Switching “vloerverwarming pomp” using domoticz and toon
If you don't know where to post, post here.
Postby Jjhendrickx » Mon Jun 18, 2018 7:20 am
Dear forum-members,
After reading this excellent forum, I have a question before I start from scratch :) .
I would like to turn on my “vloerverwarming pomp”/underfloor heating pump, using domoticz and toon. I have a working domoticz installation, and an normal Toon, without subscription. I would like to root-toon, and then using a domoticz script to controlle a Z-wave switch on the pump.
Is there a variable that is avaible in domoticz/rooted-toon, to check if the CV is heating? Or is it easiest way, check if the requested temperature>room temperature?
Kind regards,
Jan-Jaap
Ps. I know a “pompschakelaar” is probably easier, cheaper and faster, but not as nice :D
Jjhendrickx
Re: Switching “vloerverwarming pomp” using domoticz and toon
Postby Rudolf » Mon Jun 18, 2018 10:05 am
I think the boiler-status app provides some stats from the boiler/OpenTherm; i.e. you could check the modulation level to see if it's heating.
Both current room-temperature and setpoint are available too.
Like this:
{"sampleTime":"18-06-2018 11:03:00","boilerSetpoint":0,"roomTempSetpoint":12,"boilerPressure":0,"roomTemp":24.29,"boilerOutTemp":0,"boilerInTemp":0,"boilerModulationLevel":0}
My Toon is not connected to the boiler, so the values don't make sense. (still testing in the attic...)
Domoticz-scripts can parse these values and act accordingly.
Rudolf
Postby TheHogNL » Mon Jun 18, 2018 2:10 pm
Rudolf wrote:I think the boiler-status app provides some stats from the boiler/OpenTherm; i.e. you could check the modulation level to see if it's heating.
Like this:
I'm exactly doing this right now to turn on and off my heatpump. Each 10 seconds I read those values http://toon-ip:10080/happ_thermstat?act ... mostatInfo and when the burnerInfo is 1 my domoticz is switching on the heatpump. You can use that to turn on your zwave switch to turn on the pump.
Also, in newer versions Quby/Eneco is building Z-wave smart thermostat radiator valve support. Maybe this is something you can use when they have finished this
Postby georon » Thu Feb 07, 2019 9:42 pm
I just finished the dzVents code to switch my floor heating pump.
You can find it at https://github.com/Geo-Ron/dzVents
No support however :)
the script dzToon controls my Toon <-> Domoticz
On of the switches is the heating state.
the script dzPompVloerverwarming gets triggered by that switch and starts/stops the pump.
Also the pump will start for 2 seconds every hour to prevent it from getting stuck.
georon
Postby madpatrick » Fri Feb 08, 2019 3:30 pm
georon wrote:I just finished the dzVents code to switch my floor heating pump.
Nice !!
Normal pumpswitches turns on the pump at fixed temperature (38°C).
This should also be possible with a script. Maybe an option to add.
madpatrick
Postby TheHogNL » Fri Feb 08, 2019 4:17 pm
madpatrick wrote:Normal pumpswitches turns on the pump at fixed temperature (38°C).
That is not what he needs. He want to have the pump not running even when the boiler is heating. So that upstairs the radiators can get warm without the floor downstairs is heating (when downstairs is warm enough).
Postby Fietspomp » Mon Mar 11, 2019 11:02 am
I have done the same but with Home Assistant (Which I like more than Domoticz).
From the boiler status I use the boiler set temp to switch on/off my vloerverwarming pump using plugwise.
Plugwise is of course controlled from Home Assistant via MQTT and the boiler status is a sensor in Home Assistant. Works perfect!
Fietspomp
Return to Toon miscellaneous
