /HCBv2/qml/apps/toonstore-2.1.2
Firmware version 5 or greater detected, changing app for firmware compatibility...
Posting message ...
EDITING: Adding serial connection
