Page 36 of 44
Posted: Mon Jul 08, 2019 2:19 pm
by jozg
Hello Maiden,
Even deleting all custom apps did not work.
I only have 28.0mb free.
How many do i need for the 5.0.4 update?.
Regards
Posted: Mon Jul 08, 2019 2:23 pm
by TheHogNL
Check /qmf/log (on some toon which are running for years these logs are big).
But normally 5.0.4 should install fine (although it gets close to full disk during update). Not sure what the mininum free space is.
Posted: Mon Jul 08, 2019 2:35 pm
by jozg
Oh oh.
I just used opkg remove --autoremove '*' and now it crashed.
Is there a way to recover the complete toon?
I think serial link will work, i hope.
thanks
Posted: Mon Jul 08, 2019 3:51 pm
by mAiden
jozg wrote:Oh oh.
thanks
Then you are now I think ...
Your only hope is to fully restore Toon with TFTP and NFS, if you know what that means?
Perhaps TheHogNL is so sweet to explain things to you .. I'm not going to share things if I'm not sure if i can :)
You will have to restore the entire rootfs, hoping that you can still backup your VPN for that.
Can you still get there with SSH?
Posted: Mon Jul 08, 2019 4:04 pm
by TheHogNL
A short time ago I released Toon Recovery just for this :) viewtopic.php?f=95&t=12462
(btw: I moved your messages after this to this topic for toon recoverY0
Posted: Mon Jul 29, 2019 12:35 pm
by bvlet
Tonight I tried updating Toon from 5.7.7. to the new version. It looked as if this was going allright (as usual), up to this point:
Tunnel is alive and configured.
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (anything else)?
yes
Starting the upgrade prepare option which downloads all necessary files. No upgrade is done yet.
Progress: 0% ..
Then everything stalled, and after a while Toon restarted.
Now when I try to update again I get this message:
Your Toon already tried downloading version Collected errors: before. Need to force this version!
iptables: Chain already exists.
yes
Progress: 0% .
Prepare failed. Please check the logs at /mnt/data/update/upgrade-qb2.sh.log
I checked if there was a problem with diskspace, but I don't think so:
eneco:~# df -h
Filesystem Size Used Available Use% Mounted on
ubi0:rootfs 103.3M 75.4M 27.8M 73% /
tmpfs 61.6M 512.0K 61.1M 1% /var/volatile
So then I checked the mentioned log. I see a lot of signature errors and download fails, but I can't seem to understand what's the problem.
I attached the last part of the log (only today).
Can anyone point me in the right direction?
Posted: Mon Jul 29, 2019 4:20 pm
by TheHogNL
something going wrong with the current firmware detection:
Please send me the output of:
opkg list-installed base-qb2*
and
opkg list base-qb2*
Posted: Mon Jul 29, 2019 9:56 pm
by bvlet
OK, here it is:
eneco-001-378442:~# opkg list-installed base-qb2*
base-qb2-uni - 5.5.7-0
eneco-001-378442:~# opkg list base-qb2*
eneco-001-378442:~#
Posted: Tue Jul 30, 2019 12:00 am
by TheHogNL
Hmm that looks normal. Wasn't expecting that.
Did you reboot in the meanwhile? And did you retry the update again?
If it still doesn't work send me your mobile number in a PM and I will help you with this tomorrow around 20:00. I want to know where that weird error is coming from to fix the script.
Posted: Tue Jul 30, 2019 1:15 am
by bvlet
OK, yesterday I rebooted three times with no luck. Today I tried it again with no rebooting and it still didn't work.
then I rebooted (shutdown -r) and I tried it again.
Surprise: It works! The script started all over again (choosing version etc.) and it finished without any problems.
I'm very happy that the problem is solved now, but unfortunately I can't help you fix the strange bug from yesterday...
Thanks for your help anyway, I'm very happy with the script!
Bart
Posted: Tue Jul 30, 2019 2:07 pm
by TheHogNL
OK still weird :-) Glad is worked now
Posted: Sun Sep 01, 2019 10:21 pm
by abb
Hi, I just tried to update my rooted Toon but the script mentions that Eneco changed the updatescript... I choose to opt out of the update procedure since I'm not aware of the risk when I force the script to proceed.
eneco-001-137595:~# ./update-rooted.sh
Version: 3.991 - TheHogNL & TerrorSource & yjb - 1-8-2019
Your Toon already tried downloading version 5.9.6 before. Need to force this version!
Warning: upgrade script from Eneco server is changed. Do you want to continue downloading the files (if not sure, type no and report in the forums)?
Posted: Tue Sep 03, 2019 8:37 pm
by TheHogNL
abb wrote:Hi, I just tried to update my rooted Toon but the script mentions that Eneco changed the updatescript... I choose to opt out of the update procedure since I'm not aware of the risk when I force the script to proceed.
Thanks. I just checked the new eneco script and it is ok. I updated my script to allow this in version 3.992 of the script.
Posted: Sun Sep 08, 2019 1:52 am
by CrumNL
TheHogNL wrote:/etc/passwd and /etc/group are files and should NEVER be links to busybox
you need to find out why it want to link it anyways
After some trial and error sessions in the last months when I had time, I figured out that this issue is resolved by
opkg remove busybox.passwd
and running the updatescript with -f.
It is possible that when I rooted toon a year ago or so, that I installed a wrong/different busybox version.
Can't remember what I did and my notes are gone.
Toon functions again but it doesn't yet detect the smart meter so I'm not done yet with it I guess.
Posted: Sun Sep 08, 2019 5:10 pm
by abb
Thanks! At the mean time I have checked the logging from previous firmware installs and I noticed thar there was an issue with available space. The amount of space requires was larger then the amount of space available. Looks like this message was also there In my previous unrooted firmware upgrade. Any tops on how to handle this?
Sent from my SM-G950F using Tapatalk
