New major firmware release 5.0.4 - UPGRADE AVAILABLE
Re: New major firmware release 5.0.4 - UPGRADE AVAILABLE
Postby dennis071nl » Thu Jan 17, 2019 11:26 pm
It Seems like the apps are not able to update to the latest versions. Sonos: i get 1.04 as newest, om the forum Toonz announced the 1.05 version already.
Calendar: 1.1.3....
dennis071nl
Postby TheHogNL » Thu Jan 17, 2019 11:32 pm
dennis071nl wrote:It Seems like the apps are not able to update to the latest versions. Sonos: i get 1.04 as newest, om the forum Toonz announced the 1.05 version already.
Calendar: 1.1.3....
Toonz announced 1.0.4 sonos app :-)
Calendar latest is 1.1.3 so that is ok.
Postby Xavier » Fri Jan 18, 2019 7:04 am
I upgraded last night about 15 minutes after the release.
Sinds the upgrade my Toon reboots spontanius and/or the screen freezes.
In some cases I need to do a powercycle.
Reboot/screen freeze/ powercycle needs to be done in most of the time about 2 or 3 minutes after the system has been loaded.
Anybody any idea on how to fix this?
Please help, thanks!
Toon2 with 5.18.8 firmware TSC 2.1.1
Apps: Sonos, Calender, garbagecalender, traffic information, webcam, doorcam, PostNL, public transport, Onkyo, Domoticzboard and weather app.
Xavier
Postby mAiden » Fri Jan 18, 2019 8:27 am
Look at this link, here you can see on what version the apps are. Toon Store use this link also.
http://files.domoticaforum.eu/uploads/T ... onRepo.xml
mAiden
Postby TheHogNL » Fri Jan 18, 2019 8:37 am
Xavier wrote:Hi,
Try this post https://www.domoticaforum.eu/viewtopic. ... les#p88325
Report if this works for you.
Thinking about this,.. maybe I need to create a check script which checks that xml config file...
Postby TerrorSource » Fri Jan 18, 2019 8:52 am
Xavier wrote:Hi,
I'm hearing more and more of this issue. Looks like the qt-gui.xml file is being stuffed with useless information somehow. when it's larger as 10-15kb, rename the file (just put a _ in front of the name or something like that) and reboot the toon.
I already did the upgrade on a Toon1 (from 4.19.7 to 5.0.4), went OK.
Upgrade on my Toon2 (from 4.22.7 to 5.0.4) resetted the tiles automatically. no reason found for that.
TerrorSource
Postby Xavier » Fri Jan 18, 2019 8:59 am
TerrorSource wrote:
Xavier wrote:Hi,
Thanks for this help!
I will give it a try later today (somewhere after 13.00 hours CET)
Xavier
Postby Xavier » Fri Jan 18, 2019 9:01 am
TerrorSource wrote:
Xavier wrote:Hi,
Sorry, forgot to mention that I have a Toon1 and upgraded from 4.22.7 to 5.0.4...….
Xavier
Postby SDeath » Fri Jan 18, 2019 10:30 am
After upgrading none of the custom apps including ToonStore are installed.
Is that normal after an upgrade, since this is my first?
Edit: Resource files I guess need to be placed manually?
Edit2: After placing the resource file still nothing shows up. Any tips to get the ToonStore and custom apps going again?
Edit3: Manually installed the ToonStore app and had to remove and reinstall all other apps.
Edit4: All working now!
I could see the following while upgrading to 5.0.4:
Unattended mode
You are currently running version 4.22.7 on a qb2 with flavour uni
Available versions: 1.0.9 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.7 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.9.15 2.9.26 2.10.15 3.0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.2 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.9.124 4.10.6 4.11.6 4.12.0 4.13.6 4.13.7 4.15.2 4.15.6 4.16.8 4.18.8 4.19.10 4.20.7 4.22.7 5.0.4
Unattended selected version 5.0.4
Alright, I will try to upgrade to 5.0.4
Upgrade script downloaded. We need to download the upgrade files first. No upgrade is done yet. Do you want me to download the files (yes) or quit (anything else)?
Waiting to finish. Sometimes this takes a minute or two  ...
Done preparing.
Are your sure you want to upgrade to 5.0.4 (yes)? This is the last moment you can stop the upgrade. Answer with 'yes' will start the upgrade.
