Firmware 5.30.4
Posted: Thu Jun 25, 2020 8:02 pm
by bekke517
I'd like to know if it is save to install thenew version of the firmware 5.30.4
Re: Firmware 5.30.4
Posted: Thu Jun 25, 2020 9:32 pm
by TerrorSource
Yes it is.
We've tested it and runs fine
Re: Firmware 5.30.4
Posted: Tue Jun 30, 2020 11:00 pm
by michel30
Ip updated my Toon 1 and all okay..
Thanks again for the nice update script.
Re: Firmware 5.30.4
Posted: Fri Jul 03, 2020 2:25 pm
by Flarrestein
Works perfect here.
Re: Firmware 5.30.4
Posted: Thu Jul 23, 2020 10:00 pm
by Ossegek
Where can i find the change log
Re: Firmware 5.30.4
Posted: Thu Jul 23, 2020 10:07 pm
by TheHogNL
Ossegek wrote:Where can i find the change log
Check the (dutch) forum
https://toonforum.nl/d/4-softwareversie-overzicht/57
Re: Firmware 5.30.4
Posted: Sat Aug 01, 2020 10:10 pm
by Hmmbob
I'm on 5.30.4, but my Toon v1 keeps saying the "new TSC resource file available, reboot gui" message and reboots on its own but then the message appears again.
It's also rather slow, way slower than after the last update.
Any idea what's happening?
Re: Firmware 5.30.4
Posted: Sat Aug 01, 2020 10:56 pm
by TheHogNL
Hmmbob wrote:I'm on 5.30.4, but my Toon v1 keeps saying the "new TSC resource file available, reboot gui" message and reboots on its own but then the message appears again.
It should not reboot on its own. A new TSC resource file is published which includes some new icons for new toonstore apps. Nothing important.
That message should only appear when you hit 'check update' in TSC menu and it will then download the new resource file and asks you to restart the GUI.
You probably have seen the 'there is a new TSC resource file availabe. Please update using the TSC menu'. This directs you to this.
In your case, I think something else is wrong. Disk full? Too many apps running?
Re: Firmware 5.30.4
Posted: Sun Aug 02, 2020 3:05 pm
by Hmmbob
Thanks!
Diskspace does not seem to be an issue:
eneco-001-392594:~# df -h
Filesystem Size Used Available Use% Mounted on
ubi0:rootfs 103.3M 80.5M 22.8M 78% /
tmpfs 61.6M 368.0K 61.3M 1% /var/volatile
Apps:
Boilerstatus 1.0.7
Newsreader 1.1.3
Buienradar 8.5.6
Toonstore 5.0.9
This is the message:
I've rebooted "the hard way" (unplugged it from the wall, waited 30sec, replugged) - let's see if that helps.
Re: Firmware 5.30.4
Posted: Sun Aug 02, 2020 6:35 pm
by TheHogNL
Hmmbob wrote:Thanks!
Apps:
Boilerstatus 1.0.7
Newsreader 1.1.3
Buienradar 8.5.6
Toonstore 5.0.9
You do need to confirm that message by pressing the > in the message
Re: Firmware 5.30.4
Posted: Sun Aug 02, 2020 7:01 pm
by mAiden
Nice to see you here Hmmbob !!
Look what TheHogNL say, just tap on the ">", message will be gone.
This shows only a new TSC resource file is published which includes some new icons for new toonstore apps. Nothing important
Re: Firmware 5.30.4
Posted: Sun Aug 16, 2020 9:41 am
by Hmmbob
Thanks both!
