Cost and Honeywell EVO
If you don't know where to post, post here.
Postby Sa_reno » Fri Feb 22, 2019 12:40 pm
Hi All,
At this moment I have an unrooted Toon 1 and I just ended my contract with Eneco. After searching and reading through this forum I am still not sure if rooting will enable the features I am looking for:
1) In the overview of features I read that customized cost is not possible with the rooted toon, is this still the case? I do not need to know if I used more or less than the monthly amount but I would like to now the EURO's I have used. Can this be done?
2) I do not use the Toon as a thermostat because I have an Honeywell EVO system that controls all rooms individually. However, can I get the 2 systems to work together? i.e. the Evosystem sends the heat requirement to the Toon, Toon talks to the CV? And also, control the room settings in Toon? That way I can ditch the EVO controller.
Sa_reno
Re: Cost and Honeywell EVO
Postby TerrorSource » Fri Feb 22, 2019 1:08 pm
To answer the points:
1. It should remember the costs for kwh and gas you are using now, until you factory reset the Toon.
2. Dont have any experience with Honeywell systems. Maybe it's possible to connect the Toon and the Honeywell to Domoticz and script the things you want in Domoticz.
TerrorSource
Postby Sa_reno » Fri Feb 22, 2019 2:23 pm
Thanks,
In regards to 1, can I enter the cost per M3 gas and per KWH mannually?
Sa_reno
Postby WickedMaster » Fri Feb 22, 2019 2:36 pm
This is not possible (yet).
WickedMaster
Postby Sa_reno » Fri Feb 22, 2019 2:56 pm
WickedMaster wrote:This is not possible (yet).
Too bad, not a reason to root it then.
I hope someone can help me out with the EVO thingie.
Sa_reno
Return to Toon miscellaneous
