Toon firmware - update script
Postby FunFair » Tue May 21, 2019 6:31 pm
TheHogNL wrote:Ah ok Eneco changed their scripts again. Just checked and it is ok. I updated the update-rooted script to allow this (version 3.86 just published).
WOW! Quick service. But a bit too quick lol. :D
Getting a syntax error. :P
But it seems to be an error in the update script from Toon?
Which version do you want to upgrade to?
5.5.7
Alright, I will try to upgrade to 5.5.7
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (anything else)?
yes
/mnt/data/update/upgrade-qb2.sh: line 62: syntax error: unexpected "}"
Prepare failed. Please check the logs at /mnt/data/update/upgrade-qb2.sh.log
The log file is not updated btw. Removed the old log and no new one was created.
FunFair
Postby yustmenl » Tue May 21, 2019 7:40 pm
I am having the same problem here.
yustmenl
Postby TheHogNL » Tue May 21, 2019 8:23 pm
Should work now. A line was changed in their script which my script needed to modify but now failed.
The line is about posting everything you do while updating your toon to the eneco server center. We don't want that so my script removes that line. But that failed now because they changed a small thang. So again, it is fixed now, version 3.87.
Postby yustmenl » Tue May 21, 2019 8:33 pm
Thanks for the quick responce but unfortunaly i stil have the same problem
yustmenl
Postby FunFair » Wed May 22, 2019 6:49 am
yustmenl wrote:Thanks for the quick responce but unfortunaly i stil have the same problem
Mine works. Did you re-download the script?
Thanks HogNL
FunFair
Postby yustmenl » Wed May 22, 2019 12:36 pm
It's working now, Thanks!
yustmenl
Postby MP51 » Sun May 26, 2019 6:50 pm
Upgrading my Toon from version 4.16.8 to 5.5.7 by update script, everything went fine.
After reboot my Toon shows only Toon logo with aan loading bar until 33% then stopped, what can i do ?
MP51
Postby TheHogNL » Sun May 26, 2019 7:42 pm
MP51 wrote:Upgrading my Toon from version 4.16.8 to 5.5.7 by update script, everything went fine.
How did you reboot after the update?
Can you check /etc/inittab and /usr/bin/startqt ? Should both be readable files. In some cases they end up empty. Probably after a power cycle reboot.
Postby mAiden » Sun May 26, 2019 7:51 pm
Probably inittab is empty and you missing qt-gui now.
On the forum you will find a inittab, p put it in it. And start a VPN and install qt-gui with:
Opkg install qt-gui
mAiden
Postby MP51 » Sun May 26, 2019 8:12 pm
i have checked /etc/inittab and /usr/bin/startqt, the are both with readable text in it inittab = 3kb and startqt = 2kb
Have done Opkg install qt-gui, that give the message already installed.
my inittab
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
# HCBv2 static stuff
#ovpn:235:respawn:/usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0 >/dev/null 2>&1
qtqt:245:respawn:/usr/bin/startqt >/dev/null 2>&1
# add serial console access:
gett:235:respawn:/sbin/getty -L 115200 ttymxc0 vt102
tscs:245:respawn:/usr/bin/tsc >/var/log/tsc 2>&1
# WARNING: auto-managed by '/etc/init.d/HCBv2 inittabwrap' with '/HCBv2/etc/start.d/*'
#          lines containing 'inittabwrap' will be removed automagically.
netc:235:respawn:/etc/init.d/HCBv2 inittabwrap hcb_netcon
comm:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_comm
even:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_eventmgr
kpik:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_kpi
pwru:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_pwrusage
scsy:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_scsync
smar:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_smartplug
ther:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_thermstat
user:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_usermsg
weat:345:respawn:/etc/init.d/HCBv2 inittabwrap happ_weather
bxtp:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_bxtproxy
conf:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_config
logl:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_log
rrdr:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_rrd
watc:345:respawn:/etc/init.d/HCBv2 inittabwrap hcb_watchdog
hueh:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_hue
p1p1:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_p1
zwav:345:respawn:/etc/init.d/HCBv2 inittabwrap hdrv_zwave
ligh:345:respawn:/etc/init.d/HCBv2 inittabwrap lighttpd
# end of 'inittabwrap' section.
my startqt
#!/bin/sh
# load a sane environment, HCBv2 can prevent execution with 'exit'
. /etc/profile
. /etc/default/HCBv2
cd /qmf/sbin
if [ -z `pidof psplash` ]
then
        echo "Starting psplash..."
        /etc/init.d/psplash.sh
fi
# set the initial progress of the UI
/etc/init.d/psplash.sh progress 30
# do we have dim support in our binary? For qt if the system supports it the UI will as well
SYSBL="`/bin/ls /sys/class/backlight/*/ramp_brightness_sync | grep -v contrast | head -n1`"
if [ "$SYSBL" ]
then
        BL=1
        BLMAX="`dirname $SYSBL`/max_brightness"
fi
# calib screen first?
if [ ! -f /etc/pointercal ]
then
        [ "$BL" ] && cat $BLMAX > $SYSBL
        echo 0 > /sys/class/graphics/fb0/blank
        ts_calibrate
        #[ "$BL" ] && echo 0 > $SYSBL
fi
# enable screen and create the tmp file if it was still missing
echo 0 > /tmp/fb0_blank
#export QT_DEBUG_PLUGINS=1
#export QML_IMPORT_TRACE=1
echo "Starting Qt"
exec /qmf/sbin/qt-gui -platform linuxfb -plugin Tslib
MP51
Postby mAiden » Mon May 27, 2019 12:25 pm
Nothing strange there.
Start VPN with:
sh update-rooted.sh -o
Open a new SSH window (Dont close the other one with the VPN!), and try this one:
opkg install --force-reinstall qt-gui
mAiden
Postby TheHogNL » Mon May 27, 2019 3:14 pm
Try to log the QT start sequence and see why QT isn't booting up.
Postby mAiden » Mon May 27, 2019 3:25 pm
TheHogNL wrote:Try to log the QT start sequence and see why QT isn't booting up.
Dangerous to do this, but I suspect a wrong resource file with no backup. hence my reaction above.
There are hardly any other choices.
mAiden
Postby TheHogNL » Mon May 27, 2019 3:59 pm
Dangerous to do a log? Nothing dangerous about that mAiden :-)
Postby mAiden » Mon May 27, 2019 4:02 pm
You misunderstand me.
It is dangerous to make statements that I just made. That wrong resource file might have been loaded..
QT logging is always a good thing, so you can see exactly what's wrong.
mAiden
PreviousNext
Return to Toon Firmware
