Waterusage
whizzz63
Waterusage
Post by whizzz63 »
Is there a possibility to monitor the water usage via the optical sensors?
Re: Waterusage
Post by TheHogNL »
Yes. But unknown how :-)
It is in the Toon sofware but we don't know which hardware to connect to it. We must wait until we see this in production on Toons
Hussar_303
Re: Waterusage
Post by Hussar_303 »
Do you think it can be homebrewed, or would it better to leave the software untouched and wait for the pros to do something about it?
michel30
Re: Waterusage
Post by michel30 »
Could it be that this is for detection if water leak?
today i heard an advertising spot from engine Belgium and they were talking about box get an sms when there is an water leak.
Re: Waterusage
Some time ago I bought a pulse generator for my water meter, never used it. Will hook it up to a toon meter adapter in the summer holiday (if I can still find it :-) ), and give it a shot.
Hussar_303
Re: Waterusage
Hi Marcelr, have you had any progress in that project? I had to delay a little bit my home automation project for financial reasons, so I still have time to learn the theory :lol:
Jasper
Re: Waterusage
Post by Jasper »
I just rooted my Toon and was also looking for monitoring water usage.
Found this thread using the search, so is it already possible to get this to work?
Jasper
Re: Waterusage
Post by Jasper »
While waiting for the post to be approved I found out that that it's not jet possible in the Netherlands. Though I do have a spare port on the meteradapter for gas, the electricity is taken by the solar panels and the S1 is going to the meter port.
Can't the spare gas connector be reprogrammed for water?
Re: Waterusage
Post by TheHogNL »
Jasper wrote:While waiting for the post to be approved I found out that that it's not jet possible in the Netherlands. Though I do have a spare port on the meteradapter for gas, the electricity is taken by the solar panels and the S1 is going to the meter port.
No you need the belgian (Boxx) meteradapter for that (also uses the 'gas' connection though). A boxx meteradapter works fine on your dutch toon by the way.
Jasper
Re: Waterusage
Post by Jasper »
Thanks, then how do I get one. I checked 2ehands.be and didn't see any.
Re: Waterusage
I got mine from 2dehands.be.
But it's true, they're in short supply.
Peter06
Re: Waterusage
Post by Peter06 »
hi,
last week smart E and Gas meter where installed and those are up and
running via P1
i did also installed 2 2e meetadapter to connect my pulse from the water
meter.
2e meetadapter is added but i cannot choose any item, i do see e/gas/water
but none of them i can select.
how do i add the water sensor?
looking forward of your reply.
best regards peter
X1pheR
Re: Waterusage
Post by X1pheR »
Peter06 wrote:hi,
running via P1
meter.
best regards peter
Did you ever get this sorted out?
Re: Waterusage
Post by TheHogNL »
X1pheR wrote:
Peter06 wrote:hi,
running via P1
meter.
best regards peter
See further above. You need a boxx meteradapter (belgian toon) for this
rleunk
Re: Waterusage
Post by rleunk »
Hello, got a boxx meter module and got it connected to my Toon, saw that some off you have it working also, is this with the standard optical sensor?
Or has someone managed to use another sensor?
From sometime ago I had a Sensus HRI-A4 pulse sensor lying around, now I am trying to figure out if I can connect this to the boxx module to read the watermeter.
Someone got an idea if this is possible and how to connect it?
Return to “Toon miscellaneous”