Starting the upgrade now! Just wait a while... It can take a few minutes.
Upgrade done!
Restoring your iptables and passwd files so you can login again after rebooting.
Upgrade is done. However each firmware upgrade will revert the changes to some files needed for a working rooted Toon. Do you want me me to try and fix a few well known issue's for you right now?
creating backup of hosts...
FIXING: Downloading resources.rcc TSC mod for this version 5.0.4.
Downloading http://files.domoticaforum.eu/uploads/Toon/apps//.
Collected errors:
* opkg_download: Failed to download http://files.domoticaforum.eu/uploads/Toon/apps//: HTTP response code said error.
Collected errors:
Collected errors:
Collected errors:
Collected errors:
Collected errors:
FIXING: Installing Dropbear for ssh access
Downloading http://files.domoticaforum.eu/uploads/Toon/dropbear_2015.71-r0_qb2.ipk.
Installing dropbear (2015.71-r0) to root...
Multiple replacers for glibc, using first one (libc6).
Multiple replacers for zlib, using first one (libz1).
update-alternatives: Linking //usr/bin/scp to /usr/sbin/dropbearmulti
update-alternatives: Linking //usr/bin/ssh to /usr/sbin/dropbearmulti
System startup links for /etc/init.d/dropbear already exist.
Restarting Dropbear SSH server: stopped /usr/sbin/dropbear (pid 695)
dropbear.
Broadcast message from root (Fri Jan 18 09:08:14 2019):
The system is going down for reboot NOW!
Configuring dropbear.
EDITING: Adding serial connection
Do you want to install x11vnc? cmd 'x11vnc' needs to be run after each reboot to start the x11vnc server. x11vnc password can be set while starting x11vnc for the first time
Everything done! You should reboot now!
Toon1 running firmware 5.2.11 (rooted)
SDeath
Postby Xavier » Fri Jan 18, 2019 11:15 am
SDeath wrote:After upgrading none of the custom apps including ToonStore are installed.
Unattended mode
Done preparing.
Upgrade done!
Collected errors:
Collected errors:
Collected errors:
Collected errors:
Collected errors:
Collected errors:
dropbear.
Same here custom apps not installed, also when trying in the time window of the "crash" I need to complete the Configuration settings again.
For calander for example I see an extra file (settings.json) where the ICAL links need to be placed in....
Xavier
Postby TheHogNL » Fri Jan 18, 2019 12:18 pm
Glad you found out yourself how to fix it. As you can see in the logs from the update the part where all apps are updated went wrong as files.domoticaforum.com was down/not available at that time.
Postby TheHogNL » Fri Jan 18, 2019 12:19 pm
Xavier wrote:Same here custom apps not installed, also when trying in the time window of the "crash" I need to complete the Configuration settings again.
First check that qt-gui.xml config file please.
Postby SDeath » Fri Jan 18, 2019 1:16 pm
Yeah I noticed this, but dropbear installed normally from the same source.
Glad that it did though.
SDeath
Postby TheHogNL » Fri Jan 18, 2019 1:44 pm
SDeath wrote:Yeah I noticed this, but dropbear installed normally from the same source.
Hmm after looking again I noticed the requested app installation url where bad in your log.
Could you please run this on your Toon and post the result? It does not install anything, just prints some info. Maybe the problem is gone already, but there could be something else.
#!/bin/sh
SOURCEFILES="http://files.domoticaforum.eu/uploads/Toon"
for a in toonstore `find /qmf/qml/apps -type l | sed 's#/qmf/qml/apps/##' | grep -v toonstore`
do
      latest=`curl -Nks $SOURCEFILES/apps/ToonRepo.xml | grep $a | grep folder | sed 's/.*<folder>\(.*\)<\/folder>.*/\1/'`
      filename=`curl -Nks $SOURCEFILES/apps/$latest/Packages.gz | zcat | grep Filename| cut -d\  -f2`
      APPURL=$SOURCEFILES/apps/$latest/$filename
      echo $APPURL
done
just put this in a 'test.sh' and run it or just paste it in your toon command line
Postby SDeath » Fri Jan 18, 2019 1:59 pm
TheHogNL wrote:just put this in a 'test.sh' and run it or just paste it in your toon command line
The result:
zcat: no gzip/bzip2/xz magic
SDeath
PreviousNext
Return to Toon Firmware
