Toon firmware 5.15.6 released
Re: Toon firmware 5.15.6 released
Postby michel30 » Sun Oct 20, 2019 1:06 pm
Thanks, this has helped me a lot I'm running now on 5.15.6 and I have 23,3 mb free space left after the update.
michel30
Postby TheHogNL » Sun Oct 20, 2019 7:44 pm
michel30 wrote:Thanks, this has helped me a lot I'm running now on 5.15.6 and I have 23,3 mb free space left after the update.
Can you share us in what location you had too much space in use? Maybe this helps this other guy with the same issue.
Postby michel30 » Sun Oct 20, 2019 8:04 pm
well I had directory's that was not in your list like a backup directory an update directory and also one very strange that had etc, lib and some other maps in. and these maps where also in / root..
but still when I match my files with yours than you will see that there are still more in my directory.
0   /HCBv2
764   /bin
0   /boot
0   /configured
0   /dev
1104   /etc
4728   /lib
0   /linuxrc
26696   /mnt
0   /proc
41840   /qmf
136   /root
892   /sbin
0   /sys
0   /tmp
74836   /usr
1192   /var
But on my Toon there are also installed some apps from the app store.....
michel30
Postby TheHogNL » Sun Oct 20, 2019 8:25 pm
michel30 wrote:but still when I match my files with yours than you will see that there are still more in my directory.
Check that /mnt dir. Too high for 'after an update'. During update /mnt/data/update will contain the update files but those should be deleted afterwards. Then /mnt should mostly contain logs/config files and the bigest the hcb_rrd files (the elec/gas usage data/history).
Postby michel30 » Sun Oct 20, 2019 9:52 pm
In my /mnt directory I have:
352 Aug 16  2017 qmf
432 Oct  6 20:25 tsc
472 Oct 20 12:40 update
In the Update directory I have only:
qb-auto-update-msg-sent
upgrade-qb2.sh
upgrade-qb2.sh.log
upgrade-qb2.sh.res
in the qmf directory I have:
2312 Oct 20 21:30 config
1192 Oct 20 21:03 log
856 Oct 20 12:44 var
michel30
Postby TheHogNL » Mon Oct 21, 2019 9:13 am
Weird, combined that is not: 26696 /mnt
Postby michel30 » Mon Oct 21, 2019 6:05 pm
Hello TheHogNL,
I was spitting in the directory /mnt to see where the big number is coming from and it is here:
20324 /mnt/data/qmf/var/hcb_rrd/
but the count files is 215 but at the front when I do du -sk /mnt/data/qmf/var/hcb_rrd/ * I see sometimes 175, 340, 42, etc..
Michel
michel30
Postby TheHogNL » Mon Oct 21, 2019 7:29 pm
Hmm are there old (not used) rrd's in there?
Compare these both results:
ls /mnt/data/qmf/var/hcb_rrd | cut -d\. -f1 | cut -d\- -f1,2,3,4,5 | sort -u
with
grep uuid /qmf/config/config_hcb_rrd.xml | wc -l
if the first is more then then second then there are old rrd in there not being used in your system anymore and then
for i in `find  /mnt/data/qmf/var/hcb_rrd | cut -d\/ -f7 | cut -d\. -f1 | cut -d\- -f1,2,3,4,5 | sort -u` ; do if ! grep -q $i /qmf/config/config_hcb_rrd.xml ; then ec
ho $i ; fi ; done
Should show which uuid's are not used anymore
Postby michel30 » Tue Oct 22, 2019 6:02 pm
It does not cleanup...
105 files
29 files
for i in `find /mnt/data/qmf/var/hcb_rrd | cut -d\/ -f7 | cut -d\. -f1 | cut -d\- -f1,2,3,4,5 | sort -u` ; do if ! grep -q $i /qmf/config/config_hcb_rrd.xml ; then echo $i ; fi ; done
But when I check I still see 105 files plus when I do: du -sk /* than it says 26800 /mnt
michel30
Postby Toonz » Tue Oct 22, 2019 6:46 pm
if you don't mind losing your history you can also delete all rrd files. They will be created again anyway.
Postby TheHogNL » Tue Oct 22, 2019 7:22 pm
Can you send the file list of that rrd directory?
Postby TheHogNL » Tue Oct 22, 2019 8:09 pm
Just recieved your list of files. There are a lot of garbage in there.
All files older than one day in that directory are useless ( find /mnt/data/qmf/var/hcb_rrd/ -type f -mtime +1 ).
Make a copy of them and then remove them.
Postby michel30 » Wed Oct 23, 2019 7:09 pm
Hello TheHogNL,
I thought so :) I deleted the old files and now I have 93 files from today with .dat and .rra in /mnt/data/qmf/var/hcb_rr.
When I run the command ls /mnt/data/qmf/var/hcb_rrd | cut -d\. -f1 | cut -d\- -f1,2,3,4,5 | sort -u , it will show 29 files and when I run grep uuid /qmf/config/config_hcb_rrd.xml | wc -l that it will also show 29.
regards,
Michel
michel30
Postby jumperone » Mon Nov 04, 2019 12:24 pm
The update script works perfectly.
With Putty of 4.15.6 after 4.22.7.
Then with the TLC menu from 4.22.7 after 5.05.6 and then after 5.15.6
everything works perfectly thanks
I have the toon with Version: 2.0 - ThehogNL - 24-3-2018 upgrade from version 2.9.26 upgrade to 4.10.6. Update failled / Bus error
OPKG Do Not Work / Bus error / orange screen with 2 points.
What can I do
jumperone
Postby TheHogNL » Mon Nov 04, 2019 8:38 pm
jumperone wrote:The update script works perfectly.
Great! You maybe need to change your user profile footer as is has some text about failures :D
Previous
Return to Toon Firmware
cron
