Re: Toon firmware resource file (as from 4.16.8)
Yes that is (probably) in the other resources file containing all images. Will look into this, but low prio
Bwired.nl Domotica - Home Automation Forum
http://www.domoticaforum.eu/
Toonz wrote:1. by default all custom apps will be loaded from /qmf/qml/apps/ at startup.
Globals.qml is not used anymore for that purpose. If you don't want an app anymore, remove it from the apps folder
makkie2002 wrote:Toonz wrote:1. by default all custom apps will be loaded from /qmf/qml/apps/ at startup.
My apps folder looks like this ... as you can see some apps have multiple versions + links in the same directory ... is this a problem ?
Arcidodo wrote:how do i edit an *.rcc file? i found an app "QT" but i can only view it as an binary file.
newwolf wrote:makkie2002 wrote:Toonz wrote:1. by default all custom apps will be loaded from /qmf/qml/apps/ at startup.
makkie2002, I see you have a webcam app?
Where did your get that from and what's in it?
Because I'm looking for something to show a webcam feed or photo of my frontdoor camera when there is someone pushing my doorbell.
I allready have a script that's sending a picture when the doorbell is pushed but if it also can be showed on my Toon it would be very cool
TheHogNL wrote:Arcidodo wrote:how do i edit an *.rcc file? i found an app "QT" but i can only view it as an binary file.
What do you want to do? It is not possible to edit the .rcc file as it indeed a binary file.
We create our own .rcc files to make it work on a > 4.16.8 toon.
makkie2002 wrote:
It is a homemade app ... it is functional but not very performant ... but it does the job to display my IP-cam image (via a weblink to a (m)jpeg) ... please feel free to experiment with it !
newwolf wrote:makkie2002,
Thanks it's working.
mAiden wrote:Eneco release today 4.19.10. Dont update it, if you like the custom apps.
